1008AS-R22J-01
1008AS-R22J-01
    FASTRON
1008AS-R22J-01 数据手册
www.fastrongroup.com Chip Inductors for RF Applications / Medical Applications (Wire wound-open) FASTRON’s wire wound chip inductors are designed for radio frequency (RF) applications that require optimal Q on high frequency circuits. Its gold flash pad metallization provides better solderability for a higher yield in production. Additionally, their encapsulation not only protects the winding but also allows for surface mount assembly. It comes in compact sizes (from 0402 to 1812) and is available in reel packaging. Unlisted inductance values are usually available upon request. Ferrite core versions are also available for selected case sizes for applications which require higher inductances in a smaller case size. Applications Technical Data Technical Data Used in LC resonant circuits such as oscillator and signal generators, impedance matching, RF filters etc. Mobile Telecommunication: GSM, CDMA, TCDMA, cordless phones, 2 way radio Automotive Subsystems: TPMS, Keyless Entry, Anti-Theft, GPS Wireless Communication: W-LAN, WIFI, WIMAX, RFID, Bluetooth Non-magnetic versions for medical imaging applications: ASM series L – Value (Rated Inductance) ≥ 1 MHz measured with HP 4286A RF LCR meter or equivalent at frequency fL, 25°C ambient < 1 MHz measured with HP 4285A or equivalent at frequency fL, 25°C ambient Q – Factor (min) ≥ 1 MHz measured with E4991B Impedance Analyzer or equivalent at frequency fQ, 25°C ambient < 1 MHz measured with HP 4285A or equivalent at frequency fQ, 25°C ambient SRF (min) Measured with HP8753ES Network Analyzer or equivalent at 25°C ambient DCR (max) Measured at 25°C ambient Rated DC Current: Irms Max permissible current that causes a 15°C component temperature rise from 25°C ambient for AS, AQ, ASM & F Max permissible current that causes a 40°C component temperature rise from 25°C ambient for AQC & FLP Saturation Current: Isat Max permissible DC bias at 25°C ambient that causes inductivity drop 30% (typ.) related to the unloaded inductivity for FLP. Operating Temperature -40°C to +100°C (Including component self-heating): F -40°C to +125°C (Including component self-heating): FLP -40°C to +140°C (Including component self-heating): AS, AQ, ASM & AQC Surface Finishing Epoxy molded flat top for perfect pick and place assembly Pad Metallization Gold flash as top layer for AS, AQ, F & AF Silver-Palladium-Platinum for ASM & AQC Tin as top layer for FLP Wire Termination Spot welding Recommended Soldering Method Reflow Moisture Sensitivity Levels (MSL) MSL Level 1, indicating unlimited floor life at ≤ 30°C / 85% relative humidity Solderability Using lead free solder (Sn 99.9) at 260°C ± 5°C for 5 ± 0.5 seconds, min 90% solder coverage of metallization Standard: IEC 68-2-20 (Ta) Resistance to Soldering Heat Resistant to 260°C ± 5°C for 10 ± 1 seconds Standard: IEC 68-2-20 (Tb) Resistance to Solvent Resistant to isopropyl alcohol for 5 ± 0.5 minutes at 23°C ± 5°C Standard: IEC 68-2-45 Climatic Test Defined by