APM-MAX-M21-PU-4B
APM-MAX-M21-PU-4B
    TRUMETER
    TRUMETER - APM-MAX-M21-PU-4B - DIGITAL PANEL METER, 4DIGIT, LCD, 240VAC
APM-MAX-M21-PU-4B 数据手册
APM-MAX M21 and M23 EVALUATION KIT AVAILABLE Programmable RGB backlight for user alerts. Segment curved bar graph display TY A E YE W 60 16 million colors RE AR TH Contact us to request yours RRAN Programmable scale Combined digital and bar graph display 2 Alarm set points Modbus® Programmable 4 digit starburst display. Custom messages & annunciators RTU/TCP/IP Connectivity PLC USB port for custom user settings via the free easy-to-use software 2 digital outputs 1 analog output Selectable to measure voltage, current, frequency or watts 108mm x 108mm; only 64mm deep and fits in 4” diameter circular cutout Full 4 digit readout for accuracy Designed for a wide range of power monitoring applications, the APM-MAX combines the instant visual representation of an analog meter with the speed and accuracy of a digital meter for instant recognition and precision measurement. The large 81.5mm x 66mm display features a two-line display, programmable scale, alarm set-points and colorchanging, full color RGB backlight for instant alerts. APM-MAX-M21: for high voltage applications; configurable as an ammeter, volt meter, frequency meter or power monitor (Watts, VA & Power Factor). APM-MAX-M23: for low voltage applications; configurable as a process meter or to be used in conjunction with a shunt. Both models feature digital and analog outputs and serial MODBUS® RTU as standard (ethernet MODBUS® also available) for communication with other components in a system as well as an IP65 rating and our industry leading three-year warranty. Go to www.trumeter.com/apm for further information Large multi-format display that incorporates: Specifications MEASUREMENT M21 M23 Input range (V1) 0-600V DC/AC 47-63Hz 0–10V DC Current Input range (Direct) 0–5A DC/AC 45-65Hz 0–50mA DC 0-500mV DC/AC 45-65Hz 0-500mV DC Current Input range (w/shunt) Frequency (AC) Power Measurement 0–400Hz 0–400Hz Watts, VA & Power Factor - Accuracy (Frequency) 0.1% Accuracy (Voltage) 0.5% Display modes RMS Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C Programmable: • • • • • • Scaling and Range (min and max) Custom annunciators User selectable backlight color and intensity Two independent alarm set-points Two independent outputs 4-20mA analog monitor output • The largest display of any APM • User adjustable RGB backlight provides an almost infinite range of colors for different requirements or environmental conditions. • Wide viewing angle (both horizontal and vertical) • C  ustom annunciators IP65 POWER SUPPLY Universal (AC) 100–240V AC (50-60Hz) Low Voltage (DC) 12-24V DC (50-60Hz AC) Part Numbers Standard Models - Modbus RTU DISPLAY Number of digits 60 segment bar graph display Large 4 digit display Separate Starburst display area for annunciators, custom messages and alarm info Full color RGB dynamic backlight for user alerts Visibility: ENVIRONMENTAL IP rating (from the front) • • • • APM-MAX-M21-PU-4R Positive LCD, volt, amp, freq or power monitor, RTU 4 APM-MAX-M23-PU-4R Positive LCD, process or shunt meter, RTU Digit height 14.5mm [0.57”] APM-MAX-M21-NU-4R Negative LCD, volt, amp, freq or power monitor, RTU Digit height of annunciator 6.8mm [0.27”] APM-MAX-M23-NU-4R Negative LCD, process or shunt meter, RTU Number of message characters APM-MAX-M21-PL-4R Positive LCD, low voltage, volt, amp, freq or power monitor, RTU 4 Backlight colors APM-MAX-M23-PL-4R Positive LCD, low voltage, process or shunt meter, RTU Full RGB backlight and White LCD display APM-MAX-M21-NL-4R Negative LCD, low voltage, volt, amp, freq or power monitor, RTU APM-MAX-M23-NL-4R Negative LCD, low voltage, process or shunt meter, RTU Positive or Negative OUTPUTS Max voltage 34V Max current 500mA Analog output Standard Models - Modbus TCP/IP and RTU APM-MAX-M21-PU-4B Positive LCD, volt, amp, freq or power monitor, TCP/IP and RTU APM-MAX-M23-PU-4B Positive LCD, process or shunt meter, TCP/IP and RTU 4-20mA or 0-10V APM-MAX-M21-NU-4B Negative LCD, volt, amp, freq or power monitor, TCP/IP and RTU APM-MAX-M23-NU-4B Negative LCD, process or shunt meter, TCP/IP and RTU COMMUNICATION Modbus® APM-MAX-M21-PL-4B Positive LCD, low voltage, volt, amp, freq or power monitor, TCP/IP and RTU RTU and/or TCP/IP CERTIFICATION APM-MAX-M23-PL-4B Positive LCD, low voltage, process or shunt meter, TCP/IP and RTU UL and cUL, CE, UKCA APM-MAX-M21-NL-4B Negative LCD, low voltage, volt, amp, freq or power monitor, TCP/IP and RTU APM-MAX-M23-NL-4B Negative LCD, low voltage, process or shunt meter, TCP/IP and RTU Options Dimensions: 2.596 65.9 4.269 108.4 3.376 85.7 3.376 85.7 2.541 64.5 3.210 81.5 4.269 108.4 1.756 44.60 DESCRIPTOR DEFINITION OPTIONS -?X-XX LCD Type P - Positive N - Negative LCD also available -X?-XX PSU Type U – Universal 100–240V AC 50-60Hz L – Low Voltage 12-24V DC / 50-60Hz AC -XX-?X Analog Output 4 – 4 to 20mA / 0 – 20mA switchable 1 - 0 to 10V DC also available* -XX-X? Communications R – Modbus® RTU B – Modbus® TCP/IP and Modbus® RTU 024569-21 MAX Meter Evaluation Kit Panel cutout: Square: 68mm x 68mm [2.7” x 2.7”] Circle Diameter: 96mm [3.8”] www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com APM-MAX-DS-v.2.6 2/2023
APM-MAX-M21-PU-4B 价格&库存
很抱歉,暂时无法提供与“APM-MAX-M21-PU-4B”相匹配的价格&库存,您可以联系我们找货
APM-MAX-M21-PU-4B
    • 1+4137.766061+535.71694
