0805AQ-018J-01
0805AQ-018J-01
    FASTRON
    Inductor RF Chip Molded/Unshielded Wirewound 0.018uH 5% 250MHz 76Q-Factor Ceramic 1.4A 0.06Ohm DCR 0...
0805AQ-018J-01 数据手册
0805 AQ 125 °C www.fastrongroup.com AEC-Q200 RoHS Halogen Free Mechanical Shock Vibration Proof Exceptionally High Q Values Exceptionally High Q Engineer’s Kit: EK-0805AQ-X 1.80 max 1.80 1.60 max 2.03 2.30 max 1.17 1.0 0.8 Epoxy flat top 0.43 Typical Ls vs Frequency (ƒ) 100 80 70 56 nH 60 50 39 nH 40 27nH 30 20 12 nH 6.2 nH 10 0 1 10 100 Frequency (MHz) 1000 Typical Q vs Frequency (ƒ) 12 nH 100 6.2 nH 56 nH 27nH 80 39 nH 60 Single layer (typ) Inductance (nH) 0.23 ~ 0.50 0.80 ref Inductance fL Tol Q fQ L (nH) (MHz) ± (%) min 2.5 2.7 5.6 6.2 8.7 11 12 15 16 18 20 22 27 30 39 47 48 51 56 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 200 200 200 200 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 80 67 98 88 50 83 80 78 78 76 74 60 75 69 74 85 71 65 75 (MHz) SRF min (MHz) DCR max (Ω) Rated DC Current (mA) 1500 1500 1500 1000 1000 1000 1000 500 500 500 500 500 500 500 500 500 500 500 500 >6000 >6000 >6000 4750 5300 3000 3000 2950 2950 2550 2050 2050 2000 1950 1600 1400 1400 1400 1400 0.020 0.020 0.035 0.035 0.045 0.060 0.045 0.060 0.060 0.060 0.055 0.070 0.070 0.095 0.110 0.095 0.095 0.120 0.120 1600 1600 1600 1600 1600 1600 1600 1500 1500 1400 1400 1400 1300 1200 1100 1200 1200 1000 1000 Part No 90 0805AQ-2N5K-YY 0805AQ-2N7K-YY 0805AQ-5N6K-YY 0805AQ-6N2K-YY 0805AQ-8N7K-YY 0805AQ-011J-YY 0805AQ-012J-YY 0805AQ-015J-YY 0805AQ-016J-YY 0805AQ-018J-YY 0805AQ-020J-YY 0805AQ-022J-YY 0805AQ-027J-YY 0805AQ-030J-YY 0805AQ-039J-YY 0805AQ-047J-YY 0805AQ-048J-YY 0805AQ-051J-YY 0805AQ-056J-YY 40 Core Material: Ceramic 20 SPQ: Taped / Reel 1000 [-08] 2500 [-01] 7500 [-04] 0 1 10 100 1000 Frequency (MHz) 10000 1.0 Recommended layout for solder pads 1.27 Q Factor Chip Inductors for RF Applications (Wire wound - open) 0.43 Revision date: 11 Jan 2022 Remarks: - Unlisted inductance values available upon request. - 2% and 5% tolerance available upon request. • All dimensions in mm
0805AQ-018J-01
物料型号:0805 AQ系列,包括多个型号,如0805AQ-2N5K-YY、0805AQ-2N7K-YY等。
器件简介:这些电感器适用于射频应用,具有单层典型结构,并且是机械冲击和振动防护的。
引脚分配:文档中没有明确提供引脚分配信息,但推荐了焊盘布局。
参数特性:包括电感值、频率、公差、最小Q值、自谐频率、最大表面电阻、额定直流电流等。
功能详解:文档提供了典型电感值与频率的关系图和典型Q值与频率的关系图。
应用信息:适用于射频应用。
封装信息:封装类型未明确说明,但提到了尺寸信息,例如电感器的最大宽度和高度。
0805AQ-018J-01 价格&库存
很抱歉,暂时无法提供与“0805AQ-018J-01”相匹配的价格&库存,您可以联系我们找货
