BK/C515-125-R
BK/C515-125-R
    EATON(伊顿)
BK/C515-125-R 数据手册
5 x 15mm Axial-Leaded, Time-Delay, Glass Tube Fuses C515 Series Dimensions - mm Drawing Not to Scale Description • Axial-leaded, time-delay • 5 x 15mm physical size • Nickel-plated brass endcap construction • Leads are tin coated • Optional sleeve is flexible flouropolymer (UL Flammability rating VW-1). • UL Listed product meets standard UL 248-14 Agency Information • UL Listed Card: C515 125mA-250mA and 375mA-3A (Guide JDYX, File E19180) • UL Recognized Card: C515 350mA, and 3.5A-7A (Guide JDYX2, File E19180) • CSA Certification Card: C515 125mA-250mA and 375mA-3A (Class 1422-01, 53787 Ordering Specify product code • Insert packaging code prefix before part number. E.g., BK (or TR2)/C515-2-R • With TR2 packaging code, lead wire length is 20.3mm Specify option code, if desired • For insulation sleeve, insert “S” after part series. E.g., BK/C515S-2-R Electrical Characteristics Amp Rating Opening Time 135% 60 minutes max. 125mA - 250mA 3 seconds min. 200% 120 seconds max. 100% 4 hours min. 470mA 30 minutes max. 350mA 600mA 90 seconds max. 2A 2 seconds max. 6A 500 milliseconds max. 135% 60 minutes max. 375mA - 7A 3 seconds min. 200% 120 seconds max. Rated Current Specifications Product Code C515-125-R C515-250-R C515-350-R C515-375-R C515-500-R C515-600-R C515-750-R C515-800-R C515-1-R C515-1.25-R C515-1.5-R C515-1.6-R C515-2-R C515-2.25-R C515-2.5-R C515-3-R C515-3.5-R C515-4-R C515-5-R C515-6-R C515-7-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 125 125 125 Interrupting Rating (amps) 600Vac 250Vac 125Vac 35 10000 35 10000 25 35 10000 35 10000 35 10000 35 10000 35 10000 35 10000 35 10000 100 10000 100 10000 100 10000 100 10000 100 10000 100 10000 100 10000 400 400 400 400 400 Typical DC Cold Resistance* Ω) (Ω 4.72 1.32 1.04 0.81 0.54 0.38 0.26 0.23 0.14 0.13 0.100 0.090 0.059 0.057 0.046 0.035 0.028 0.023 0.019 0.014 0.013 Typical Melting I2t** 0.101 0.467 1.169 1.531 2.280 6.982 9.162 10.544 14.289 22.961 31.989 35.156 60.256 97.724 78.163 80.426 149.279 233.346 354.813 471.360 710.500 *DC Cold Resistance (Measured at
BK/C515-125-R 价格&库存
很抱歉,暂时无法提供与“BK/C515-125-R”相匹配的价格&库存,您可以联系我们找货
