Model 3410
Electronic LCD Hour Meter
The Model 3410 LCD Hour Meter provides a large display with 0.28” [7mm] high characters, in industry size housings.
They are available in 5 different housings. All models are NEMA 4/4X, 12 & IP66 rated when used with the optional gasket
and have a polarized lens which assures high visibility in an outdoor environment.
Maintenance Meters are offered with an optional maximum of 3 preset “Redi-Alerts” icons to alert user when service
intervals are due or other periodic timed events are due. Models are available with front panel field or factory
programmable alerts. Not only does the display flash to get attention, but it displays a choice of 7 different .08 [2mm]
maintenance icons. Users can program or specify the count/service interval and flash duration for each Redi-Alert, Flash
duration is the amount of time in hours that the specific icon flashes before and after the specified total count. If a front
panel manual reset of the Redi-Alert is required, the front panel models with switches must be specified.
Key Features
Options
Totally sealed from moisture and dirt
AC or DC voltage input in the same unit
Compact depth
Fits in existing panel openings
Always-on display
15+ Year Battery Life
A choice of 5 housings
A choice of reset modes
Optional front panel programmable
Preset Timer
Can be programmed with starting time
Up to 3 Redi-Alerts/7 icons
Go to www.trumeter.com for further information
Specifications
Display
LCD with large 0.28” [7mm] high figures black on light
background
Run Indicator
Blinking decimal point
Reset
Remote, manual & non-reset (remote reset not avialble on
surface mounting housing)
Hour Meter
Resolution
0.01 or 0.1 Hour, displayed;
1 second, internal
Accuracy
± 0.1% @ room temperature
± 0.2% over the specified temperature range
Records &
Displays
9999999.9 - hours & 1/10’s or
9999999.9 - hours & 1/100’s
Inputs
10-300VDC and 20-300VAC - 50/60Hz
很抱歉,暂时无法提供与“3410-2010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+605.578281+78.40428
