732-0002
732-0002
    TRUMETER
    TRUMETER - 732-0002 - Panel Mount Timer, 10 VDC, 80 VDC, 0 s, 99999.9 h, 24.1 mm, 36.8 mm
732-0002 数据手册
732 Series Electromechanical Hour Meter EVALUATION KIT AVAILABLE Contact us to request yours Available with stainless steel bezel The Model 732 provides a DC Hour Meter with an operating range of 10-80VDC. Models are protected for 2 times battery voltage and/or reverse polarity. Models are available in the standard industry housings, 3-Hole Round, Flush-Rectangular, Flush-Round and 2-Hole Rectangular. A Stirrup and Cup mount are available for applications where high shock and vibration exist. Its quartz time base insures accurate long-term time keeping. The totally sealed case protects against the environment and provides years of reliable service. Most models are IP66 and NEMA 4X, 12 rated when mounted with optional gasket. Key Features • • • • • Operating voltage 10-80VDC Totally Sealed UL/cUL Recognized, CE, UKCA & RoHS Compliant 6 Figure, 99999.9 Quartz accuracy • Options include: ◦ Wire leads ◦ Gasket kit (for IP66 and NEMA 4X, 12 rating) ◦ Custom lens ◦ Terminals up, down, straight • • Construction Equipment Utility Vehicles Applications • • • Material Handling Farming Equipment Outdoor Power Equipment Specification Figures 6 - digits, 0.14” [3.6mm] 99999.9 Hours and indicator - white on black Decimal - black on white Non-reset 10-80VDC 1 watt max. Clip, mounting holes, Cup, or Stirrup 1/4” [6.3mm] spade terminals ~2 oz [57 g] ± 0.02% over entire range Stirrup and Cup mount have metallic bezels Black polymer Cup & Stirrup - glass All other models - polymer ± 6 times normal for 300msec UL/cUL Recognized, CE, UKCA, SAE, & RoHS Compliant. All models are IP66 and NEMA 4X, 12 Compliant except the Cup and Stirrup mount Protected for 2 times battery voltage and/or reverse polarity Totally Sealed IP66 and NEMA 4X, 12 rated with optional gasket -40°F to +185°F [-40°C to + 85°C] 95% (SAE J1378) 10-80 Hz. 20g max. (SAE J1378) 55g @ 9 - 13msec (SAE J1378) Reset Voltage Power Mount Terminations Weight Accuracy Bezel Case Material Lens Material Transient Protection Approvals Overvoltage & Reverse Polarity Environmental Front Panel Temp. Range Humidity Vibration Shock Industry standard quartz timing: The 732 series hour meter uses a quartz crystal oscillator that generates an impulse every 36 seconds or 0.01 of an hour. Dimensions 2-Hole Flush-Rectangular .7 [18] .7 [18] 25° REF 25° REF 1.89 [48.0] MAX 2.05 [52.1] 2.19 [55.6] MAX 1.89 [48.0] MAX .10 [2.5] 1.60 [40.6] 1.47 [37.4] 2.19 [55.6] MAX .10 [2.5] .88 [22.4] .88 [22.4] 2X Ø.126 [Ø3.2] 1.08 [27.4] 1.03 [26.2] 1/10 .93 [23.5] .93 [23.5] 1/10 .15 [3.8] 1.75 [44.5] 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Recommended cut out hole size: 0.15 [3.8mm] 1.43 [36.3] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Maximum Panel Thickness: 0.03 to 0.63 [0.76 to 16.00] 1.03 [26.2] 1/10 .93 [23.5] .93 [23.5] 1/10 .15 [3.8] 1.43 [36.3] 1.43 [36.3] 1.75 [44.5] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Recommended cut out hole size: 0.15 [3.8mm] Panel Opening: 1.45” X 0.95” [36.8 X 24.1] Maximum Panel Thickness: 0.03 to 0.63 [0.76 to 16.00] Flush-Round 3-Hole Round .7 [18] .7 [18] 25° REF 25° REF 1.87 [47.5] MAX .11 [2.8] 2.17 [55.1] MAX 1.87 [47.5] MAX FOAM GASKET Ø.16 [Ø4.0] Ø.13 [Ø3.2] .10 [2.5] Ø1.98 [Ø50.3] Ø2.24 [Ø56.9] 2.17 [55.1] MAX .09 [2.3] .21 [5.3] Ø2.80 [Ø71.1] Ø1.95 [Ø49.4] Ø1.98 [Ø50.3] Ø1.82 [Ø46.2] .93 [23.5] .93 [23.5] 1/10 1/10 Ø2.53 [Ø64.3] 1.43 [36.3] Ø2.42 [Ø61.5] 1.43 [36.3] Panel Opening: 2.0” [50.6] Maximum Panel Thickness: 0.40 [10.2] Panel Opening: 2.0” [50.6] Cup Stirrup .3 [8] .7 [18] Ø2.25 [Ø57.2] Ø2.25 [Ø57.2] .3 [8] Ø1.95 [Ø49.5] Ø1.98 [Ø50.3] 2.89 [73.4] 1.88 [47.8] MAX 1.88 [47.8] MAX .30 [7.6] Ø2.5 [Ø64] .7 [18] .12 [3.0] Ø2.5 [Ø64] .12 [3.0] 2X #8-32UNF .30 [7.6] METALLIC RING 1.53 [38.9] 3/8-16UNC 1/10 15° REF ~ ~ 1/10 15° REF Ø2.2 [Ø56] METALLIC RING GLASS LENS NOTE: SUPPLIED WITH MOUNTING HARDWARE Panel Opening: 2.0” [50.6] Ø2.2 [Ø56] GLASS LENS NOTE: SUPPLIED WITH MOUNTING HARDWARE Panel Opening: 2.0” [50.6] Part Numbers 732-0001 3-Hole Round, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0002 Flush-Rectangular, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0003 Flush-Round, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0004 2-Hole Rectangular, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0013 Panel mt, Round, Cup, stainless steel bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0014 Panel mt, Round, Cup, black bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0023 Panel mt, Round, Stirrup, stainless steel bezel, 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 732-0030 Square 1.9” (48mm), 10-80VDC, ¼” [6.3mm] spade terminals, hours & 1/10’s 5003-008 IP66 and NEMA 4X, 12 Gasket for Models 732-0003, 732-0013 & 732-0023 5003-009 IP66 and NEMA 4X, 12 Gasket for Model 732-0002 5003-010 IP66 and NEMA 4X, 12 Gasket for Model 732-0004 5003-011 IP66 and NEMA 4X, 12 Gasket for Model 732-0001 732-0004-EVAL 732 Evaluation Kit www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 732-series-DS.v.3.4 05/2023
732-0002 价格&库存
很抱歉,暂时无法提供与“732-0002”相匹配的价格&库存,您可以联系我们找货
  • 1+275.55013
库存:51
