AAO16A
AAO16A
    EATON(伊顿)
    EATON BUSSMANN - AAO16A - Fuse, High Rupturing Capacity (HRC), AAO, 16 A, Bolted Tag, 550 VAC
AAO16A 数据手册
Bussmann® Industrial HRC Fuse AAO 13.8 x 85mm, BS88, IEC 269-1 Offset Bolted Tags CURRENT RATING 15 20 25 32 40 50 63 10 1,000 4 5 2 Time-Current Characteristic Curve (Full Size Curves Available) 100 TIME IN SECONDS CATALOG SYMBOL: AAO INDUSTRIAL HRC FUSE OFFSET BOLTED TAGS PACKAGE QUANTITY: 20 80kA INTERRUPTING RATING MOUNTS IN CAMASTER SERIES OF HOLDERS Dimensional Data: 10 1 K D J A F B E H G 100 1 10 .01 1,000 .1 CURRENT IN AMPERES Electrical Characteristics Catalog Number Ampere Rating I2T (Amp2 Seconds) PreTotal At Arcing 415V Total At 550V Nom Watts Loss AAO2 AAO4 AAO6 AAO10 AAO16 AAO20 AAO25 AAO32 AAO32M40 AAO32M50 AAO32M63 2 4 6 10 16 20 25 32 32M40 32M50 32M63 1.4 8 28 125 120 260 570 710 1400 3000 7000 5 30 115 500 750 1700 2500 5000 5000 11,000 24,800 0.9 1.4 1.8 2.1 1.8 1.8 2 2.9 4.7 4.9 5.6 4.7 26 100 400 470 1100 2300 3000 3600 8500 18,000 Dimensions (Inches/mm) Rated Voltage A B D E F G H J K 35.0 13.7 3.35 85.0 0.34 8.7 0.05 1.2 2.87 73.0 0.22 5.5 8.0 14.5 54.5 21.0 85.0 0.34 8.7 0.05 1.22 73.5 0.22 5.5 8.0 22.3 550AC The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-17-98 SB98107 Rev. A Form No. AAO Page 1 of 1 BIF Doc #4109
AAO16A 价格&库存
很抱歉,暂时无法提供与“AAO16A”相匹配的价格&库存,您可以联系我们找货
