711-0150
711-0150
    TRUMETER
    TRUMETER - 711-0150 - ELECTROMECHANICAL HOUR METER
711-0150 数据手册
711 Series Electromechanical Hour Meter The Model 711 provides a family of compact 7 figure, AC Hour Meters. Models are available in the standard industry housings, 2- Hole rectangular, flush-round and flush-rectangular. A choice of two rectangular panel cutouts are offered 1.45” X 0.95’’ [36.8mm X 24.1mm] or 1.45” X 0.87” [36.8mm X 2.1mm]. The Round meter has a panel cutout of 1.99” [50.5mm]. Key Features • • • • • • 7 figure, 99999.99 Various voltage inputs Large figures, 0.14” [3.6mm] CE Compliant, ROHS UL and cUL Recognized Synchronous Motor Applications • • • Office Equipment Test Equipment Medical Equipment • Options include: ◦ Special voltages ◦ Terminations ◦ Panel cutout Specification Figures Reset Voltages Case Material Weight Power Mount Terminations Temp. Range Storage Temp. Vibration Shock 7 figures, 0.14” [3.6mm] 99999.99 Non-reset 24, 115 or 230VAC (± 10%) Black polymer 1.2oz. [35g] 2 watts AC Clip or mounting holes 1/4” [6.3mm] spade terminals with screws (AC) -22°F to +180°F [-30°C to +82°C] -40°F to +185°F [-40°C to +85°C] 1g [10/500Hz] IEC 68-T2-34 30g [18ms] IEC 68-T2-27 25g [16ms] IEC 68-T2-19 CE Compliant, UL and cUL Recognized, UKCA Approvals Dimensions O2.28 [O58] 1.75 [44.5] 1234567 1.4 [36] 1.08 [27.4] 1234567 2X Ø.16 [Ø4.1] HOURS 0.9 [23] 1.60 [40.6] 1234567 1.21 [30.8] 0.87 [22.0] 1.43 [36.2] 2.1 [53] 0.12 [2.9] 1.43 [36.2] 0.08 [2.2] 0.87 [22.0] 0.13 [3.3] 0.06 [1.4] 2.33 [59.3] 2.33 [59.2] 2.33 [59.3] PANEL OPENING 1.45 [36.8] X 0.87 [22.1] PANEL OPENING 1.45 [36.8] X 0.87 [22.1] PANELTHICKNESS 0.50'' [12.7] PANEL OPENING 1.99 [50.5] DIA .94 [24.0] 1.75 [44.5] 1.4 [36] 2X Ø.16 [Ø4.1] 0.9 [23] 1234567 1234567  h 1.08 [27.4] 1.21 [30.8] 1.60 [40.6] 2.1 [53] 0.93 [23.5] 1.43 [36.2] 1.43 [36.2] 0.93 [23.5] 1.42 [36.0] 1.30 [33.0] 0.12 [3.0] 0.06 [1.4] .12 [3.0] 0.08 [2.2] 2.33 [59.2] 2.33 [59.3] 2.33 [59.2] .87 [22.0] PANEL OPENING 1.45 [36.8] X 0.95 [24.1] PANEL OPENING 1.45 [36.8] X 0.95 [24.1] PANELTHICKNESS 0.50'' [12.7] PANEL OPENING 1.299 [33.0] X 0.866 [22.0] Part Numbers Models Voltage AC Mount 711-0013 711-0014 711-0100 711-0113 711-0114 711-0120 711-0123 711-0130 711-0131 711-0132 711-0133 711-0138 115VAC/60Hz 230VAC/60Hz 230VAC/60Hz 115VAC/60Hz 24VAC/60Hz 115VAC/60Hz 230VAC/60Hz 115VAC/60Hz 230VAC/60Hz 24VAC/60Hz 115VAC/50Hz 230VAC/60Hz Round Round Flush Rect. Flush Rect. Flush Rect. Flush Rect Flush Rect. 2-Hole 2-Hole 2-Hole 2-Hole Flush Rect. Panel Cut-out 1.45 X .87 1.45 X .95 1.99 1.299 x .866 X X X X X X X X X X X X These 7 figure, AC hour meters with running indicators, offer crisp, distinctive styling for many panel applications. Available in square and round bezel, flush mount, or three-hole round panel mount. Each is light-weight, low power, and carry UL and CE approvals. Key Features • • • • 7 figure, 99999.99 Various voltage inputs Distinctive styling Synchronous Motor • Options include: ◦ Terminations ◦ Din rail ◦ VoltagesPanel cutout Applications • • • Office Equipment Test Equipment Medical Equipment Specification Figures Reset Voltages Power Mount Terminations Front Panel Temp. Range Weight Approvals 7 figures, 0.14’’ high [3.6mm], 99,999.99 hours Non-reset 24, 115, or 230VAC (+/-10%) 3 watts (AC) Panel (mounting hardware included) 1/4’’ [6.3mm] spade terminals, with removable screws, or 8’’ [203mm] wire leads IP65 -22°F to +158°F [-30°C to +70°C] 1.6 oz. [46g] UL and cUL Recognized, CE Compliant, ROHS, UKCA Dimensions 2.28’’ Dia. Flush 3 - Hole Round 1.60 [40.6] 1.55 [39.3] 1.35 [34.3] 1.35 [34.3] 1.77 [44.9] 1.77 [44.9] 2.28 [57.9] 2.93 [74.5] Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. Screws provided: 4-40 x 5/8’’ [16] Bolt hole circle: 2.44’’ [62] Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. 