0805F-100K-01
0805F-100K-01
    FASTRON
0805F-100K-01 数据手册
www.fastrongroup.com 0805 F 85 °C AEC-Q200 RoHS Halogen Free Mechanical Shock Vibration Proof Engineer’s Kit: EK-0805F-X 1.80 max 1.60 max 1.80 2.00 1.0 1.06 0.8 Epoxy flat top 0.47 1.27 Typical Ls vs Frequency (ƒ) 16 Part No Inductance (µH) 14 10 μH 12 10 7.5 μH 8 6 3.3 μH 4 2.7 μH 2 0 1.0 μH 0.68 μH 1 10 100 Frequency (MHz) 1000 Typical Q vs Frequency (ƒ) 30 Q Factor Chip Inductors for RF Applications (Wire wound - open) 2.30 max 0.47 7.5 μH 2.7 μH 20 0.68 μH 3.3 μH 10 0 1 1.0 μH 10 μH 0805F-R68K-YY 0805F-R82K-YY 0805F-1R0K-YY 0805F-1R2K-YY 0805F-1R5K-YY 0805F-1R8K-YY 0805F-2R2K-YY 0805F-2R7K-YY 0805F-3R3K-YY 0805F-3R9K-YY 0805F-4R7K-YY 0805F-5R6K-YY 0805F-6R2K-YY 0805F-6R8K-YY 0805F-7R5K-YY 0805F-8R2K-YY 0805F-9R1K-YY 0805F-100K-YY 0805F-120K-YY 0805F-150K-YY 0805F-220K-YY 0.50 Inductance L (µH) 0.68 0.82 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.2 6.8 7.5 8.2 9.1 10 12 15 22 fL (MHz) ± (%) 25.2 25.2 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 Core Material: Ferrite 10 Frequency (MHz) 100 Tol 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 0.80 ref Q fQ min (MHz) 18 18 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 18 18 15 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 1.0 Recommended layout for solder pads SRF (MHz) DCR max (Ω) Rated DC Current (mA) 350 min 350 min 350 min 300 typ 250 typ 200 typ 200 typ 200 typ 200 typ 150 typ 150 typ 80 typ 70 typ 65 typ 60 typ 55 typ 50 typ 45 typ 25 typ 25 typ 30 typ 0.50 0.55 0.50 0.65 0.75 0.85 1.70 2.0 3.3 3.6 3.8 2.8 3.0 3.1 3.4 3.7 3.7 3.8 4.2 5.0 6.0 450 400 250 220 200 190 130 120 100 95 90 175 165 160 160 160 150 150 150 150 97 Revision date: 11 Jan 2022 SPQ: Taped / Reel 1000 [-08] 2500 [-01] 7500 [-04] Remarks: - Unlisted inductance values available upon request. - 2% and 5% tolerance available upon request. • All dimensions in mm
0805F-100K-01
物料型号:EK-0805F-X
器件简介:Fastron Group提供的是适用于射频应用的开放式线圈电感器,符合RoHS标准且无卤素。
引脚分配:文档中没有明确提供引脚分配信息,但通常这类电感器为两个引脚。
参数特性: - 尺寸:1.80mm x 0.47mm - 推荐焊盘布局尺寸:1.27mm x 0.50mm x 0.80mm - 典型电感值与频率关系图表显示了不同频率下的电感值变化。
功能详解:文档中没有提供详细的功能解释,但电感器通常用于滤波、能量存储和转换等。
应用信息:适用于射频应用,可能包括无线通信、广播设备等。
封装信息:0805尺寸,环氧树脂平面顶部。
0805F-100K-01 价格&库存
很抱歉,暂时无法提供与“0805F-100K-01”相匹配的价格&库存,您可以联系我们找货
0805F-100K-01
    • 1+4.648601+0.60200
    • 10+3.9181010+0.50740
    • 50+3.9181050+0.50740
    • 100+2.91150100+0.37710
    • 1000+2.235801000+0.28960
    • 10000+1.8595010000+0.24080
    库存:1250
