Process Meter
with trurange™ technology
Easy to Use. Easy to Read.
Programmable dynamic
backlight color
0 to +/- 10V / 4-20mA / 10-50mA
Warning
flash
User selectable Voltage & Current
40
0.1
Accuracy
segment curved
bar graph display
Programmable
scale
Programmable 4 digit
star-burst display
Custom messages
& annunciators
2
Combined digital and
bar graph display
USB port for
custom user
settings
alarm set points
Full 4 digit readout for accuracy
Less
than
53mm
deep
user configurable
linearization
2 outputs - digital and
analog
INPUT
Featuring an acclaimed easy-to-read display and a versatile set of inputs, the Process Meter takes the APM into a
wide range of new industrial applications.
The programmable scale and custom annunciators mean users can tailor the meter to display their critical parameters exactly
how they want, while the dynamic backlighting, in conjunction with setpoints, means operators are visually alerted when a
parameter is out of range. The two outputs can be used to control other systems in the process, meaning the APM Process
Meter is much more than just a display.
trurange™ technology brings a greater level of accuracy to the APM range through innovative input signal optimization. By using
this technology, accuracy of 0.1% or better is now achieved, allowing for more precise measurement, display and control.
Non-linear sensors, such as thermocouples and pressure transducers, can also be used thanks to the new APM Configurator
application that allows the user to configure upto 20 points in a non-linear conversion table.
Go to www.truAPM.com for further information
Key Features
Large multi-format display that incorporates:
Visibility:
• 40 segment bar graph display
• Large 4-digit display
• Separate Starburst display area for annunciators,
custom messages and alarm information
• D
ynamic backlight color
Programmable:
Dimensions:
Display Range (Both Min & Max Values)
Custom annunciators
User-selectable backlight color and intensity
Two independent alarm set-points
T
wo independent outputs
4-20mA analog retransmission output
INPUT
VOLTAGE
CURRENT
Range (DC)
0 to +/-10VDC
0 - 50mA
Impedance
100KΩ
15Ω
0.1% of input or 5mV
whichever is greater
0.01% of input or 5uA
Accuracy
ENVIRONMENTAL
Temperature - operating
-10 to +60°C
Temperature - storage
-40 to +70°C
IP rating (from the front)
57mm [2.24”]
53mm [2.09”]
72mm [2.84”]
72mm [2.84”]
User-adjustable backlight brightness and color
Large display
Wide viewing angle (horizontal and vertical)
C
ustom annunciators
Panel cutout: 68mm x 68mm [2.68” x 2.68”] as per DIN43700/IEC61554
Easy To Use Software
Just plug into any USB port on your PC, run the
freely available APM Configurator application
and you’re off. No drivers required.
IP65
POWER SUPPLY
Nominal Input (AC or DC)
12-24 VAC/VDC
Max Power
1.6W
DISPLAY
Number of digits
4
Digit height
12mm [0.47”]
Number of message characters
4
Message character height
6mm [0.236”]
Backlight colors
Red, Green, White
LCD display
Positive or Negative
OUTPUTS
Max voltage
24V
Max current
50mA
Analog output
4-20mA
CERTIFICATION
UL and cUL (Pending), CE
Part Numbers:
APM-PROC-APO
APM-PROC-ANO
022128-01
APM Process Meter, Positive LCD with outputs
APM Process Meter, Negative LCD with outputs
USB Cable
Full specifications available online
www.trumeter.com
Trumeter (Europe)
Trumeter House
Europa Business Park
Bury,
BL9 5BT
Tel: +44 161 705 4317
Email: sales.uk@trumeter.com
Trumeter (The Americas)
702 S. Military Trail
Deerfield Beach, Florida
FL 33442,
USA
Tel: +1 954 725 6699
Email: sales.usa@trumeter.com
www.truAPM.com
Innovative Design Technologies Sdn. Bhd
Lot 5881, Lorong Iks Bukit Minyak 1
Taman Perindustrian Iks, 14000 Bukit Tengah
Penang, Malaysia
Web: www.idtworld.com
Tel: + 604 5015700
Email: sales.my@idtworld.com
Fluid Level Application
The APM Process Meter is used to display the volume of fluid in
the tank. The 4-20mA analog output from the fluid level sensor
is scaled to gallons, and the custom annunciator set to “Gal”,
all via the easy-to-use software application.
High and low setpoints are configured so that the normal green display
will flash red when the tank is too full or empty, thereby alerting the
operator. Additionally the APM digital outputs are integrated into the
tank pumping system and the tank is automatically drained or filled if the
setpoints are exceeded.
Tank
Red flashing
backlight at
high setpoint
Red backlight at
low set point
Fluid level sensor
4-20 mA
Silo Volume Application
display the volume of material in the
silo, using the analog output from a
level sensor.
The signal from the sensor is scaled
to measure cubic meters, and the
annunciator customised to m3, all via
the easy-to-use software. Due to the
irregular shape of the silo, the 20-point
linearization table is used to correct the
non-linear signal from the sensor.
Silo
The displayed value accurately shows
the volume in the silo. High or low
setpoints can be set, and the APM
can be integrated into other systems
for process control.
Level sensor
4-20 mA
INPUT
Due to the irregular
shape of the grain silo
www.trumeter.com
Trumeter (Europe)
Trumeter House
Bury,
BL9 5BT
FL 33442,
USA
www.truAPM.com
Penang, Malaysia
Tel: + 604 5015700
很抱歉,暂时无法提供与“APM-PROC-APO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1175.750811+152.84380
- 3+1095.344963+142.39130
