3400-2010
3400-2010
    TRUMETER
    TRUMETER - 3400-2010 - LCD COUNTER, 8-DIGITS, 20VAC-300VAC / 10VDC-300VDC
3400-2010 数据手册
Model 3400 Electronic LCD Counter EVALUATION KIT AVAILABLE Contact us to request yours The Model 34 LCD Totalizer/Preset Counter provides a large display with 0.28” [7mm] high characters, in a range of industry-standard sized housings. The Model 34 counts and displays the number of pulses that appear at its input terminal at a rate of 40 pulses per second (Hz), the input interface handles AC or DC inputs. The Totalizers are available in 5 different housings. A wide operating voltage, 10-300VDC and 20-300VAC, makes the model 34 versatile for all indoor and outdoor applications. All models are NEMA 4/4X, 12 & IP66 rated when used with the optional gasket and have a polarized lens which assures high visibility in an outdoor environment. Key Features • • • • • Options Totally sealed from moisture and dirt AC and DC voltage input in the same unit Compact depth Fits in existing panel openings Always on display • • Optional Remote Reset A choice of 5 housings Applications Medical Devices Test Equipment Control Panels Production Equipment Office Equipment Secondary Equipment 0.776 19.70 2.21 56.1 0.776 19.70 1.98 50.3 RECTANGULAR FLUSH MOUNT AND SNAP-IN MODEL 0.94 23.9 0. 0.88 22.40 CL ROUND FLUSH MOUNT 27.90 CL 1.09 27.6 1.750 44.45 1.09 27.6 1.750 44.45  hen interfacing the Model 34 with a Solid State Relay or AC sensor, the W leakage current needs to be considered. Exceeding the Absolute Voltage 1.44 36.6 Range and the Absolute Maximum Limits may result in damge to the unit. 1.60 40.60 AC/DC Counter 2-hole case 1/4” spade terminal non-reset AC/DC Counter 2-hole case 1/4” spade terminal remote-reset Gasket 1.09 27.6 5003-010 0.25 5003-010 6.35 3400-1000 AC/DC Counter 3-hole case 1/4” spade terminals non-reset 3400-1010 AC/DC Counter 3-hole case 1/4” spade terminals remote-reset **special order** MOQ=50pcs 3400-2000 AC/DC Counter flush rectangular case 1/4” spade terminals non-reset **special order** MOQ=50pcs 0.78 19.70 3400-0000 3400-0010 1.60 40.60 5003-017 5003-017 0.25 6.35 0.88 22.40 3400-2010 AC/DC Counter flush rectangular case 1/4” spade terminals remote-reset 5003-009 AC/DC Counter round SAE case 1/4” spade terminals non-reset **special order** MOQ=50pcs 5003-009 5003-009 3400-3010 AC/DC Counter round SAE case 1/4” spade terminals remote-reset AC/DC Counter snap-in case 1/4” spade terminals non-reset 3403-3000 3-30VDC Counter round SAE case 1/4” spade terminals non-reset 5003-010 5003-017 5003-009 NEMA 4X Gasket two hole mount NEMA 4X Gasket three hole mount NEMA 4X Gasket flush rectangular and SAE round mount 3400-0010-EVAL 3400 Evaluation Kit www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com 1.09 27.6 0.88 22.40 3400-3000 3400-5000 0.94 23.9 1.10 27.90 0.78 19.70 1.10 27.90 Description 0.94 23.9 1.44 36.6 Part Numbers Part Number 0.63 16.07 0.63 16.07 0.03 0.70 0.25 6.35 Notes: 1.98 50.30 1.26 32.13 1.26 32.13 0.88 22.40 0.78 19.70 Weight 0.03 0.70 1.09 27.6 0.94 23.9 0.78 19.70 0.25 6.35 Totally sealed Totally sealed from moisture and dirt. NEMA 4/4X, 12 & IP66 compliant from the front when properly mounted using the optional gasket. (Not applicable in the Snap-In Model) 1 oz. [28g] 0.776 19.70 2.21 56.1 1.98 50.3 1.09 27.6 EMC Compliance EN61326 Enclosure 0.78 19.70 1.60 40.60 0.78 19.70 Sealing 0. 15 7 4 0.78 19.70 Environmental Operating Temp.: -10˚C to +60˚C [14˚F to +140˚F] Storage Temp.: -20˚C to +70˚C [-4˚F to +158˚F] Humidity: 95% RH per SAE J1378 Shock: 44 to 55g’s per SAE J1378 Dielectric: 1000VAC 50/60 Hz for 1 minute Compliance: to European WEEE and RoHS Directives 0.776 19.70 2.21 56.1 15 7 4 UL & cUL recognized (file # ELIY2.E36690), CE, UKCA, SAE, NEMA 4/4X/IP66 compliant (not including snap-in models) 0.03 0.70 THREE HOLE MOUNT 0. Approvals TWO HOLE MOUNT 0.03 0.70 0.78 19.70 Standard 0.250” [6.4mm] spades 2.19 55.65 0.78 19.70 Terminations 2.19 55.65 1.60 40.60 1.44 36.6 1.10 27.90 Self-powered - battery life 10+ years (battery life reduced to 5 years for temps above 100˚F/37.8˚C) 1.44 36.6 0.78 1.10 19.70 27.90 Power 1.09 27.6 1.750 44.45 0.78 19.70 10-300VDC and 20-300VAC - 50/60Hz
3400-2010 价格&库存
很抱歉,暂时无法提供与“3400-2010”相匹配的价格&库存,您可以联系我们找货
    • 1+297.08595
    库存:14
