3400-1000
3400-1000
    TRUMETER
    TRUMETER - 3400-1000 - LCD COUNTER
3400-1000 数据手册
Electronic Model 34 LCD Counter Description The Redington Model 34 LCD Totalizer/Preset Counter provides a large display, with 0.28” [7mm] high characters, in industry size housings. The Model 34 counts and displays the number of pulses that appear at its input terminal at a rate of 40 pulses per second (Hz). The input interface handles AC or DC inputs. The Totalizers are available in 7 different housings. All models are totally sealed and are capable of submersion in 6’ [2 meters] of water. A wide operating voltage, 10-300VDC and 20-300VAC, makes the model 34 versatile for all indoor and outdoor applications. All models are NEMA 4/4X, 12, & IP66 rated when used with the optional gasket and have a polarized lens which assures high visibility in an outdoor environment. Maintenance Meters are offered with a maximum of 3 preset “Redi-Alert’s” icons to alert users when service intervals are due or other periodic timed events are due. Models are available with front panel field or factory programmable alerts. Not only does the display flash to get attention, but it displays a choice of 7 different .08” [2mm] maintenance icons. Models are available with an Open Drain MOSFET output for the actuation of external alarms or indicator lamps. Users can program or specify the count/service interval and flash duration for each Redi-Alert. Flash duration is the amount of time in hours that the specific icon flashes before and after the specified total count. If a front panel manual reset of the Redi-Alert is required, the front panel models with switches must be specified. Features • • • • • • Totally sealed from moisture and dirt AC or DC voltage input in the same unit Compact depth Programmable output thresholds Preset count value Up to 3 Redi-Alerts/7 icons • • • • • • • Fits in existing panel openings Always on display A choice of 7 housings A choice of reset modes Front panel programmable Preset Counter with output 15+ Year Battery Life Specifications Display: LCD with large 0.28” [7mm] high figures black on light background Annunciators: LCD 0.08” [2mm] Reset: Remote, manual and non-reset Accuracy: 100% [provided signal meets stated parameters] Displays: 8 digits (99999999) Maximum pulse rate: 40 pulses per second (Hz) Inputs: 10-300VDC and 20-300VAC - 50/60Hz VIH 20VAC or 10VDC minimum VIL 3VAC or 3VDC maximum Power: Self powered - battery life 15+ years Terminations: Standard 0.250” [6.4mm] spades Output: 8 Environmental: Temperature: (Storage and Operating) -40 to +185˚F [-40 to +85˚C] Humidity: 95% RH per SAE J1378 Vibration: 20g @ 10 to 80 Hz per SAE J1378 Shock: 44 to 55g’s per SAE J1378 Dielectric: 1000VAC 50/60 Hz for 1 minute Compliance: Compliant to the European WEEE and RoHS Directives Sealing: Totally sealed EMC Compliance: EN61326:1997 with A1:1998 and A2:2001 for industrial environments Enclosure: Totally sealed from moisture and dirt, NEMA 4/4X, 12, & IP66 compliant from the front when properly mounted using the optional gasket. (Not applicable to Snap-In Model) Approvals: UL and cUL Recognized (file # ELIY2.E36690), CE, SAE, NEMA 4/4X/IP66 compliant Weight: Format: Open-Drain MOSFET with Source connected to Common (see note 3) Maximum Withstanding voltage: 30VDC, reference to Common Maximum Load current: 0.1Amp www.redingtoncounters.com 1oz [28g] Electronic Model 34 