1812CMF-110X-01
1812CMF-110X-01
    FASTRON
    Common Mode Chokes Dual 11uH 600Ohm 100kHz 0.25A 0.5Ohm DCR SMD T/R
1812CMF-110X-01 数据手册
www.fastrongroup.com 130 °C 1812 CMF AEC-Q200 RoHS Halogen Free Mechanical Shock Vibration Proof Common Mode Filter CAN bus 3.40 max Flat top H max 0.7 5.9 4.70 max 0.70 0.70 1 0.80 0.80 3.2 1812CMF-110X Typical |Ζ| vs Frequency (ƒ) Impedance (Ω) 2 110X Common mode 3.5 1000 1.5 100 3 10 0.80 0.80 4 Recommended layout for solder pads 110X Differential mode 1 0 1 10 100 1000 Frequency (MHz) Schematic 10000 1 2 3 4 1812CMF-220X Typical |Ζ| vs Frequency (ƒ) 10000 Impedance (Ω) 220X Common mode 1000 No polarity 100 Impedance fΖ Inductance Tol |Z| (Ω) min typ (MHz) L (µH) ± (%) 10 220X Differential mode Part No 1 1 10 100 1000 Frequency (MHz) 10000 1812CMF-510X Typical |Ζ| vs Frequency (ƒ) Impedance (Ω) 100000 1812CMF-110X-YY 1812CMF-220X-YY 1812CMF-510X-YY * 1812CMF-101X-YY 10000 1000 SPQ: Taped / Reel 100 510X Differential mode 1 1 10 100 1000 Frequency (MHz) 300 500 1000 2000 600 1200 2800 5800 10 10 10 10 Core Material: Ferrite Top Material: Magnetically shielded 510X Common mode 10 10000 Typical |Ζ| vs Frequency (ƒ) 101X Common mode 10000 1000 100 1 101X Differential mode 1 10 100 1000 Frequency (MHz) +50/-30 +50/-30 +50/-30 +50/-30 100 100 100 100 0.05 0.08 0.15 0.20 0.5 0.7 0.9 2.0 250 200 200 150 10000 • All dimensions in mm 3.15 3.15 3.15 3.25 Revision date: 25 May 2022 Remarks: - Unlisted inductance values available upon request. - Rated Volt = 50 Vdc. - Insulation Resistance = 10 MΩ min. - * indicated approved according to IEC62228-3, Annex D and CiA 110. 100000 10 11 22 51 100 Leakage DCR Rated DC Dimension Inductance max Current H max (mA) (kHz) (µH) typ (Ω) fL 600 [-01] 2200 [-04] 1812CMF-101X Impedance (Ω) Common Mode Filter Chip Inductors 10000
1812CMF-110X-01 价格&库存
很抱歉,暂时无法提供与“1812CMF-110X-01”相匹配的价格&库存,您可以联系我们找货
