1008ASM-3R3K-08
1008ASM-3R3K-08
    FASTRON
    1008ASM-3R3K-08
1008ASM-3R3K-08 数据手册
www.fastrongroup.com 125 °C 1008 ASM RoHS Halogen Free AEC-Q200 Mechanical Shock Vibration Proof High Q Values Non-magnetic Engineer’s Kit : EK-1008ASM-X 2.10 max 2.80 max 2.5 2.47 2.90 max 1.45 1.0 1.3 Epoxy flat top 0.51 2.03 0.15 ~ 0.40 Typical Ls vs Frequency (ƒ) Inductance Inductance (nH) 100000 L (nH) 8200 nH 3300 nH 1000 nH 1000 100 nH 100 33 nH 10 nH 10 1 10 100 1000 10000 Frequency (MHz) Typical Q vs Frequency (ƒ) 120 10 nH 100 33 nH 80 100 nH 60 40 1000 nH 20 3300 nH 8200 nH 0 1 10 100 1000 10000 Frequency (MHz) Typical |Ζ| vs Frequency (ƒ) 1000000 3300 nH 100000 8200 nH 10000 1000 nH 100 nH 33 nH 1000 100 10 nH 10 1 0.1 1 10 100 1000 10000 Frequency (MHz) Single layer (typ) 1 Q Factor fL Tol 1.0 Recommended layout for solder pads 1.20 Ref Q fQ min (MHz) 50 53 70 50 55 50 58 65 60 65 65 67 63 63 60 50 45 46 48 51 47 54 56 49 46 46 52 37 36 35 35 34 28 23 22 27 20 22 22 24 500 500 500 350 350 350 350 350 350 350 350 350 350 350 350 100 100 100 100 100 100 100 100 100 100 100 100 100 100 50 50 50 50 25 25 25 25 7.9 7.9 7.9 (MHz) DCR max (Ω) Rated DC Current (mA) 4100 min 3300 min 2500 min 2500 min 2400 min 1600 min 1600 min 1600 min 1500 min 1500 min 1300 min 1300 min 1000 min 1000 min 950 min 850 min 750 min 700 min 600 min 570 min 500 min 450 min 415 min 375 min 375 min 360 min 350 min 320 typ 290 typ 250 typ 200 typ 160 typ 160 typ 140 typ 110 typ 100 typ 65 typ 55 typ 48 typ 44 typ 0.08 0.09 0.10 0.11 0.12 0.13 0.13 0.14 0.15 0.16 0.18 0.20 0.22 0.56 0.63 0.70 0.77 0.84 0.91 1.05 1.12 1.19 1.33 1.40 1.47 1.54 1.61 1.68 1.75 2.00 2.30 2.60 2.80 4.80 5.10 5.40 6.00 6.50 7.50 8.40 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 650 650 620 620 620 600 470 470 470 400 400 400 400 400 380 370 310 330 300 280 120 120 110 110 110 110 110 SRF Part No 10000 Impedance (Ω) Chip Inductors for RF / Medical Applications (Wire wound - open) 0.51 1008ASM-010J-YY 1008ASM-012J-YY 1008ASM-015J-YY 1008ASM-018J-YY 1008ASM-022J-YY 1008ASM-024J-YY 1008ASM-027J-YY 1008ASM-033J-YY 1008ASM-039J-YY 1008ASM-047J-YY 1008ASM-056J-YY 1008ASM-068J-YY 1008ASM-082J-YY 1008ASM-R10J-YY 1008ASM-R12J-YY 1008ASM-R15J-YY 1008ASM-R18J-YY 1008ASM-R22J-YY 1008ASM-R27J-YY 1008ASM-R33J-YY 1008ASM-R39J-YY 1008ASM-R47J-YY 1008ASM-R56J-YY 1008ASM-R62J-YY 1008ASM-R68J-YY 1008ASM-R75J-YY 1008ASM-R82J-YY 1008ASM-R91K-YY 1008ASM-1R0K-YY 1008ASM-1R2K-YY 1008ASM-1R5K-YY 1008ASM-1R8K-YY 1008ASM-2R2K-YY 1008ASM-2R7K-YY 1008ASM-3R3K-YY 1008ASM-3R9K-YY 1008ASM-4R7K-YY 1008ASM-5R6K-YY 1008ASM-6R8K-YY 1008ASM-8R2K-YY 10 12 15 18 22 24 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 620 680 750 820 910 1000 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 (MHz) ± (%) 50 50 50 50 50 50 50 50 50 50 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 10 10 10 10 10 10 10 10 10 10 10 10 10 Core Material: Ceramic SPQ: Taped / Reel 1000 [-08] 2000 [-01] 7500 [-04] Remarks: - Unlisted inductance values available upon request. - 2% and 5% tolerance available upon request. • All dimensions in mm Revision date: 11 Jan 2022
1008ASM-3R3K-08
1. 物料型号:1008 ASM系列,包括不同型号的电感器,如1008ASM-010J-YY至1008ASM-8R2K-YY等。 2. 器件简介:这是一系列用于射频/医疗应用的线绕开放式芯片电感器。 3. 引脚分配:文档中提供了推荐的焊盘布局,但未具体说明引脚分配。 4. 参数特性:列出了不同型号电感器的电感值、频率、公差、Q因子最小值、自谐振频率、最大直流电阻、额定直流电流等参数。 5. 功能详解:文档提供了典型电感值与频率的关系图、Q因子与频率的关系图以及典型阻抗与频率的关系图。 6. 应用信息:适用于射频和医疗应用。 7. 封装信息:封装材料为环氧树脂,顶部平坦,具体尺寸数据未在摘要中提及。 8. 其他信息:核心材料为陶瓷,修订日期为2022年1月11日,SPQ(标准包装量)信息以及备注,包括未列出电感值和公差值的请求信息。
1008ASM-3R3K-08 价格&库存
很抱歉,暂时无法提供与“1008ASM-3R3K-08”相匹配的价格&库存,您可以联系我们找货
