ACE1V3225-110-R
ACE1V3225-110-R
    EATON(伊顿)
    两路 共模滤波器 阻抗500Ω@10MHZ
ACE1V3225-110-R 数据手册
Technical Data 10985 Effective November 2019 ACE1V3225 Automotive grade common-mode chip inductor Applications Product features • AEC-Q200 qualified • 1210 (3225 metric) package • Impedance range from 500 ohms to 15000 ohms • Inductance range from 11 uH to 200 uH • Moisture sensitivity level (MSL): 1 • Controller area network (CAN) • Ethernet architectures • Automotive signal line filter • Advanced driver assistance systems (ADAS) • Infotainment, safety cameras, sensors, xEV, Powertrain • Engine control unit (ECU) • Electric power steering system (EPS) • Battery management systems (BMS) Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ACE1V3225 Automotive grade common-mode chip inductor  Technical Data 10985 Effective November 2019 Product specifications Common-mode impedance Z (Ω) at 10 MHz Part number Common-mode inductance (μH) at 100 kHz DCR (Ω) @ +25 ° maximum Idc (mA) maximum Rated voltage (Vdc) typical Insulation resistance (MΩ) minimum ACE1V3225-110-R 300 minimum 500 typical 11+50%/-30% 0.40 300 80 10 ACE1V3225-220-R 500 minimum 1000 typical 22+50%/-30% 0.50 250 80 10 ACE1V3225-510-R 1000 minimum 2600 typical 51+50%/-30% 0.70 200 80 10 ACE1V3225-101-R 2200 minimum 5100 typical 100+50%/-30% 1.50 150 80 10 ACE1V3225-201-R NA 200+30%/-20% 4.80 70 80 10 1. Part Number Definition: ACE1V3225-xxn-R ACE1V3225 = Product code and size xx= inductance value in uH, n= multiplication factor: 10^n (i.e. 110 = 11 * 10^0 = 11 uH) -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout B A Epoxy C D Terminations Wires E E F F Equivalent circuit 1 4 2 3 No polarity Part Number A B C D E F L H G1 G2 ACE1V3225-xxn-R 3.2±0.2 2.5±0.2 2.5 max 0.2±0.1 0.9 typ 08 typ 3.7 typ 2.8 typ 2.4 typ 1.2 typ All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 10985 ACE1V3225  Automotive grade common-mode chip inductor Effective November 2019  Packaging information (mm) Supplied in tape and reel packaging, 1000 parts per 7” diameter reel Ao 2.80±0.10 Bo 3.60±0.10 Ko 2.20±0.10 W 8.00±0.20 E 1.75±0.10 F 3.50±0.05 Po 4.0±0.05 P1 4.0±0.10 Do 1.0±0.1 www.eaton.com/electronics 3 ACE1V3225 Automotive grade common-mode chip inductor  Technical Data 10985 Effective November 2019 Performance curves ACE1V3225-220-R Impedance (Ω) Impedance (Ω) ACE1V3225-110-R Frequency (MHz) Frequency (MHz) ACE1V3225-101-R Impedance (Ω) Impedance (Ω) ACE1V3225-510-R Frequency (MHz) Frequency (MHz) Common mode measurement method: Impedance (Ω) ACE1V3225-201-R Differential mode measurement method: Frequency (MHz) 4 www.eaton.com/electronics Technical Data 10985 ACE1V3225  Automotive grade common-mode chip inductor Effective November 2019  Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package Thickness Volume mm3
ACE1V3225-110-R 价格&库存
很抱歉,暂时无法提供与“ACE1V3225-110-R”相匹配的价格&库存,您可以联系我们找货
ACE1V3225-110-R
    ACE1V3225-110-R
    • 1000+4.502101000+0.58284
    • 2000+4.245492000+0.54962
    • 3000+4.102343000+0.53109
    • 5000+3.929035000+0.50865
    • 7000+3.819017000+0.49441
    • 10000+3.7058510000+0.47976
    库存:446
    ACE1V3225-110-R
    • 1000+2.97414
    • 2000+2.81723
    • 3000+2.75254
    • 4000+2.70583
    • 5000+2.66870
    • 7000+2.61360
    • 10000+2.56209
    ACE1V3225-110-R
    • 1+6.580751+0.85194
    • 10+5.3861910+0.69729
    • 25+4.9855925+0.64543
    • 50+4.6997450+0.60843
    • 100+4.43001100+0.57351
    • 250+4.09820250+0.53055
    • 500+3.86415500+0.50025
    库存:446
    ACE1V3225-110-R
    • 1000+2.68421
    • 4000+2.10384
    库存:65839