the following standards IEC 68-2-1 for Cold test: -55°C for 96 hours IEC 68-2-2 for Dry heat test: +85°C for ferrite core and 125°C for ceramic core for 96 hours IEC 60068-2-78 for Humidity test: 40°C at RH 95% for 4 days Thermal Shock Test Temperature cycle (ceramic): -40°C to +125°C to -40°C Temperature cycle (ferrite): -40°C to +85°C to -40°C Max/Min temperature duration: 15 minutes Temperature transition duration: 5 minutes Cycles: 25 Standard: MIL-STD-202G Adhesion of Soldered Component (Shear Test) Components withstand a pushing force of 10N for 10 ± 1 seconds Standard: IEC 60068-2-21, method Ue3 Mechanical Shock Mil-Std 202 Method 213, Condition C 3 axis, 6 times, total 18 shocks 100 G, 6 ms, half-sine Vibration Mil-Std 202 Method 204 20 mins at 5G 10 Hz to 2000 Hz 12 cycles each of 3 orientations www.fastrongroup.com Chip Inductors for RF Applications / Medical Applications (Wire wound-open) 0402AS-1N0K-01 Ordering Code Example : 0402AS-1N0X-YY 0402 AS 1N0 X YY (Case Size) (Core Type) (Inductance Value) (Tolerance) (Packaging Code) Case Sizes Core Type Tolerances Packaging Code P1 D0 D d B P P0 d1 Fig.1 Packaging Specification K0 W Packaging Specification Schematic K0 - 0402, 0603, 0805, 1008, 1206, 1210, 1812 - AS, AQ, AQC, ASM (Ceramic), F (Ferrite), AF (Ceramic & Ferrite), FLP (Ferrite Low Profile) - F (1%), G (2%), A (3%), J (5%), K (10%), L (15%), M (20%) - 01, 04, 08 (Taped / Reel) T Fig.2 b Type Packaging Code D D0 d d1 B b W P P0 P1 K0 T Fig 0402 01, 08 180 1.55 60 13 11.9 9.5 8 2 4 2 0.60 - 2 0603 01, 08 180 1.55 60 13 11.4 9.0 8 4 4 2 0.98 - 2 0603 04 330 1.55 100 13 14.4 8.4 8 4 4 2 0.98 - 2 0805 01, 08 180 1.55 60 13 11.4 9.0 8 4 4 2 1.63 0.25 1 0805 04 330 1.55 100 13 14.4 8.4 8 4 4 2 1.63 0.25 1 1008 01,08 180 1.50 60 13 11.4 9.5 8 4 4 2 2.23 0.30 1 1008 04 330 1.55 100 13 14.4 8.4 8 4 4 2 1.63 0.25 1 1206 01,08 180 1.50 60 13 18.4 13.7 12 4 4 2 1.80 0.30 1 1206 04 330 1.50 100 13 18.4 12.4 12 4 4 2 1.80 0.30 1 1210 01 180 1.55 60 13 18.4 13.7 12 8 4 2 2.55 0.30 1 1210 04 330 1.55 100 13 18.4 12.4 12 8 4 2 2.55 0.30 1 1812 01 180 1.50 60 13 18.4 13.7 12 8 4 2 3.70 0.35 1 1812 04 330 1.50 100 13 18.4 12.4 12 8 4 2 3.70 0.35 1 • All dimensions in mm Revision date: 16 Aug 2022 www.fastrongroup.com FASTRON’s Component Key Characteristics AEC-Q200 AEC-Q200 Approved according to AEC-Q200 Approved according to AEC-Q200 with High Temperature Suitable for High Temperature RoHS Halogen Free Mechanical Shock Vibration Proof Part is RoHS conform and Halogen free Mechanical Shock and Vibration Proof Designed for High Q-values High Q Values Exceptionally High Q Values Exceptionally High Q-values Optimized for High Currents High Current Optimized for High Voltages High Voltage www.fastrongroup.com 125 °C 1008 AS AEC-Q200 RoHS Halogen Free Mechanical Shock Vibration Proof High Q Values Engineer’s Kit: EK-1008AS-X 2.80 max 2.5 2.10 max 2.47 1.45 1.0 1.3 Epoxy flat top 0.51 2.03 Typical Ls vs Frequency (ƒ) 560 nH 180 nH 100 nH 100 33 nH 10 nH 10 1 1 100 10 100 1000 10000 Frequency (MHz) Typical Q vs Frequency (ƒ) 100 nH 80 33 nH 60 560 nH 40 20 0 Impedance (KΩ) 100 1 10 100 Frequency (MHz) 1000 Typical IZI vs Frequency (ƒ) 10 nH 1 µH 10 1 0.1 0.1 µH 0.01 0.1 1 10 100 Frequency (MHz) 1000 Core Material: Ceramic SPQ: Taped / Reel 1000 [-08] 2000 [-01] 7500 [-04] Remarks: - Unlisted inductance values available upon request. - 2% and 5% tolerance available upon request. L (nH) 1008AS-4N7J-YY 1008AS-8N2J-YY 1008AS-010J-YY 1008AS-012J-YY 1008AS-015J-YY 1008AS-018J-YY 1008AS-022J-YY 1008AS-027J-YY 1008AS-030J-YY 1008AS-033J-YY 1008AS-039J-YY 1008AS-047J-YY 1008AS-056J-YY 1008AS-068J-YY 1008AS-082J-YY 1008AS-090J-YY 1008AS-R10J-YY 1008AS-R12J-YY 1008AS-R15J-YY 1008AS-R18J-YY 1008AS-R22J-YY 1008AS-R24J-YY 1008AS-R27J-YY 1008AS-R30J-YY 1008AS-R33J-YY 1008AS-R39J-YY 1008AS-R47J-YY 1008AS-R51J-YY 1008AS-R56J-YY 1008AS-R62J-YY 1008AS-R68J-YY 1008AS-R75J-YY 1008AS-R82J-YY 1008AS-R91K-YY 1008AS-1R0K-YY 1008AS-1R1K-YY 1008AS-1R2K-YY 1008AS-1R4K-YY 1008AS-1R5K-YY 1008AS-1R8K-YY 1008AS-2R2K-YY 1008AS-2R7K-YY 1008AS-3R3K-YY 1008AS-3R9K-YY 1008AS-4R7K-YY 1008AS-5R0K-YY 1008AS-5R6K-YY 1008AS-6R8K-YY 1008AS-8R2K-YY 1008AS-100K-YY 1008AS-120K-YY 4.7 8.2 10 12 15 18 22 27 30 33 39 47 56 68 82 90 100 120 150 180 220 240 270 300 330 390 470 510 560 620 680 750 820 910 1000 1100 1200 1400 1500 1800 2200 2700 3300 3900 4700 5000 5600 6800 8200 10000 12000 fL Tol (MHz) ± (%) 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 1.0 Recommended layout for solder pads 1.20 Ref 0.23 ~ 0.50 Inductance Part No Single layer (typ) Inductance (nH) 1000 Q Factor Chip Inductors for RF Applications (Wire wound - open) 2.90 max 0.51 (MHz) DCR max (Ω) Rated DC Current (mA) 6000 min 5000 min 4100 min 3300 min 2500 min 2500 min 2400 min 1600 min 1600 min 1600 min 1500 min 1500 min 1300 min 1300 min 1000 min 1000 min 1000 min 950 min 850 min 750 min 700 min 600 min 600 min 600 min 570 min 500 min 450 min 415 min 415 min 375 min 375 min 360 min 350 min 320 typ 290 typ 250 typ 250 typ 200 typ 200 typ 160 typ 160 typ 140 typ 110 typ 100 typ 65 typ 60 typ 55 typ 48 typ 44 typ 40 typ 30 typ 0.15 0.08 0.08 0.09 0.10 0.11 0.12 0.13 0.14 0.14 0.15 0.16 0.18 0.20 0.22 0.56 0.56 0.63 0.70 0.77 0.84 0.84 0.91 0.91 1.05 1.12 1.19 1.33 1.33 1.40 1.47 1.54 1.61 1.68 1.75 1.85 2.00 2.30 2.30 2.60 2.80 4.80 5.10 5.40 6.00 6.60 6.50 7.50 8.40 8.40 11.5 600 600 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 650 650 650 620 620 620 600 500 500 470 470 470 400 400 400 400 400 400 380 370 350 310 330 330 300 280 120 120 110 110 110 110 110 110 110 136 Q fQ SRF min (MHz) 17 70 50 53 70 50 55 58 65 65 60 65 65 67 63 60 63 60 50 45 46 46 48 45 51 47 54 51 56 49 46 46 52 37 36 35 35 33 35 34 28 23 22 27 20 20 22 22 24 20 20 500 1000 500 500 500 350 350 350 350 350 350 350 350 350 350 350 350 350 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 50 50 50 50 50 50 50 50 25 25 25 25 25 7.9 7.9 7.9 7.9 7.9 Revision date: 11 Jan 2022 • All dimensions in mm
1008AS-R22J-01 价格&库存
很抱歉,暂时无法提供与“1008AS-R22J-01”相匹配的价格&库存,您可以联系我们找货
