3410-3010
3410-3010
    TRUMETER
3410-3010 数据手册
Model 3410 Electronic LCD Hour Meter EVALUATION KIT AVAILABLE Contact us to request yours The Model 3410 LCD Hour Meter provides a large display with 0.28” [7mm] high characters, available in 5 different industry size housings. A wide operating voltage, 10-300VDC and 20-300VAC, makes the model 34 versatile for all indoor and outdoor applications. All models are NEMA 4/4X, 12 & IP66 rated when used with the optional gasket and have a polarized lens which assures high visibility in an outdoor environment. Key Features Options • • • • • • • Totally sealed from moisture and dirt AC and DC voltage input in the same unit Compact depth Fits in existing panel openings Always on display A choice of 5 housings Optional Remote Reset Applications Medical Devices Generators Control Panel Production Equipment Garden Tractor Marine Equipment Specifications Sealing EMC Compliance Protection Against Weight Part Number 0.78 1.98 50.3 1.476 1.461 37.50 37.10 0.03 0.70 0.03 0.70 RECTANGULAR FLUSH MOUNT AND SNAP-IN MODEL 0.78 19.70 0.25 6.35 0.88 22.40 1.98 50.30 0.63 16.07 0.78 19.70 0.965 0.949 24.50 24.10 0.63 16.07 1 oz. [28g] UL & cUL recognized (file # ELIY2.E36690),1.09CE, SAE, 27.6 UKCA, NEMA 4/4X/IP66 compliant (not including 3410-2210) Part Numbers 1.26 32.13 0.78 19.70 0.94 23.9 27.90 0.78 19.70 2.19 55.65 ROUND FLUSH MOUNT Notes: 1. W  hen interfacing the Model 34 with a Solid State Relay or AC Sensor, the leakage current needs to be considered. 2. E  xceeding 1.476the Absolute Voltage Range and the Absolute Maximum 1.461 Limits may result in damge to the unit. 37.50 37.10 0.78 19.70 Approvals 1.09 27.6 Totally sealed EN61326 1.60 40.60 Alternator load dump: 150V EMI (Electromagnetic Interface): +400V @ 500Hz inductive switching and reverse polarity 0.776 19.70 2.21 56.1 1.09 27.6 1.60 40.60 0.94 23.9 Dielectric Compliance 2.87 72.90 THREE HOLE MOUNT 2 15 5 0. 3.8 Humidity Vibration CL Operating Temp.: -10˚C to +60˚C [14˚F to +140˚F] 1.09 1.750 27.6 Storage Temp.: -20˚C to +70˚C44.45 [-4˚F to +158˚F] 95% RH per SAE J1378 20g @ 10 to 80 Hz per SAE J1378 Shock: 44 to 55g’s per SAE J1378 1000VAC 50/60 Hz for 1 minute1.44 (34x0 models only) 36.6 Compliant to the European WEEE and RoHS Directives 1.10 27.90 Environmental: Temp. TWO HOLE MOUNT 1.44 36.6 0.03 0.70 0.94 23.9 Totally sealed from moisture and dirt. NEMA 4/4X, 12 & IP66 compliant from the front when properly mounted using the optional gasket. (Not applicable in the Snap-In Model) 0. 15 7 4 Enclosure 2.19 55.65 1.10 27.90 Terminations 10-300VDC and 20-300VAC - 50/60Hz
3410-3010 价格&库存
很抱歉,暂时无法提供与“3410-3010”相匹配的价格&库存,您可以联系我们找货
  • 1+287.07825
库存:32
