3410-1000
3410-1000
    TRUMETER
    TRUMETER - 3410-1000 - LCD HOUR METER
3410-1000 数据手册
Model 3410 Electronic LCD Hour Meter The Model 3410 LCD Hour Meter provides a large display with 0.28” [7mm] high characters, in industry size housings. They are available in 5 different housings. All models are NEMA 4/4X, 12 & IP66 rated when used with the optional gasket and have a polarized lens which assures high visibility in an outdoor environment. Maintenance Meters are offered with an optional maximum of 3 preset “Redi-Alerts” icons to alert user when service intervals are due or other periodic timed events are due. Models are available with front panel field or factory programmable alerts. Not only does the display flash to get attention, but it displays a choice of 7 different .08 [2mm] maintenance icons. Users can program or specify the count/service interval and flash duration for each Redi-Alert, Flash duration is the amount of time in hours that the specific icon flashes before and after the specified total count. If a front panel manual reset of the Redi-Alert is required, the front panel models with switches must be specified. Key Features Options • • • • • • • • • • • • Totally sealed from moisture and dirt AC or DC voltage input in the same unit Compact depth Fits in existing panel openings Always-on display 15+ Year Battery Life A choice of 5 housings A choice of reset modes Optional front panel programmable Preset Timer Can be programmed with starting time Up to 3 Redi-Alerts/7 icons Go to www.trumeter.com for further information Specifications Display LCD with large 0.28” [7mm] high figures black on light background Run Indicator Blinking decimal point Reset Remote, manual & non-reset (remote reset not avialble on surface mounting housing) Hour Meter Resolution 0.01 or 0.1 Hour, displayed; 1 second, internal Accuracy ± 0.1% @ room temperature ± 0.2% over the specified temperature range Records & Displays 9999999.9 - hours & 1/10’s or 9999999.9 - hours & 1/100’s Inputs 10-300VDC and 20-300VAC - 50/60Hz
3410-1000 价格&库存
很抱歉,暂时无法提供与“3410-1000”相匹配的价格&库存,您可以联系我们找货
