APM-VOLT-APN
APM-VOLT-APN
    TRUMETER
    TRUMETER - APM-VOLT-APN - Voltmeter, APM Series, AC, DC Voltage, 0 to 528Vac / 0 to 600, 4 Digits, 1...
APM-VOLT-APN 数据手册
The Next Generation of Panel Meters Easy to Use. Easy to Read. Advanced Panel Meter (APM) Programmable dynamic backlight colour Warning flash 40 segment curved bar graph display Programmable 4 digit star-burst display Models: Voltage Frequency Current Combined digital and bar graph display Programmable scale Custom messages & annunciators 2 USB port for custom user settings alarm set points PLC 2 outputs - digital and analogue Less than 53mm deep 16  osition switch for P selecting standard configurations Full 4 digit readout for accuracy The latest innovative Advanced Panel Meter is now available from Trumeter! The Trumeter APM is the most visible, easy to use, multi-format, programmable panel meter on the market. Providing you with the highest level of accuracy and an immediate visual indication of your critical parameters. The APM has been specifically designed for engineers requiring a more effective way of monitoring and displaying data. The Trumeter APM is a cost-effective alternative to the traditional moving coil and expensive digital panel meters. Trumeter - Revolutionising the future of panel meters. Go to www.truAPM.com for further information Key Features Large multi-format display that incorporates: Visibility: • 40 segment bar graph display • Large 4 digit display • Separate Starburst display area for annunciators, custom messages and alarm information • D  ynamic backlight colour • • • • Programmable: Dimensions: Scale (offset and gain) and Range (min and max) Custom annunciators User selectable backlight color and intensity Two independent alarm set-points T  wo independent outputs (output models only) 4-20mA analogue monitor output (output models only) MEASUREMENT VOLT AMP FREQUENCY Input range (DC) 0 - 600V 0 - 5A - Max Using Shunt Input range (AC) 1000A 0 - 528V 0 - 5A Max Using CT 0 - 400Hz 1000A Accuracy 1% Display modes 1% 0.1% 57mm [2.24”] 53mm [2.09”] 72mm [2.84”] 72mm [2.84”] • • • • • • User adjustable backlight brightness and colour Large display Wide viewing angle (both horizontal and vertical) C  ustom annunciators Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554 Easy To Use Software Just plug into any USB port on your PC, run the freely available APM Configurator application and you’re off. No drivers required. Peak or RMS ENVIRONMENTAL Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C IP rating (from the front) IP65 POWER SUPPLY Nominal Input (AC or DC) 12-24 VAC/VDC DISPLAY Number of digits 4 Digit height 12mm [0.47”] Digit height of annunciator 6mm [0.23”] Number of message characters Backlight colours LCD display 4 Red, Green, White Positive or Negative OUTPUT MODELS Max voltage 24V Max current 50mA Analogue output 4-20mA CERTIFICATION UL and cUL (Pending), CE Part Numbers: (POS LCD = Positive LCD; NEG LCD = Negative LCD) Volt APM-VOLT-APN Description Amp Description Frequency APM VOLT METER, POS LCD APM-AMP-APN APM AMMETER, POS LCD APM-FREQ-APN APM FREQ METER, POS LCD Description APM-VOLT-APO APM VOLT METER, POS LCD WITH OUTPUTS APM-AMP-APO APM AMMETER, POS LCD WITH OUTPUTS APM-FREQ-APO APM FREQ METER, POS LCD WITH OUTPUTS APM-VOLT-ANN APM VOLT METER, NEG LCD APM-AMP-ANN APM AMMETER, NEG LCD APM-FREQ-ANN APM FREQ METER, NEG LCD APM-VOLT-ANO APM VOLT METER, NEG LCD WITH OUTPUTS APM-AMP-ANO APM AMMETER, NEG LCD WITH OUTPUTS APM-FREQ-ANO APM FREQ METER, NEG LCD WITH OUTPUTS 022128-01 USB Cable Full specifications available online www.trumeter.com UK Office Trumeter Technologies Ltd Trumeter House Europa Business Park Bury, BL9 5BT Tel: +44 161 705 4317 Email: sales.uk@trumeter.com North America Office Trumeter Company Inc. (USA) 702 S. Military Trail Deerfield Beach, Florida FL 33442, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com www.truAPM.com Asia Pacific Distributor Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: info@idtworld.com
APM-VOLT-APN 价格&库存
很抱歉,暂时无法提供与“APM-VOLT-APN”相匹配的价格&库存,您可以联系我们找货