1.89’’ or 2.05’’ Square 1.35 [34.3] 2.05 [50.2] 0.20 [5.1] 2.20 [55.9] 1.77 [44.9] Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. (for 1.89’’ Sq. use 1.81’’ [46] Sq. cutout only) Part Numbers 711-0150 711-0152 711-0160 711-0162 711-0163 711-0164 711-0180 711-0182 711-0190 711-0192 711-0193 711-0195 115VAC/60Hz, 2.28’’ Dia., Flush mount, screw termination 230VAC/60Hz, 2.28’’ Dia., Flush mount, screw termination 115VAC/60Hz, 2.93’’ Dia., 3-hole round, screw termination 230VAC/60Hz, 2.93’’ Dia., 3-hole round, screw termination 230VAC/50Hz, 2.93’’ Dia., 3-hole round, screw termination 24VAC/60Hz, 2.93’’ Dia., 3-hole round, screw termination 115VAC/60Hz, 1.89’’ Sq., Flush mount, screw termination 24VAC/60Hz, 1.89’’ Sq., Flush mount, screw termination 115VAC/60Hz, 2.05’’ Sq., Flush mount, screw termination 24VAC/60Hz, 2.05’’ Sq., Flush mount, screw termination 115VAC/50Hz, 2.05’’ Sq., Flush mount, screw termination 24VAC/50Hz, 2.05’’ Sq., Flush mount, screw termination A rectangular style AC hour meter designed to complement existing meters in control panels. Available in 6 figure reset or 7 figure non-reset. The nonreset model incorporates a retaining clip to lock into panel, while the reset version has a metal bracket and screw. Key Features • • • Large figures 6 or 7 digits CE Compliant, ROHS • • Synchronous Motor Options include: ◦ Reset or non-reset Applications • • • Office Equipment Test Equipment Medical Equipment Specification Figures Reset Voltages Power Mount Terminations Front Panel Temp. Range Weight Approvals Options 6 figure (reset) or 7 figure (non-reset), 0.19’’ [5mm] high 9,999.99 hours. (reset version) 99,999.99 hours. (non-reset models) Push-button, or non-reset 115VAC (+/- 10%), 50 or 60 Hz. 2 watts (nominal) Panel (mounting hardware included) 19’’ [483mm] wire leads IP65 -4°F to +158°F [-20°C to +70°C] 2 oz. [57g] CE Compliant, ROHS, UKCA Voltages Dimensions Non-Reset 12 3 4 5 6 7 1.14 [29.0] 2.13 [54.0] 0.12 [3.0] 0.98 [24.9] 1.77 [45.0] Panel cutout: 1.98’’ x 0.99’’ [50.3 x 25.1] Reset 0.19 [4.8] 1 2 3 4 5 6 2.13 [54.1] 1.14 [29.0] 0.98 [24.9] 0.18 [4.4] 2.95 [74.9] Panel cutout: 1.98’’ x 0.99’’ [50.3 x 25.1] Part Numbers 711-0019 115VAC/60Hz, reset, 6 figure, 9,999.99hrs., 19” [483mm] wire leads 711-0020 115VAC/60Hz, non-reset, 7 figure, 99,999.99hrs., 19” [483mm] wire leads 711-0041 115VAC/50Hz, non-reset, 7 figure, 99,999.99hrs., 19” [483mm] wire leads 711-0144 115VAC/50Hz, reset, 6 figure, 9,999.99hrs., 19” [483mm] wire leads www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7, Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 711-series-DS.v.3.4 01/2023
711-0150 价格&库存
很抱歉,暂时无法提供与“711-0150”相匹配的价格&库存,您可以联系我们找货
  • 1+1196.931141+154.96678
  • 10+1023.5538110+132.51961
  • 25+977.2405325+126.52342
  • 50+948.4453950+122.79531
  • 100+924.11439100+119.64518
库存:5
711-0150
  • 1+663.95501
库存:19
