720-6300
720-6300
    TRUMETER
    TRUMETER - 720-6300 - DIGITAL HOUR METER
720-6300 数据手册
720-6300 Series Electronic LCD Hour Meter The Model 720 Electronic Hour Meter offers a large 8 digit LCD display, (9999999.9) 0.32” (8mm) high, with an input operating voltage of 85-500VAC. The front of the unit is totally sealed, and the Hour Meter is housed in a rugged steel enclosure that is interchangeable with the Redington Model 720 Electro Mechanical Hour Meters. The wide operating voltage makes this product ideal for almost any application. Key Features • • • • • Operating voltage 85-500VAC Rugged steel housing Lithium battery Quartz accuracy (better than 0.01%) Popular 3-hole mounting Applications • • • • • Test Equipment Control Panels Outdoor Lighting Compressors Industrial Equipment • Options include: ◦ Gasket (721-0004) Specifications Display: Large 8 digit LCD (999999.9), 0.32” [8mm] high Reset: Non-reset Voltage: 85-500VAC 50/60Hz Hour Meter Memory: Self-powered (internal lithium battery) Termination: Wire leads 6” [152mm] Mounting: Panel (3-Hole) Temp. Range: Operating: -4°F to + 140°F(-20°C to +60°C) Storage: -40°F to +165°F (-40°C to +75°C) Humidity: 0 to 95% RH, non-condensing, front totally sealed Vibration: 10 to 80 Hz, 0.06 double amplitude Shock: 50G Dielectric: 1000VAC 50/60Hz for 1 minute Accuracy: Quartz accuracy (better than 0.01%) Weight: 5.0 oz (142g) Dimensions 3X Ø.125 [Ø3.2] EQUALLY SPACED ON A 2.44[62.0] B.C. Ø2.14 [54.2] 6 IN. LEADS 2.37 [60.2] Ø2.66 [67.5] Panel cutout: 2.16’’ [54.9] Dia. Mounting holes: 0.125’’ [3.2] Dia. on 2.44’’ [62.0] B.C. Part Numbers 720-6300 85-500VAC, non-reset, 3-hole round, 6” (152mm) wire leads www.trumeter.com Trumeter (Europe) Pilot Mill Alfred Street Bury, BL9 9EF Tel: +44 161 674 0960 Email: sales.uk@trumeter.com Trumeter (The Americas) 6601 Lyons Rd, Suite H-7, Coconut Creek, Florida, FL 33073 USA Tel: +1 954 725 6699 Email: sales.usa@trumeter.com Innovative Design Technologies Sdn. Bhd Lot 5881, Lorong Iks Bukit Minyak 1 Taman Perindustrian Iks, 14000 Bukit Tengah Penang, Malaysia Web: www.idtworld.com Tel: + 604 5015700 Email: sales.my@idtworld.com 49-series-DS.v.3.0 12/2021
720-6300 价格&库存
很抱歉,暂时无法提供与“720-6300”相匹配的价格&库存,您可以联系我们找货
    • 1+2907.628191+377.26236
    • 10+2573.5580410+333.91703
    • 25+2484.5836025+322.37267
    库存:1