LCD Counter Functions Preset Counter: The preset function is centered on the output signal. When the count reaches the preset value, the output signal is turned “on”. The Preset function is count “up”. In addition to the preset function, models are also available with 3 RediAlert set points. Upon reaching the preset value the preset can be automatically reset, or it can await an external reset. Front Panel Switch Functions: Front panel switches can be used for reset, display selection and programming. The two front switches are used as follows: SEL: During programming this switch is used to select options and to move horizontally in the programming chart. RST: This is the reset switch during normal operation. to move vertically in the programming chart. During programming this switch is used to select options and Available Icons SERVICE OIL AIR FILTER CHANGE OIL FILTER LAMP MUFFLER Dimensions Rectangular Flush Mount 1.60 [40.6] .28 [7.0] 1.10 [27.9] 2-Hole Mount .34 [8.6] .89 [22.6] .34 [8.6] 1.75 [44.4] .50 [12.7] .28 [7.0] 1.10 [27.9] .05 [1.3] .05 [1.3] 1.41 [35.8] .50 [12.7] .89 [22.6] .05 [1.3] .05 [1.3] 1.41 [35.8] .75 [19.0] .75 [19.0] .25 [6.3] .25 [6.3] .88 [22.3] 1.43 [36.3] .88 [22.3] 1.43 [36.3] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] Maximum Panel Thickness: 0.375” [9.5mm] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] 2-Hole No-Hole Mount Round Flush Mount .34 [8.6] .34 [8.6] .28 [7.0] 1.10 [27.9] .50 [12.7] .89 [22.6] .50 [12.7] .28 [7.0] .79 [20.0] .05 [1.3] 1.41 [35.8] .05 [1.3] .75 [19.0] .03 [0.7] 1.29 [32.7] .05 [1.3] 2.21 [56.1] .05 [1.3] .25 [6.3] 1.98 [50.3] .88 [22.3] 1.43 [36.3] .75 [19.0] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] Maximum Panel Thickness: 0.375” [9.5mm] .25 [6.3] .88 [22.3] 1.43 [36.3] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] Maximum Panel Thickness: 0.375” [9.5mm] www.redingtoncounters.com 9 Electronic Model 34 LCD Counter 3-Hole Mount Snap-In Mount 1.10 [27.9] .34 [8.6] 1.29 [32.7] .34 [8.6] .28 [7.0] .79 [20.0] .50 [12.7] .28 [7.0] .79 [20.0] 1.29 [32.7] .50 [12.7] .05 [1.3] 1.60 [40.6] .05 [1.3] .75 [19.0] .03 [0.7] .05 [1.3] .05 [1.3] 2.87 [72.9] .25 [6.3] 1.98 [50.3] .88 [22.3] 1.43 [36.3] .75 [19.0] Panel Cutout: 1.46” [37mm] x 0.95” [24.1mm] Minimum Panel Thickness: 0.04” [1.0mm] Maximum Panel Thickness: 0.125” [3.18mm] .25 [6.3] .88 [22.3] 1.43 [36.3] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] Square Flush Mount .34 [8.6] .28 [7.0] .79 [20.0] .50 [12.7] .93 [23.6] 1.81 [46.0] 1.89 [48.0] 1.29 [32.7] 1.89 [48.0] .03 [0.7] .05 [1.3] .05 [1.3] .75 [19.0] 1.81 [46.0] .25 [6.3] .88 [22.3] 1.43 [36.3] Panel Cutout: 1.45” [36.8mm] x 0.95” [24.1mm] Maximum Panel Thickness: 0.375” [9.5mm] Notes 1. When interfacing the Model 34 with a Solid State Relay or AC Sensor, the leakage current needs to be considered. Contact the factory or see the application note at www.redingtoncounters.com 2. Exceeding the Absolute Voltage Range and the Absolute Maximum Limits may result in damage to the unit. 3. The open-drain MOSFET acts like an open-collector NPN trasistor. Care should be taken since there is no current limiting protection in the unit. Applications Medical Devices 10 Test Equipment Control Panels Production Equipment www.redingtoncounters.com Office Equipment Secondary Equipment
3400-1000 价格&库存
很抱歉,暂时无法提供与“3400-1000”相匹配的价格&库存,您可以联系我们找货
    • 1+605.801321+78.40428
