0805ASM-039J-08
0805ASM-039J-08
    FASTRON
    0805ASM-039J-08
0805ASM-039J-08 数据手册
www.fastrongroup.com 125 °C 0805 ASM AEC-Q200 RoHS Halogen Free Non-magnetic Engineer’s Kit: EK-0805ASM-X Mechanical Shock Vibration Proof High Q Values 1.80 max 1.60 max 1.8 2.03 1.17 1.0 0.8 0.43 Epoxy flat top 1.27 680 nH Single layer (typ) Inductance (nH) 1000 150 nH 100 33 nH 8.2 nH 10 2.7 nH 1 1 10 100 1000 Frequency (MHz) 10000 Typical Q vs Frequency (ƒ) 120 2.7 nH 8.2 nH Q Factor 100 80 33 nH 150 nH 60 40 680 nH 20 0 1 10 100 1000 Frequency (MHz) 10000 Typical |Ζ| vs Frequency (ƒ) 100000 680 nH 150 nH 10000 33 nH 1000 8.2 nH 100 2.7 nH 10 1 0.1 0.01 1 10 100 1000 Frequency (MHz) 0.23 ~ 0.50 1.0 Recommended layout for solder pads 0.8 Ref Inductance fL Tol Q fQ L (nH) (MHz) ± (%) min (MHz) 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 200 200 200 200 150 150 150 100 100 100 100 100 100 100 100 100 100 100 100 100 100 50 25 25 25 7.9 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 80 50 53 50 50 51 50 43 50 50 53 57 55 60 60 60 65 64 65 55 67 65 52 53 60 50 54 59 52 52 40 40 40 40 42 40 40 37 23 23 23 15 1500 1500 1000 1000 1000 1000 1000 1000 500 500 500 500 500 500 500 500 500 500 500 500 500 500 250 250 250 250 250 250 250 250 100 100 100 100 100 100 100 75 50 50 50 7.9 SRF (MHz) DCR max (Ω) Rated DC Current (mA) 6000 min 6000 min 5500 min 5500 min 5500 min 4700 min 4700 min 4300 min 4000 min 3400 min 3300 min 2600 min 2500 min 2050 min 2050 min 2000 min 1650 min 1550 min 1450 min 1300 min 1300 min 1200 min 1100 min 920 min 920 min 870 min 850 min 850 min 850 min 850 min 820 min 795 min 795 min 790 min 750 min 720 min 650 min 450 min 215 typ 215 typ 215 typ 80 typ 0.08 0.08 0.11 0.11 0.11 0.12 0.12 0.13 0.15 0.17 0.20 0.22 0.25 0.27 0.27 0.29 0.31 0.34 0.38 0.42 0.42 0.46 0.51 0.56 0.56 0.64 0.70 0.70 0.80 0.80 1.50 1.80 1.80 1.80 2.00 2.50 3.50 3.50 2.35 2.35 2.35 3.80 600 600 600 600 600 600 600 600 600 600 500 500 500 500 600 500 500 500 400 400 400 400 400 400 400 400 400 400 400 400 280 260 260 260 200 170 170 170 180 180 180 150 Part No Typical Ls vs Frequency (ƒ) 10000 Impedance (Ω) Chip Inductors for RF / Medical Applications (Wire wound - open) 2.30 max 0.43 10000 0805ASM-2N7K-YY 2.7 0805ASM-3N3K-YY 3.3 0805ASM-5N6K-YY 5.6 0805ASM-5N8K-YY 5.8 0805ASM-6N8K-YY 6.8 0805ASM-8N0K-YY 8.0 0805ASM-8N2K-YY 8.2 0805ASM-010J-YY 10 0805ASM-012J-YY 12 0805ASM-015J-YY 15 0805ASM-018J-YY 18 0805ASM-022J-YY 22 0805ASM-027J-YY 27 0805ASM-033J-YY 33 0805ASM-036J-YY 36 0805ASM-039J-YY 39 0805ASM-047J-YY 47 0805ASM-056J-YY 56 0805ASM-068J-YY 68 0805ASM-075J-YY 75 0805ASM-082J-YY 82 0805ASM-R10J-YY 100 0805ASM-R12J-YY 120 0805ASM-R13J-YY 130 0805ASM-R15J-YY 150 0805ASM-R18J-YY 180 0805ASM-R20J-YY 200 0805ASM-R22J-YY 220 0805ASM-R24J-YY 240 0805ASM-R25J-YY 250 0805ASM-R27J-YY 270 0805ASM-R29J-YY 290 0805ASM-R30J-YY 300 0805ASM-R33J-YY 330 0805ASM-R39J-YY 390 0805ASM-R47J-YY 470 0805ASM-R56J-YY 560 0805ASM-R68J-YY 680 0805ASM-R75J-YY 750 0805ASM-R82J-YY 820 0805ASM-1R0J-YY 1000 0805ASM-2R2J-YY 2200 Core Material: Ceramic Revision date: 11 Jan 2022 SPQ: Taped / Reel 1000 [-08] 2500 [-01] 7500 [-04] Remarks: - Unlisted inductance values available upon request. - 2% and 5% tolerance available upon request. • All dimensions in mm
0805ASM-039J-08
1. 物料型号:文档列出了多种型号的0805 ASM系列的芯片电感器,例如0805ASM-2N7K-YY、0805ASM-3N3K-YY等,每个型号都有其特定的电感值、频率、公差、Q因子、自谐振频率、直流电阻、额定直流电流等参数。
2. 器件简介:文档由Fastron Group提供,专注于射频和医疗应用的芯片电感器。
3. 引脚分配:推荐了焊盘的布局设计,包括尺寸和单层典型布局。
4. 参数特性:提供了不同频率下的典型电感值、Q因子和阻抗值。
5. 功能详解:文档详细描述了电感器的电气特性,如在不同频率下的电感值变化、Q因子和阻抗。
6. 应用信息:虽然文档没有直接提到应用信息,但从电感器的参数可以推断它们适用于射频和医疗设备。
7. 封装信息:电感器的封装为0805 ASM,尺寸和形状有具体描述,如最大宽度、长度和高度。
0805ASM-039J-08 价格&库存
很抱歉,暂时无法提供与“0805ASM-039J-08”相匹配的价格&库存,您可以联系我们找货
