BK/GMC-2-R
BK/GMC-2-R
    EATON(伊顿)
    5.00 x 20.00mm
    FUSE GLASS 2A 250VAC 5X20MM
BK/GMC-2-R 数据手册
Effective February 2018 Supersedes May 2017 Technical Data 4395 GMC HALOGEN HF Pb FREE 5 mm x 20 mm Medium time-delay glass tube fuses Agency information • • • • • UL Listed, Guide JDYX, File E19180, 63mA-6.3A UL Recognized Card: (7A-10A) Guide JDYX2, File E19180 CSA Certified, Class 1422-01, File E65063, 63mA-6.3A MITI Approval, 1A-10A KC-Mark: Certificate SU05011-4001 (63mA~250mA); SU05011-4002 (300mA~800mA); SU05011-4003 (1A~3.15A); SU05011-4004 (3.5A~6.3A) Ordering Product features • • • • • Specify packaging code prefix, product number and option code suffix • Medium time-delay, low breaking capacity Available with optional axial leads 5 mm x 20 mm physical size Glass tube, nickel-plated brass endcap construction Designed to UL/CSA 248-14 Rated Current 63mA - 10A Product Number GMC-63-R GMC-80-R GMC-100-R GMC-125-R GMC-150-R GMC-160-R GMC-200-R GMC-250-R GMC-300-R GMC-315-R GMC-400-R GMC-500-R GMC-600-R GMC-630-R GMC-700-R GMC-750-R GMC-800-R GMC-1-R GMC-1.25-R GMC-1.5-R GMC-1.6-R GMC-2-R GMC-2.5-R GMC-3-R GMC-3.15-R GMC-3.5-R GMC-4-R GMC-5-R GMC-6-R GMC-6.3-R GMC-7-R GMC-8-R GMC-10-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 125 125 125 125 125 125 Interrupting Rating (Amps)* 250Vac 125Vac 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 10,000 10,000 10,000 10,000 10,000 200 200 200 Electrical Characteristics % of Amp Rating Opening Time 100% None 135% 60 minutes maximum 200% 2 minutes maximum Typical DC Cold Resistance (Ω)** 10.350 4.775 3.400 2.555 2.295 1.395 0.965 0.838 0.685 0.615 0.335 0.282 0.246 0.213 0.213 0.180 0.156 0.098 0.076 0.067 0.043 0.035 0.026 0.025 0.022 0.019 0.014 0.013 0.012 0.012 0.009 0.007 Typical Pre-Arc I2t AC† 0.0027 0.0050 0.0094 0.014 0.022 0.022 0.032 0.046 0.081 0.081 0.18 0.41 0.60 0.66 0.85 0.85 0.85 1.8 3.4 5.4 5.8 8.9 13 19 23 25 36 58 88 110 150 200 300 Maximum Voltage Drop (mV)‡ 1400 1400 1200 1000 800 730 650 490 580 480 510 370 360 360 340 320 290 250 200 190 160 130 130 130 130 130 120 120 120 120 120 110 110 * Interrupting ratings: Interrupting ratings for 63mA - 6.3A were measured at 70% - 80% power factor on AC. The interrupting ratings for 7A - 10A were measured at 100% power factor on AC. ** DC Cold Resistance (Measured at
BK/GMC-2-R 价格&库存
很抱歉,暂时无法提供与“BK/GMC-2-R”相匹配的价格&库存,您可以联系我们找货
BK/GMC-2-R
  • 100+20.06176100+2.49750
  • 300+19.79427300+2.46420
  • 400+19.70510400+2.45310
  • 1000+19.526781000+2.43090
  • 1500+19.259291500+2.39760
BK/GMC-2-R
    • 100+2.22909100+0.27750
    • 400+2.18451400+0.27195
    • 1500+2.139921500+0.26640
    • 4000+2.095344000+0.26085
    • 10000+2.0507610000+0.25530
    库存:1900
    BK/GMC-2-R
    • 100+22.15072
    • 1000+5.53768
    库存:34
