XT Series Toggles Vehicle Controls
Commercial and industrial
equipment
Household appliances
Industrial machinery and
automation
Medical equipment
Military communications and
surveillance
Rail systems
Signaling and communications
Test and lab equipment
Telecommunications, cable
and broadcasting
Accessories
Keyway
16.0 ± 0.3
28.6 ± 0.3
ø6.0 ± 0.3
16.5 ± 1.0
11.9 ± 0.3
17.2 ± 0.5
11.5 ± 0.5
15/32-32 NS-2A
1
Eaton’s new competitively
priced ac rated XT Series
Toggles offer a standard high
rating for both single- and double-pole applications. The new
XT Series Toggle line offers a
wide range of switching
circuits, functions and accessories. Ratings for single- and
double-pole include 20 A at
125 Vac and 10 A at 277 Vac to
handle more severe inductive,
motor and lamp loads. In addition, XT Series Toggles have a
high standard horsepower rating
of 1-½ hp from 125 – 250 Vac
for double-pole applications. The
easy-to-install toggles also have
an industry standard .480-inch
diameter mounting hole. For
added convenience and delivery
support, select industry standard
switch circuit part numbers are
available from stock. With so
many features, XT Series can be
used in a variety of applications!
2
Applications
3
Introduction
Single-Pole Dimensions in mm
For more information on relevant
accessories, see publication
number TD07002001E.
Keyway
Mounting Hole
19.0 ± 0.5
ø12.0+0.1
-0
33.0 ± 0.5
16.5 ± 1.0
ø6.0 ± 0.2
1.6 ± 0.1
11.0 ± 0.1
11.9 ± 0.3
18.8 ± 0.5
11.5 ± 0.5
15/32-32 NS-2A
3
2
1
3
4
6
6
1
5
4
Double-Pole Dimensions in mm
Specifications Summary
Single-Pole Rating
20 A, 125 Vac; 10 A, 277 Vac; 3/4 hp 125 – 250 Vac
Double-Pole Rating
20 A, 125 Vac; 10 A, 277 Vac; 1-1/2 hp 125 – 250 Vac
Available Circuits
1PST, 1PDT, 2PST, 2PDT
Terminal Types
Brass Screw, Brass Solder Lugs, Brass Nickel-Plated .250” Spade
Hardware Included
Zinc Nickel-Plated Knurl Nut, Zinc Nickel-Plated Hex Nut
Mounting Means
Threaded Bushing 12.0 +.1, -0 mm; 16.5 +1, -1 mm
Keyway
1.8 mm Located in Down Position
Base Material
Thermoset Molding Material
Finish
Bright Nickel-Plated Toggle Lever and Bushing
Contact Mechanism
Slow-make/Slow-break Butt Contact
Contact Resistance
50 Ohm Maximum
Dielectric Strength
AC 1500 V, 1 Minute
Operating Temperature
0 – 65°C
Insulation Resistance
DC 500 V 100M Ohm Minute
Seal Level Rating
IP40
Approval
UL姞 Recognized component for Canada (cUR marked): File E2702;
RoHS Compliant
Packaging
Sealed in Polybag Labeled with Part Number
1 Furnished bulk packaged.
Single-Pole — Rating 20 A at 125 Vac; 10 A at 277 Vac; 3/4 hp, 125 – 250 Vac; Recommended up to 15 A at 28 Vdc
Circuit with Toggle In
Terminal Type — Catalog Number
Poles and Throw
UP Position
CENTER Position
DOWN Position 2
.250 Spade
Screw
Solder Lugs
1 PST
ON
NONE
OFF
XTD1A1A2
XTD1A2A2
XTD1A3A2
1 PST
ON 3
NONE
OFF
XTD1F1A2
XTD1F2A2
XTD1F3A2
1 PDT
ON
OFF
ON
XTD2B1A
XTD2B2A
XTD2B3A
1 PDT
ON
NONE
ON
XTD2C1A
XTD2C2A
XTD2C3A
1 PDT
ON
NONE
ON 3
XTD2D1A
XTD2D2A
XTD2D3A
1 PDT
ON 3
OFF
ON 3
XTD2E1A
XTD2E2A
XTD2E3A
1 PDT
ON
OFF
ON 3
XTD2G1A
XTD2G2A
XTD2G3A
2 Keyway position.
3 Indicates momentary position.
Double-Pole — Rating 20 A at 125 Vac; 10 A at 277 Vac; 1-1/2 hp at 125 – 250 Vac; Recommended up to 15 A at 28 Vdc
Poles and Throw
UP Position
CENTER Position
DOWN Position 4
.250 Spade
Screw
Solder Lugs
2 PST
ON
NONE
OFF
XTD3A1A2
XTD3A2A2
XTD3A3A2
2 PST
ON 5
NONE
OFF
XTD3F1A2
XTD3F2A2
XTD3F3A2
2 PDT
ON
OFF
ON
XTD4B1A
XTD4B2A
XTD4B3A
2 PDT
ON
NONE
ON
XTD4C1A
XTD4C2A
XTD4C3A
2 PDT
ON
NONE
ON 5
XTD4D1A
XTD4D2A
XTD4D3A
2 PDT
ON 5
OFF
ON 5
XTD4E1A
XTD4E2A
XTD4E3A
2 PDT
ON
OFF
ON 5
XTD4G1A
XTD4G2A
XTD4G3A
4 Keyway position.
5 Indicates momentary position.
Eaton Corporation
Electrical Group
1000 Cherrington Parkway
Moon Township, PA 15108
United States
877-ETN-CARE (877-386-2273)
Eaton.com
© 2008 Eaton Corporation
All Rights Reserved
Printed in USA
Publication No. PA07002001E / Z7847
October 2008
PowerChain Management is a registered
trademark of Eaton Corporation.
All other trademarks are property of their
respective owners.
很抱歉,暂时无法提供与“7805K12”相匹配的价格&库存,您可以联系我们找货
