B042-008
B042-008
    EATON(伊顿)
B042-008 数据手册
8-Port 1U Rack-Mount USB/PS2 KVM Switch with On-Screen Display Highlights NetController 8-Port, 1U rackmount KVM switch MODEL NUMBER: B042-008 Control 8 computers via a single VGA monitor and USB or PS/2 keyboard/mouse Control up to 248 computers by daisychaining up to 15 additional B042-Series KVM switches P780-Series USB/PS2 combo KVM cables kits allow you to connect either USB or PS/2 computers, without the need to purchase separate cables or adapters Compatible with all major operating systems Description Package Includes Tripp Lite's NetController 8-Port, 1U rackmount KVM Switch is an affordable, highly-flexible enterprise class KVM Switch, which allows the user to connect either USB or PS/2 keyboards and mice. In addition, P780-Series USB/PS2 combo KVM cable kits allow you to connect either USB or PS/2 computers, without the need to purchase separate cables or adapters. Control up to 8 directly connected computers, or expand the number of connected computers to up to 248 by daisychaining up to 15 additional B042-Series KVM switches. Switch between connected computers via the On-Screen Display (OSD), pushbuttons, or keyboard hotkey commands. Other features include: password protection, auto-scanning, auto-logout, firmware upgrade and video support up to 2048 x 1536 (QXGA). Mounts easily in a standard 19" rack/cabinet and includes all necessary mounting hardware. Compatible with all major operating systems. Constructed of heavy-duty steel housing. B042-008 NetController 8-Port, 1U rackmount KVM switch External Power Supply with NEMA 1-15P Plug (Input: 100-240V, 50/60Hz, 0.5A / Output: 9V, 1A) Rackmount hardware 8 In. Daisychain cable ( for longer daisy-chain cables, see Tripp Lite P781 series cables) Features Daisychain terminator NetController 8-Port, 1U rackmount KVM switch 4 ft. HD15 to DB9 firmware Control 8 computers via a single VGA monitor and USB or PS/2 keyboard/mouse upgrade cable P780-Series USB/PS2 combo KVM cable kits allow you to connect either USB or PS/2 computers, without the CD with owner's manual and need to purchase separate cables or adapters quick start guide Control up to 248 computers by daisychaining up to 15 additional B042-Series KVM switches Quick start guide Allows for easy customization of ports by daisy-chaing any combination of B042-Series KVM's (4-, 8- or 16-port) Standard 19" Rackmount size - hardware included On-Screen Display (OSD) menu for intuitive operation and easy control Switch between connected computers via the On-Screen Display (OSD), pushbuttons, or keyboard hotkey commands Supports video resolution up to 2048 x 1536 Password protection and auto-logout features Firmware upgradeable Robust metal case design ensures best EMI/RFI shielding and video quality Hot-swappable: disconnect and reconnect USB computers without rebooting 1/3 Hot-swappable: disconnect and reconnect USB computers without rebooting Supports standard 5-button Microsoft, Logitech, or comparable mice Supports standard Microsoft, Logitech, or comparable keyboards Compatible with all major operating systems Constructed of heavy-duty steel housing Specifications OVERVIEW Users 1 AC Adapter Input: 100-240V, 50/60Hz, 0.5A / Output: 9V, 1A Console No Max CPU 248 PHYSICAL Color Black LCD Monitor (in.) Not Applicable LCD Monitor (cm) Not Applicable ENVIRONMENTAL BTUs 245.52 COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access No CONNECTIONS Ports 8 PC/Server Connections VGA; USB; PS/2 SPECIAL FEATURES Cat5 KVM Switch No WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2017 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: 2/3 Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
B042-008 价格&库存
很抱歉,暂时无法提供与“B042-008”相匹配的价格&库存,您可以联系我们找货
