711-0160
711-0160
    TRUMETER
    TRUMETER - 711-0160 - ELECTROMECHANICAL HOUR METER
711-0160 数据手册
Model 711/731 Electromechanical Hour Meter Description These 7 figure, AC or DC hour meters with running indicators, offer crisp, distinctive styling for many panel applications. Available in square and round bezel, flush mount, or three-hole round panel mount. Each is light-weight, low power, and carry UL, CSA and CE approvals. Features Options • • • • • • 7 figure, 99999.99 Various voltage inputs Distinctive styling Terminations Din rail Voltages Specifications Figures: Reset: Voltages: Power: Terminations: 7 figures, 0.14’’ high [3.6mm], 99,999.99 hours Non-reset 24, 115, or 230VAC (+/-10%), 50 or 60Hz., 10-80 VDC 3 watts (AC), 1.2 watt maximum (DC) 1/4’’ [6.3mm] spade terminals, with removable screws, or 8’’ [203mm] wire leads Mounting: Temp. Range: Approvals: Panel (mounting hardware included) -22°F to +158°F [-30°C to +70°C] UL Recognized and CSA Certified (AC only), CE Approved 2 oz. [57g] Weight: Models Description Models Description 711-0150 711-0152 711-0160 711-0161 711-0162 711-0163 711-0164 711-0170 711-0171 711-0180 115VAC/60Hz, 2.28’’ Dia.,Flush mount, screw termination 230VAC/60Hz, 2.28’’ Dia.,Flush mount, screw termination 115VAC/60Hz, 2.93’’ Dia.,3-hole round, screw termination 115VAC/50Hz, 2.93’’ Dia.,3-hole round, screw termination 230VAC/60Hz, 2.93’’ Dia.,3-hole round, screw termination 230VAC/50Hz, 2.93’’ Dia.,3-hole round, screw termination 24VAC/60Hz, 2.93’’ Dia.,3-hole round, screw termination 230VAC/60Hz, 2.93’’ Dia.,3-hole round, 8’’ wire leads 115VAC/60Hz, 2.93’’ Dia.,3-hole round, 8’’ wire leads 115VAC/60Hz, 1.89’’ Sq., Flush mount, screw termination 711-0182 711-0190 711-0191 711-0192 711-0193 711-0194 711-0195 24VAC/60Hz, 1.89’’ Sq., 115VAC/60Hz, 2.05’’ Sq., 230VAC/60Hz, 2.05’’ Sq., 24VAC/60Hz, 2.05’’ Sq., 115VAC/50Hz, 2.05’’ Sq., 230VAC/50Hz, 2.05’’ Sq., 24VAC/50Hz, 2.05’’ Sq., 731-0046 10-80VDC, * Flush Flush Flush Flush Flush Flush Flush mount, mount, mount, mount, mount, mount, mount, screw screw screw screw screw screw screw termination termination termination termination termination termination termination 2.93’’ Dia.,3-hole round, screw termination Items in bold are normally in factory stock. Dimensions 2.28’’ Dia. Flush 3 - Hole Round 1.89’’ or 2.05’’ Square 1.60 [40.6] 1.55 [39.3] 1.35 [34.3] 1.35 [34.3] 2.20 [55.9] 1.35 [34.3] 0.20 [5.1] 1.77 [44.9] 2.28 [57.9] 1.77 [44.9] 2.20 [55.9] 1.77 [44.9] 2.93 [74.5] Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. Applications Medical equipment Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. Screws provided: 4-40 x 5/8’’ [16] Bolt hole circle: 2.44’’ [62] Test equipment www.redingtoncounters.com Panel cutout: 1.99’’ [50] Dia. or 1.81’’ [46] Sq. (for 1.89’’ Sq. use 1.81’’ [46] Sq. cutout only) Office equipment 69
711-0160 价格&库存
很抱歉,暂时无法提供与“711-0160”相匹配的价格&库存,您可以联系我们找货
  • 1+1195.193951+154.55516
  • 10+1022.0707710+132.16793
  • 25+975.8238525+126.18756
  • 50+947.0703750+122.46934
  • 100+922.77479100+119.32758
库存:5
711-0160
  • 1+693.32203
库存:45
