APM Power Meter
For single-phase, split-phase & 3-phase mains networks
EVALUATION KIT AVAILABLE
Contact us to request yours
Accuracy
Combined digital and
bar graph display
Ten user configurable
alarms
TY
TH
1
Warning
flash
A
W
Programmable dynamic
backlight color
E YE
AR
Advanced Panel Meter (APM)
RE
RRAN
Instantaneous:
Voltage (L-L and L-N)
Current (L-L and L-N)
Reactive Power (VAr)
Active Power (W)
Apparent Power (VA)
Frequency (Hz)
Power Factor (PF)
THD Voltage & Current
% Max Load
Alarm Status (available on
Modbus communication)
• Phase Angle (available on
• Total Energy (kWh or kVAh)
Programmable scale
Measure single-, splitand 3-phase
PLC
Networks:
2 Digital Outputs
1 Analog Output
USB port for custom user settings
via the free easy-to-use software
Front panel
navigation buttons
Single phase, 2-wire
Single phase, 3-wire (split-phase)
3-phase, 3-wire
3-phase, 4-wire
Less
than
75mm
deep
Modbus®
RTU over RS485
Connectivity
Key Features
For single-, split- and 3-phase applications.
Measures Active (W), Reactive (VAr) and Apparent (VA) power.
Displays electrical parameters on large, backlit LCD display.
Features two independent opto-isolated digital outputs plus one analog 4-20mA output.
Includes MODBUS® RTU communication as standard.
Provides clear indication of electrical circuit performance.
User-programmable scale and custom alarm messages display critical parameters and immediately alerts operators
when a parameter is out of range.
Programmable Current Transformer (CT) and Potential Transformer (PT) ratios.
Go to www.trumeter.com/apm for further information
Specifications
Wiring Diagrams and Isolation
NETWORKS
1P2W, 1P3W, 3P3W, 3P4W,
MEASUREMENT
Frequency
Single phase 2-wire
(1P2W)
N
L
45 - 65 Hz
Voltage measurement range
Voltage
Input
L-L 0 - 600VAC
L-N 10 - 300VAC
Programmable PT range
100-277VAC
50-60Hz
1:1 to 1000:1
Current measurement range
0 - 5A
Programmable CT range
CT
Input
PSU
1:1 to 1000:1
Accuracy
1% (THD 5%) of full scale
ENVIRONMENTAL
Temperature - operating
-10 to +50°C
Temperature - storage
-40 to +70°C
IP rating (from the front)
IP65, NEMA type 4 and 12 (UL 50)
3 phase 3-wire
(3P3W)
POWER SUPPLY
Input
N
L1
L2
L3
Voltage
Input
100 - 277 VAC
Supply frequency
CT
Input
50-60Hz
Max power
2W
100-277VAC
50-60Hz
DISPLAY
Backlight colors
PSU
Red, Green, White
DIGITAL OUTPUTS
Number
2
Type
Opto-Isolated
Operating modes
Momentary
Max voltage
Control Outputs
24VDC
Max sink current
15mA
ANALOG OUTPUTS
Number
1
Analog output
4-20mA
COMMUNICATION
Modbus® RTU over RS485
CERTIFICATION
CE, RoHS, UL, cUL, UKCA
Isolation
Dimensions:
Modbus
Panel Cutout:
68mm x 68mm
[2.68” x 2.68”] as per
DIN43700/IEC61554
2.83
67.5
2.24
57
2.83
72
2.24
57
Digital Outputs
2.90
73.6
2.83
72
Current
Input
Control
Inputs
Isolation barriers:
Galvanic
Isolation Barrier
USB
Analog
Output
Voltage
Input
2.83
67.5
0.98
25
Power Supply
2.44
62.10
Part Numbers
APM-PWR-APO
APM-PWR-ANO
APM-PWR-XXX
APM Power Meter, Positive LCD
APM Power Meter, Negative LCD (subject to MOQ and extended lead time)
Custom Option
029461-01
024569-11
USB 2.0 (A-Male to Mini-B) Cable 1.8m
Power Meter Evaluation Kit
www.trumeter.com
Trumeter (The Americas)
6601 Lyons Rd, Suite H-7
Coconut Creek, Florida
FL 33073,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
Open-type Measuring
and Testing Equipment
E469787
Trumeter (Europe)
Pilot Mill
Alfred Street
Bury,
BL9 9JR
Tel: +44 161 674 0960
Email: sales.uk@trumeter.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
APM-PWR-DS-v.3.9
01/2023
很抱歉,暂时无法提供与“APM-PWR-APO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2703.155911+350.82030
