11PHC-473K-50
11PHC-473K-50
    FASTRON
11PHC-473K-50 数据手册
www.fastrongroup.com 11 PHC RoHS Halogen Free Mechanical Shock Vibration Proof High Current With Tube For High Currents Ø 0.7 Typical |Z| vs Frequency (ƒ) 1000 10 mH 100 0.1 mH 0.01 mH 10 1 0.1 0.001 0.01 0.1 1 10 Frequency (MHz) 100 Typical Ls vs Frequency (ƒ) 100 10 mH Inductance (mH) 10 1.0 mH 1 0.1 mH 0.1 0.01 mH 0.01 0.001 0.01 0.1 Inductance fL Tol L (mH) (MHz) ± (%) DCR max (Ω) 0.01 0.10 0.22 0.33 0.47 0.56 0.70 0.76 1.00 1.50 1.60 2.20 2.70 3.30 10 12 15 18 22 27 33 37 39 47 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 0.03 0.16 0.37 0.53 0.76 0.83 1.27 1.35 1.60 2.33 2.50 3.70 4.14 5.51 15.78 21.85 28.75 32.20 43 47 77 82 84 97 Part No 1.0 mH 0.01 1 10 Frequency (MHz) 100 11PHC-100K-YY 11PHC-101K-YY 11PHC-221K-YY 11PHC-331K-YY 11PHC-471K-YY 11PHC-561K-YY 11PHC-701K-YY 11PHC-761K-YY 11PHC-102K-YY 11PHC-152K-YY 11PHC-162K-YY 11PHC-222K-YY 11PHC-272K-YY 11PHC-332K-YY 11PHC-103K-YY 11PHC-123K-YY 11PHC-153K-YY 11PHC-183K-YY 11PHC-223K-YY 11PHC-273K-YY 11PHC-333K-YY 11PHC-373K-YY 11PHC-393K-YY 11PHC-473K-YY Core Material: Ferrite Rated DC Current (A) Isat Imax 6.66 2.47 1.68 1.42 1.17 1.10 0.96 0.96 0.85 0.50 0.70 0.50 0.47 0.42 0.26 0.23 0.19 0.20 0.16 0.14 0.12 0.11 0.12 0.09 4.07 1.84 1.00 0.97 0.72 0.74 0.56 0.54 0.53 0.60 0.50 0.34 0.33 0.27 0.15 0.13 0.12 0.12 0.10 0.10 0.08 0.08 0.08 0.07 Revision date: 29 Aug 2022 Typical Ls vs Current (I) 100 Inductance (mH) Pluggable Inductors C1 10 25 Packaging Loose / Box [-50] Taped / Reel [-51] C1 5.0 Impedance (kΩ) (Pin Type Coils) 15.0 max Ø 10.5 max 10 SPQ: 10 mH 1 0.1 mH 0.01 mH 0.01 0.001 0.1 1 10 Loose / Box 250 [-50] Taped / Reel 500 [-51] Remarks: - Unlisted inductance values available upon request. - 5% tolerance available upon request. - Also available without tube. - Also available with shorter leads. 1.0 mH 0.1 Packaging Form Radial 100 Current (A) • Bold figure for Tol% is standard • All dimensions in mm
11PHC-473K-50
物料型号:11PHC系列,例如11PHC-100K-YY、11PHC-101K-YY等。
器件简介:这些电感器适用于高电流应用,具有管状结构,最大外径为10.5mm,最大高度为15.0mm,引脚直径为0.7mm。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电感器会有两端引脚用于连接。
参数特性:文档列出了不同型号电感器的电感值、频率、公差、最大直流电阻(DCR)、额定直流电流、饱和电流(Isat)和最大电流(Imax)。
功能详解:文档提供了典型阻抗(|Z|)与频率的关系图和典型电感(Ls)与频率及电流的关系图,展示了电感器的性能特性。
应用信息:文档未明确提供应用信息,但根据电感器的高电流设计,它们可能适用于电源管理、电机驱动等应用。
封装信息:提供了两种封装形式的包装数量,分别是散装/盒装和带卷包装。
11PHC-473K-50 价格&库存
很抱歉,暂时无法提供与“11PHC-473K-50”相匹配的价格&库存,您可以联系我们找货
