BK/GMW-1
BK/GMW-1
    EATON(伊顿)
    Radial,Can,Vertical
    FUSE BOARD MNT 1A 125VAC RADIAL
BK/GMW-1 数据手册
Bussmann® Specialty Fuses GMW and HWA Fast-Acting Dimensional Data FUSE 0.69" (17.5mm) FRONT PANEL CATALOG SYMBOL: GMW (FUSE), HWA (HOLDER) PIN TYPE 0.280” x 0.25” (7.1mm x 6.4mm) FAST-ACTING INTERRUPTING RATING - 35 AMPS GMW: U.L. RECOGNIZED (GUIDE #JDYX2, FILE # E19180) HWA: U.L. RECOGNIZED (GUIDE #IZLT2, FILE # E14853) 0.147" 0.28" (3.7mm) (7.1mm) 0.25" 0.55" 0.98" (6.4mm) (13.9mm) (25.0mm) MOUNTING HOLE + 0.002" Test Specifications (0.5mm) 0.379" (9.6mm) Load Opening Time 100% 4 hrs. (min.) 200% 10 sec. (max.) 0.344" (8.7mm) GMW-1/64 GMW-3/10 GMW-2 GMW-1/32 GMW-4/10 GMW-3 GMW-1/16 GMW-1/2 GMW-4 GMW-1/10 GMW-6/10 GMW-5 GMW-1/8 GMW-3/4 — GMW-2/10 GMW-1 — AMPERE RATING 100 HWA Fuseholder 100 0.44 200.0 AF Knob 100 0.25 113.4 * Weight per carton. • Sub-miniature pin-base fuses for limited space applications. • Can be soldered direct into circuit or can be mounted in HWA holder which can be soldered into circuit. • Transparent window in fuse for visual determination of open fuse element. • Fuseholder body and knob material is diallyl phthalate. • Holder includes “O”-ring, gasket, and nut. • Military versions: fuse–FMO1; holder–FHN42W. • Type HWA-AF holder includes waterproof cap (knob) AF. 1 .1 .01 30 97.7 10 0.20 1 100 .1 Kg. GMW 1/100–5 .01 Weight* Lbs. .005 Carton Qty TIME IN SECONDS 10 Carton Quantity and Weight Ampere Ratings 1/10 GMW-1-1/2 1/16 GMW-1/4 1/32 GMW-1/100 1/100 1/64 1/200 125 Volts 2/10 1/4 3/10 4/10 1/2 6/10 3/4 1 1-1/2 2 3 4 5 Time-Current Characteristics–Total Clear Electrical Ratings (Catalog Symbol and Amperes) CURRENT IN AMPERES The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-18-98 SB98107 Rev. A Form No. GMW Page 1 of 1 BIF Doc #2058
BK/GMW-1 价格&库存
很抱歉,暂时无法提供与“BK/GMW-1”相匹配的价格&库存,您可以联系我们找货
