APM-CT-ANO
APM-CT-ANO
    TRUMETER
    TRUMETER - APM-CT-ANO - CT METER, NEGATIVE LCD W/ O/P, 12-24VDC
APM-CT-ANO 数据手册
AC Current Measurement When Using Current Transformers EVALUATION KIT AVAILABLE Contact us to request yours TH W A E YE High resolution 5A Input for use with current transformers 0.5 % Accuracy 40 Programmable backlight color to alert user AR Easy to Use. Easy to Read. RE TY CT Meter RRAN Warning flash Segment curved bar graph display Programmable scale Programmable 4 digit star-burst display. Custom messages & annunciators Combined digital and bar graph display 10 *NEW* 20 point non-linearization scaling NEW 10 alarm set points PLC USB port for custom user settings via the free easy-to-use software 16 2 outputs: Digital (open collector) or Analog (4-20mA) *NEW* Digital Output Delays  osition switch for P selecting standard configurations Available in either Less than 53mm deep POSITIVE NEGATIVE Full 4 digit readout for accuracy Featuring an acclaimed easy-to-read display, combined with easy-to-use programming software and a high resolution input, the CT Meter is designed specifically for use with current transformers. Accurately measuring up to 10,000 amps when used with an external current transformer, the CT Meter’s unique display includes three-color dynamic backlighting and programmable scale, now with 10 alarm set-points, linear and non-linear scaling and delayed alarm activation. The customizable four-character message display and scalability enable users to tailor the meter to display critical parameters to their desired specifications. The set-points, coupled with the backlighting allows operators to be visually alerted when a parameter is out of range. The two outputs can be used to connect the APM to other systems in the process. Go to www.trumeter.com/apm for further information Key Features Unique Display Visibility • 40 segment bar graph display • User-adjustable backlight brightness and colour • Large 4-digit display • Large display • S  eparate Starburst display area for annunciators, custom messages and alarm information • Wide viewing angle (horizontal and vertical) • D  ynamic backlight color Programmable • Custom annunciators Dimensions: • Scale (offset, gain and linear) and Range (min and max) 57mm [2.24”] 53mm [2.09”] 72mm [2.84”] 72mm [2.84”] • User selectable backlight color and intensity • *NEW* 20 point non-linearization scaling for non-linear sensors e.g. thermocouples and pressure transducers • *NEW* Ten independent alarm set-points • * NEW* Configurable digital output delays (control the time output stays open/closed - .5 seconds – 120 seconds) INPUT Easy To Use Software CURRENT Range (CT Output Current) Range (via External CT) 0 - 5A Just plug into any USB port on your PC, run the freely available APM Configurator application and you’re off. No drivers required. 0 - 10,000A Accuracy 0.5% ENVIRONMENTAL Temperature - operating -10 to +60°C Temperature - storage -40 to +70°C IP rating (from the front) Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554 IP65 NEMA rating (from the front) Type 4 & Type 12 (UL50) POWER SUPPLY Nominal Input 12-24VAC or DC DISPLAY Number of digits 4 Digit height 12mm [0.47”] Number of message characters Backlight colours 4 Red, Green, White LCD display Positive or Negative OUTPUTS Max voltage 34V Max current 500mA Analogue output 4-20mA CERTIFICATION UL, cUL, CE, UKCA Open-type Measuring and Testing Equipment E469787 Part Numbers: BY REQUEST: Modbus Connectivity APM-CT-APO APM CT Meter, Positive LCD, With Outputs APM-CT-APS APM CT Meter, Positive LCD with Modbus APM-CT-ANO APM CT Meter, Negative LCD, With Outputs APM-CT-ANS APM CT Meter, Negative LCD with Modbus 022128-01 USB Cable 022150-01 APM Evaluation Kit Full specifications available online www.trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7 Coconut Creek, Florida FL 33073, USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com www.trumeter.com/apm Trumeter (Europe) Trumeter Pilot Mill, Alfred Street Bury, Lancashire BL9 9JR Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com CT-APM-US-DS.v.5.5 01/2023
APM-CT-ANO 价格&库存
很抱歉,暂时无法提供与“APM-CT-ANO”相匹配的价格&库存,您可以联系我们找货
APM-CT-ANO
  • 1+1230.81140
  • 5+1200.04893
  • 10+1168.43252
库存:22
APM-CT-ANO
  • 1+842.529581+109.50830
  • 3+786.366743+102.20850
库存:1
