2600-132FA
2600-132FA
    TRUMETER
    TRUMETER - 2600-132FA - MECH LENGTH MEASURING UNIT, FEET/INCH
2600-132FA 数据手册
2600 Series Cable, Wire and Rope Measuring Machine Heavy duty, multi-purpose measuring machine which measures the length of cable, wire, rope, hose, extrusions or continuous strip from 6mm (0.24in) to 76mm (3.0in) diameter. The pivot arm, also available separately (2620), carries the 500mm circumference precision ground measuring wheel. The shaft that supports the measuring wheel revolves in a double ball race which is mounted in the pivot arm. A choice of polyurethane covered or knurled aluminium measuring wheels is available. The length is indicated on a 3602 counter mounted at the side of the unit. Key Features • Measures up to 76mm (3.0in) diameter • Heavy duty cast aluminum structure with integral mounting flanges • Totalising counter fitted • Optional encoder option to pulse electronic counters • Manual lever reset Specification Cable Diameter Range 6mm (0.24in) to 76mm (2.99in) Measuring Wheel 500mm Circumference Maximum Speed of Travel 1500 metres/min or 3000 counts/ min whichever is lower Units of Measurement Available Metres and centimetres, yards and eighths, or feet and inches Accuracy +/- 1% Counter Type 3602 Packed Dimensions 530mm (21in) x 330mm (13in) x 330mm (13in) Gross Weight 13.0kg (28.7lb) Dimensions 150mm 260mm 280mm 180mm 123456 11mm 350mm 466 mm Length Measuring Ordering Information To order a 2600 1. Select the wheel surface type 2. Select the wheel type 3. Select the unit of measurement 4. Select the direction of travel 2600 - Multi-purpose Measuring Machine Wheel type (Select and add code to 2600-???) 132 for polyurethane covered wheel and mechanical display 332 for knurled aluminium wheel and mechanical display Unit of measurement (Select and add code to 2600-XXX?) C Metres/Centimetres F Feet and Inches Material travel and counter position (Select and add code to 2600-XXXX?) A for material travelling towards the operator; counter on his left B for material travelling away from the operator; counter on his left C for material travelling away from the operator; counter on his right D for material travelling towards the operator; counter on his right e.g. 2600-132CA = Poly wheel displaying in metres/centimetres, material travelling towards the operator with the counter on his left. www.trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7, Coconut Creek, Florida, FL 33073 USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 2600-DS.v.3.0 03/2020
2600-132FA 价格&库存
很抱歉,暂时无法提供与“2600-132FA”相匹配的价格&库存,您可以联系我们找货
2600-132FA
    • 1+25277.720201+3283.44760
