35FE
35FE
    EATON(伊顿)
    Cylindrical,Blade Terminal(Bolt)
    FUSE CRTRDGE 35A 450VDC CYLINDR
35FE 数据手册
DATASHEET - 35A 690V IEC AC BS88 HIGH SPEED FUSE Fuse-link, high speed, 35 A, AC 690 V, DC 500 V, BS88, 19 x 77 mm, aR, BS, low let through Delivery program Part no.  Catalog No.      35A 690V IEC AC BS88 HIGH SPEED FUSE 35FE Product range     Fuse Basic function     Fuse-link Field of application     high speed Rated current I A 35 Rated voltage     AC 690 V DC 500 V Construction size     BS88 Size     19 x 77 mm Utilization category     aR Breaking Capacity   kA 200 usable for size/applications     protection of DC common bus, DC drives, power converters/rectifiers and reduced voltage starters Standard/Approval     BS Shape     offset bolted tags Standards/Regulations     BS88-4 IEC 60269-4 Optional accessories     fuse-holder BH-0111 Technical data ETIM 7.0 Circuit breakers and fuses (EG000020) / Low Voltage HRC fuse (EC000055) Electric engineering, automation, process control engineering / Electrical installation, device / Safety fuse inserts / Low-Voltage HRC fuse (ecl@ss10.0.1-27-14-20-05 [AFZ800015]) Construction size     Other Rated current   A 35 Rated voltage   V 690 Voltage type     AC/DC Rated switching capacity   kA 200 Utilization category     aR (accompanied semiconductor protection) Type of fuse status indicator     None Insulated metal gripping lugs (IMGL)     No 05/10/2020 Eaton Industries GmbH http://www.eaton.eu © 05/2020 by Eaton Industries GmbH Eaton 35FE ED2020 V68.0 EN 1/1
很抱歉,暂时无法提供与“35FE”相匹配的价格&库存,您可以联系我们找货
35FE
  • 1+206.92295
  • 50+206.52722
  • 250+202.15341
库存:124
