HBCC-223J-02
HBCC-223J-02
    FASTRON
HBCC-223J-02 数据手册
www.fastrongroup.com HBCC 14.5 63 1000 22 - 12.8 100000 66 Inductance (µH) 10000 Part No 1000 µH 100 µH 100 10 µH 10 1 µH 1 0.1 0.01 Ø 0.60 (Fixed Choke Coils) High Q Values Typical Ls vs Frequency (ƒ) X 1.0 - 18 Mechanical Shock Vibration Proof 0.1 1 10 Frequency (MHz) 100 Single layer (typ) A L (µH) (max) RoHS Halogen Free Typical Q vs Frequency (ƒ) 1000 1000 µH 100 Q Factor 1 µH 10 100 µH 0.1 0.01 0.1 1 10 100 Frequency (MHz) X A max 1 Inductance (µH) 10000 Ø 5.8 max Leaded Inductors 10 µH Typical Ls vs Current (I) 1000 µH 1000 100 µH 100 10 µH 10 1 µH 1 0.1 0.001 0.01 0.1 1 Current (A) 10 Core Material: Ferrite SPQ: Packaging Form Taped / Reel Axial 1200 [-01] Radial 1000 [-31] Taped / Ammo pack 600 [-02] 1800 [-32] Remarks: * This inductance does not comply to IEC standard. HBCC-1R0X-YY HBCC-1R2X-YY HBCC-1R5X-YY HBCC-1R8X-YY HBCC-2R2X-YY HBCC-2R7X-YY HBCC-3R3X-YY HBCC-3R9X-YY HBCC-4R7X-YY HBCC-5R6X-YY HBCC-6R8X-YY HBCC-8R2X-YY HBCC-100X-YY HBCC-120X-YY HBCC-150X-YY HBCC-180X-YY HBCC-220X-YY HBCC-250X-YY HBCC-270X-YY HBCC-330X-YY HBCC-390X-YY HBCC-470X-YY HBCC-560X-YY HBCC-680X-YY HBCC-820X-YY HBCC-101X-YY HBCC-121X-YY HBCC-151X-YY HBCC-181X-YY HBCC-221X-YY HBCC-271X-YY HBCC-331X-YY HBCC-391X-YY HBCC-471X-YY HBCC-561X-YY HBCC-681X-YY HBCC-821X-YY HBCC-102X-YY HBCC-122X-YY HBCC-152X-YY HBCC-182X-YY HBCC-222X-YY HBCC-272X-YY HBCC-332X-YY HBCC-392X-YY HBCC-472X-YY HBCC-502X-YY HBCC-532X-YY HBCC-682X-YY HBCC-103X-YY HBCC-153X-YY HBCC-183X-YY HBCC-223X-YY HBCC-333X-YY HBCC-363X-YY HBCC-473X-YY * HBCC-683X-YY * HBCC-104X-YY Inductance fL Tol Q L (µH) (MHz) ± (%) min SRF DCR Rated DC min max Current (A) (MHz) (MHz) (Ω) 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 25 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 3300 3900 4700 5000 5300 6800 10000 15000 18000 22000 33000 36000 47000 68000 100000 1 1 1 1 1 1 1 1 1 1 1 1 1 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 5,10 40 40 40 40 40 40 40 40 40 40 40 40 60 60 60 60 40 40 40 40 40 40 40 30 30 50 50 50 50 50 50 50 50 40 40 40 30 60 60 60 60 60 60 60 60 60 60 60 60 50 50 50 50 50 50 40 40 40 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 7.96 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 2.52 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.796 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 fQ 200 185 170 155 140 130 120 110 100 90 80 70 60 40 20 17 12 10 10 8.0 6.5 5.0 4.5 4.0 3.7 3.5 3.2 3.0 2.7 2.4 2.1 1.9 1.7 1.5 1.4 1.3 1.25 1.20 1.10 1.00 0.90 0.80 0.70 0.60 0.55 0.50 0.40 0.40 0.40 0.35 0.30 0.26 0.26 0.22 0.22 0.18 0.15 0.12 0.08 0.09 0.10 0.10 0.11 0.12 0.14 0.15 0.16 0.17 0.19 0.20 0.22 0.26 0.30 0.33 0.35 0.39 0.39 0.43 0.47 0.50 0.55 0.60 0.65 0.70 1.00 1.20 1.40 1.60 1.80 2.0 2.3 2.5 2.9 3.2 3.5 3.8 5.2 6.5 8 9 12 15 18 22 24 30 30 42 68 120 120 150 150 230 290 390 2.20 2.15 2.10 2.00 1.90 1.80 1.75 1.70 1.60 1.55 1.50 1.45 1.40 1.30 1.25 1.20 1.10 1.00 1.00 0.90 0.85 0.80 0.75 0.70 0.65 0.60 0.55 0.50 0.45 0.40 0.37 0.33 0.31 0.28 0.26 0.24 0.22 0.20 0.18 0.16 0.14 0.12 0.12 0.11 0.10 0.09 0.09 0.08 0.08 0.06 0.05 0.04 0.04 0.035 0.035 0.030 0.025 0.020 Revision date: 07 May 2020 • Bold figure for Tol% is standard • All dimensions in mm
HBCC-223J-02
1. 物料型号:文档列出了多种型号的固定电感器,如HBCC-1R0X-YY、HBCC-1R2X-YY等,每个型号都有其特定的电感值(Inductance L)。
2. 器件简介:文档提到这些固定电感器具有高Q值,通常是单层结构。
3. 引脚分配:文档没有明确提供引脚分配信息,但提到了轴向(Axial)和径向(Radial)两种封装形式。
4. 参数特性:提供了电感值、工作频率、公差、最小Q因子、自谐频率、最大直流电阻(DCR)、额定直流电流等参数。
5. 功能详解:文档通过图表展示了电感值随频率和电流变化的情况,以及Q因子随频率的变化。
6. 应用信息:虽然文档没有直接说明应用信息,但从电感器的特性来看,它们可能用于电源管理、信号过滤等应用。
7. 封装信息:文档提供了封装形式和包装方式,如轴向1200个/卷,径向1000个/卷。
8. 核心材料:电感器使用铁氧体作为核心材料。
9. 备注:文档指出这些电感器的电感值不符合IEC标准。
10. 修订日期:文档的修订日期为2020年5月7日。
HBCC-223J-02 价格&库存
很抱歉,暂时无法提供与“HBCC-223J-02”相匹配的价格&库存,您可以联系我们找货
HBCC-223J-02
  • 10+3.91441
  • 50+3.14662
  • 100+2.94299
  • 600+2.63756
