Technical Data 10984
Effective October 2020
Supersedes November 2019
ACE1V2012
Automotive grade common-mode chip inductor
Applications
Product features
Controller area network (CAN)
Ethernet architectures
Automotive signal line filter
Advanced driver assistance systems (ADAS)
Infotainment, safety cameras, sensors,
xEV, Powertrain
AEC-Q200 qualified
Engine control unit (ECU)
0805 (2012 metric) package
Electric power steering system (EPS)
Impedance range from 90 ohms to 2200 ohms
Battery management systems (BMS)
Moisture sensitivity level (MSL): 1
Environmental compliance and general
specifications
Operating temperature range: -40 °C to +105 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
ACE1V2012
Product specifications
Part number
Common-mode
impedance Z (Ω) at
100 MHz
DCR (Ω)
@ +25 °C
maximum
Idc (mA)
maximum
Rated voltage
(Vdc) typical
Insulation
resistance
(MΩ)
minimum
Withstanding
voltage (Vdc)
typical
ACE1V2012-900-R
90 ±25%
0.3
400
50
10
125
ACE1V2012-121-R
120 ±25%
0.3
370
50
10
125
ACE1V2012-201-R
200 ±25%
0.35
330
50
10
125
ACE1V2012-361-R
360 ±25%
0.4
280
50
10
125
ACE1V2012-681-R
680 ±25%
0.8
220
50
10
125
ACE1V2012-102-R
1000 ±25%
1.5
190
50
10
125
ACE1V2012-222-R
2200 ±25%
2.0
150
50
10
125
1. Part Number Definition: ACE1V2012-xxn-R
ACE1V2012 = Product code and size
xx= impedance value in ohms,
n= multiplication factor: 10^n (i.e. 900 = 90 * 10^0 = 90 ohms)
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended pad layout
B
A
Epoxy
C
D
Terminations
Wires
E
E
F
F
Equivalent circuit
1
4
2
3
No polarity
Part Number
A
B
C
D
E
F
ACE1V2012-xxn-R
2.0 ±0.2
1.2 ±0.2
1.2 ±0.2
0.2 ±0.1
0.40 typ
0.45 typ
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Pad layout dimensions are reference only
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ACE1V2012
Packaging information (mm)
Supplied in tape and reel packaging, 2000 parts per 7” diameter reel
Ao
1.50±0.10
Bo
2.35±0.10
Ko
1.45±0.10
W
8.00±0.20
E
1.75±0.10
F
3.50±0.05
Po
4.0±0.05
P1
4.0±0.10
Do
1.0±0.1
3
ACE1V2012
Performance curves
ACE1V2012-121-R
Impedance (Ω)
Impedance (Ω)
ACE1V2012-900-R
Frequency (MHz)
Frequency (MHz)
ACE1V2012-201-R
Impedance (Ω)
Impedance (Ω)
ACE1V2012-361-R
Frequency (MHz)
Frequency (MHz)
Frequency (MHz)
4
ACE1V2012-102-R
Impedance (Ω)
Impedance (Ω)
ACE1V2012-681-R
Frequency (MHz)
ACE1V2012
Performance curves
Impedance (Ω)
ACE1V2012-222-R
Frequency (MHz)
Common mode measurement method:
Differential mode measurement method:
5
ACE1V2012
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“ACE1V2012-201-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.460472000+0.29415
- 4000+2.414054000+0.28860
- 6000+2.367626000+0.28305
