APM-TEMP-APO
APM-TEMP-APO
    TRUMETER
    TRUMETER - APM-TEMP-APO - TEMP METER, 4DIGIT, 12MM, POSITIVE LCD
APM-TEMP-APO 数据手册
Temperature Meter W A E YE Programmable backlight color to alert user Warning flash 40 TY Easy to Use. Easy to Read. RE AR TH For use with Theromocouples RRAN Combined digital and bar graph display Segment curved bar graph display Programmable 4 digit starburst display. Custom messages & annunciators Programmable scale 2 0.25 % Alarm set points Accuracy PLC USB port for custom user settings via the free easy-to-use software 2 outputs - digital and analog user configurable linearization Less than 53mm deep INPUT Full 4 digit readout for accuracy Featuring an acclaimed easy-to-read display and a versatile set of inputs, the Temperature Meter takes the APM into a wide range of new industrial applications. The programmable scale and custom annunciators mean users can tailor the meter to display their critical parameters exactly how they want, while the dynamic backlighting, in conjunction with setpoints, means operators are visually alerted when a parameter is out of range. The two outputs can be used to control other systems in the process, meaning the APM Temperature Meter is much more than just a display. Trumeter’s innovative input signal optimization achieves accuracy of 0.25% for precise measurement, display and control. Designed for use with thermocouples, the Temperature meter allows the user to configure up to 20 points in a non-linear conversion table via the APM Configurator application in addition to the inbuilt thermocouple linearisation. Go to www.trumeter.com/apm for further information Key Features Large multi-format display that incorporates: Visibility: • 40 segment bar graph display • User-adjustable backlight brightness and color • Large 4-digit display • Large display • Separate Starburst display area for annunciators, custom • Wide viewing angle (horizontal and vertical) messages and alarm information • Custom annunciators • D  ynamic backlight color Programmable: Dimensions: • Display Range (Both Min & Max Values) 57mm [2.24”] 53mm [2.09”] 72mm [2.84”] 72mm [2.84”] • Custom annunciators • User-selectable backlight color and intensity • Two independent alarm set-points • T  wo independent outputs • 4-20mA analog retransmission output Thermocouple Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554 Easy To Use Software Type B, E, J, K, N, R, S and T Accuracy Just plug into any USB port on your PC, run the freely available APM Configurator application and you’re off. No drivers required. 0.25% of full scale ENVIRONMENTAL Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C IP rating (from the front) NEMA 4 & 12 with IP65 POWER SUPPLY Nominal Input (AC or DC) 12-24V AC/DC Max Power 1.6W Frequency DC & 50-400 Hz DISPLAY Number of digits 4 Digit height 12mm [0.47”] Number of message characters Message character height Backlight colors 4 6mm [0.236”] Red, Green, White LCD display Positive or Negative OUTPUTS Max voltage 34V Max current 500mA Analog output 4-20mA CERTIFICATION UL and cUL, CE Open-type Measuring and Testing Equipment E469787 Part Numbers: Part Description APM-TEMP-APO APM-TEMP-ANO APM TEMPERATURE METER, POSITIVE LCD WITH OUTPUTS APM-TEMP-APS APM TEMPERATURE METER, POSITIVE LCD WITH MODBUS APM TEMPERATURE METER, NEGATIVE LCD WITH OUTPUTS APM-TEMP-ANS APM TEMPERATURE METER, NEGATIVE LCD WITH MODBUS 022128-01 USB Cable www.trumeter.com By Request: Modbus connectivity Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Asia Pacific Distributor Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: info@idtworld.com APM-TEMP-DS.v.1.1 11/2020
APM-TEMP-APO 价格&库存
很抱歉,暂时无法提供与“APM-TEMP-APO”相匹配的价格&库存,您可以联系我们找货
APM-TEMP-APO
  • 1+1573.710431+204.41700
  • 3+1463.489813+190.09990
库存:1
