07MFG-563J-50
07MFG-563J-50
    FASTRON
07MFG-563J-50 数据手册
www.fastrongroup.com 07M RoHS Halogen Free Shielded Also available in 3.5mm pitch (07MFG) 12.5 max Ø 10 max 10000 Typical |Z| vs Frequency (ƒ) Part No 33 mH 1000 10 mH 82 mH 100 1 mH 10 1 0.1 0.01 0.01 0.1 1 Frequency (MHz) 10 Typical Ls vs Frequency (ƒ) 1000 Inductance (mH) Pluggable Inductors Ø 0.65 13.0 5.0 Impedance (kΩ) (Pin Type Coils) 3.0 100 82 mH 33 mH 10 mH 10 1 mH 1 0.1 0.01 0.1 Frequency (MHz) 1 07M-102K-50 07M-152K-50 07M-182K-50 07M-222K-50 07M-332K-50 07M-392K-50 07M-472K-50 07M-682K-50 07M-103K-50 07M-153K-50 07M-223K-50 07M-273K-50 07M-333K-50 07M-393K-50 07M-473K-50 07M-563K-50 07M-683K-50 07M-823K-50 Inductance L (mH) 1.0 1.5 1.8 2.2 3.3 3.9 4.7 6.8 10 15 22 27 33 39 47 56 68 82 fL Tol (MHz) ± (%) 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 0.02 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Core Material: Ferrite SPQ: Packaging Form Radial min DCR Rated DC max Current (MHz) (Ω) Imax (mA) 130 130 120 120 115 115 110 150 150 150 150 140 135 130 100 100 100 75 0.252 0.252 0.252 0.252 0.252 0.252 0.252 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 0.079 Q fQ 2.00 2.30 2.70 3.00 3.80 4.30 4.90 6.55 8.55 13.50 18.50 22.00 26.00 38.00 48.50 55.00 64.50 71.00 350 335 330 315 300 260 235 230 200 150 140 120 110 100 85 75 70 70 Revision date: 03 Aug 2022 Loose / Box 250 [-50] Remarks: - Also available with shorter leads. - No cleaning on 07M and 07MFG is recommended once assembled on the PCB. - Manual soldering is recommended for models 07M and 07MFG. • All dimensions in mm
07MFG-563J-50 价格&库存
很抱歉,暂时无法提供与“07MFG-563J-50”相匹配的价格&库存,您可以联系我们找货
