1-4635
    TRUMETER
    TRUMETER - 1-4635 - ELECTROMECHANICAL TOTALIZING COUNTER
1-4635 数据手册
Item # 1-4635 Right-hand, top-coming, standard reset knob Right-hand, top-coming, standard reset knob These 5 figure stroke counters are especially designed for limited space and high count life applications. The advanced drive system translates into exceptionally high operating speeds, extended operating life, for fast and accurate readings. Ideal for copiers, printing presses, cut-off machines, and piece-part counting applications. Also available with a thumb lever for use as a tally counter. Specifications Model No. 46 Display 5 Figures, white on black, 0.19 inch (5mm) high Display Height 0.19 Inch Display Height 5 mm No. of Digits 5 Reset Type Standard knob Speed 500 counts/minute Operating Temperature -15 to +140 °F Operating Temperature -25 to +60 °C Mounting Hole Dia. 0.13 x 0.24 Inch Mounting Hole Dia. 3.3 x 6.1 mm Weight 2 oz Weight 57 gm Stock Availability Yes Operating Life Beyond 5 million counts Rotation Top-coming Shaft Extension Right-hand Shaft Diameter 0.156 Inch 1 Shaft Diameter 4.0 mm Minimum Count Stroke 40 ° Maximum Count Stroke 45 ° 2 Model 46 Mechanical Stroke Counter With Lever & Spring Description With Thumb Lever These 5 figure stroke counters are especially designed for limited space and high count life applications. The advanced drive system translates into exceptionally high operating speeds, extended operating life, for fast and accurate readings. Ideal for copiers, printing presses, cut-off machines, and piece-part counting applications. Also available with a thumb lever for use as a tally counter. Features Options • • • • • • Compact size Reliability Low cost Special levers 10011-001S - additional spring 10007-009S - lever and spring Specifications Figures: Reset: Speed: Rotation: Count Stroke: Models Description 1-4615 1-4625 1-4635 1-4645 1-4635T Left-hand, Left-hand, Right-hand, Right-hand, Right-hand, * Shaft Extension: Shaft Diameter: Operating Life: Temp. Range: Weight: 5 figures, white on black, 0.19’’ [5mm] high Standard or large knob, non-reset 500 counts/minute Top-coming or top-going 40° Min. - 45° Max. top-coming, top-going, top-coming, top-going, top-coming, standard standard standard standard std. reset reset reset reset reset knob, knob knob knob knob with thumb lever Right-hand or left-hand 0.156’’ [4.0mm] Beyond 5 million counts -15°F to +140°F [-25°C to +60°C] 2 oz. [57g] Models Description 2-4615 2-4625 2-4635 2-4645 5-4645 Left-hand, Left-hand, Right-hand, Right-hand, Right-hand, top-coming, top-going, top-coming, top-going, top-going, large reset large reset large reset large reset non-reset knob knob knob knob Items in bold are normally in factory stock. Dimensions Right - Hand Shaft 2.53 [64.3] 1.28 [32.5] 12 3 45 1.20 [30.5] 0.96 [24.4] 1.44 [36.6] 0.81 [20.6] 1.52 [38.6] Mounting holes: 0.13’’ x 0.24’’ [3.3 x 6.1mm] slots Applications Copiers 42 Printing presses Farm equipment Piece-part counting Cut-off machines
1-4635 价格&库存
很抱歉,暂时无法提供与“1-4635”相匹配的价格&库存,您可以联系我们找货
  • 1+418.39674
库存:15
