BK1-S506-1-25-R
BK1-S506-1-25-R
    EATON(伊顿)
BK1-S506-1-25-R 数据手册
Effective January 2024 Supersedes September 2023 Technical Data 4332 S506 5 mm x 20 mm Time-delay glass tube fuses Agency information Product features Time-delay, low breaking capacity Optional axial leads available 5 x 20 mm physical size Glass tube, nickel-plated brass endcap construction Designed to IEC 60127-1 & 2 (32 mA-10 A) & extensions: (12.5 A-15 A) • Operating temperature: -40 °C to +125 °C • • • • • • cURus Recognition: Guide JDYX8, JDYX2, File E19180 • CSA Component acceptance: Class number 1422-30&90 File 053787 • SEMKO Approval: File 1518843, 1410180 • VDE Approval: File 40011926 • BSI Approval: File KM55676 • IMQ Approval: File E1921 • PSE/JET: File JET1641-31003-1019,JET1641-31003-1020,JET1641-31003-1021, J ET1641-31003-1022 • KC File number: SU05011-6001, SU05011-6002, SU05011-5005, SU05011-5006, SU05011-5007 • CCC Approval: File 2020970207000244 • Ordering information • The ordering code is the part number replacing the “.” with a “-” plus adding the packaging prefix: Cartridge: S506-3.15-R; BK-S506-3-15-R Axial lead: S506-3.15-R; BK-S506-V-3-15-R • Ratings above 4 A have a 0.81 mm diameter lead S506 Electrical characteristics 2.1 In 2.75 In 4 In 10 In In max min max min max min max 32 mA-100 mA 2 min 200 ms 10 sec 40 ms 3 sec 10 ms 300 ms 125 mA-6 A 2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms 8 A-15 A 2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms Specifications Current Voltage rating (Vac) rating (A) Interrupting rating (A) at rated Voltage (50 Hz) Vac Typical DC Typical cold resistance melting I2t (Ω)* (A2s) S506-32-R 250 0.032 35 21.0 0.0051 S506-40-R 250 0.040 35 13.90 0.0072 S506-50-R 250 0.050 35 9.24 0.0095 S506-63-R 250 0.063 35 6.96 S506-80-R 250 0.080 35 S506-100-R 250 0.100 S506-125-R 250 S506-160-R 250 S506-200-R Part number Typical voltage drop (mV)‡ Agency approvals IMQ VDE BSI SEMKO UR CCC 1050 X X X X X X 920 X X X X X X 800 X X X X X X X 0.021 760 X X X X X X X 4.42 0.038 580 X X X X X X X 35 2.80 0.045 490 X X X X X X X 0.125 35 1.97 0.063 390 X X X X X X X 0.160 35 1.27 0.093 320 X X X X X X X 250 0.200 35 1.00 0.114 340 X X X X X X X S506-250-R 250 0.250 35 0.640 0.265 270 X X X X X X X S506-315-R 250 0.315 35 0.450 0.621 250 X X X X X X X S506-400-R 250 0.400 35 0.31 0.872 210 X X X X X X X S506-500-R 250 0.500 35 0.183 0.827 140 X X X X X X X X S506-630-R 250 0.630 35 0.186 1.33 150 X X X X X X X X S506-800-R 250 0.800 35 0.129 2.78 75 X X X X X X X X S506-1-R 250 1.0 35 0.0757 6.45 87.5 X X X X X X X X X S506-1.25-R 250 1.25 35 0.060 10.05 86 X X X X X X X X X S506-1.6-R 250 1.6 35 0.0425 21.7 82 X X X X X X X X X S506-2-R 250 2.0 35 0.03325 31.6 77 X X X X X X X X X S506-2.5-R 250 2.5 35 0.0255 59.4 72.5 X X X X X X X X X S506-3.15-R 250 3.15 35 0.0185 96.4 68.5 X X X X X X X X X S506-4-R 250 4.0 40 0.0139 71.8 67 X X X X X X X X X S506-5-R 250 5.0 50 0.00985 142.5 60.5 X X X X X X X X X S506-6.3-R 250 6.3 63 0.0071 237.6 54 X X X X X X X X X S506-8-R 250 8.0 80 0.007 255.8 55 X X X X X X X X S506-10-R 250 10 100 0.005 450 54 X X X X X X X X S506-12.5-R 250 12.5 125 0.004 1019.5 45 X X X S506-15-R 250 15 150 0.004 1091.7 65.5 X X X * DC cold resistance (measured at
BK1-S506-1-25-R
1. 物料型号:S506,有多种额定电流版本,如32mA到15A。 2. 器件简介:延时保险丝,低断路容量,可选轴向引线,5 x 20 mm的物理尺寸,玻璃管和镀镍黄铜端盖结构,符合IEC 60127-1 & 2标准。 3. 引脚分配:对于额定电流超过4A的版本,引脚直径为0.81mm。 4. 参数特性:包括电气特性表,展示了不同电流下的最小和最大熔断时间。 5. 功能详解:提供了详细的电压额定值、电流额定值、中断额定值、典型直流冷态电阻、典型电压降和机构批准信息。 6. 应用信息:保险丝适用于各种电气系统,但Eaton公司不授权未经公司官员书面批准的任何产品用于生命维持设备或系统。 7. 封装信息:包括包装代码和选项代码,描述了不同的包装方式和引脚选项。 8. 其他信息:Eaton电子部门的联系信息,版权声明和社交媒体信息。
BK1-S506-1-25-R 价格&库存
很抱歉,暂时无法提供与“BK1-S506-1-25-R”相匹配的价格&库存,您可以联系我们找货
BK1-S506-1-25-R
  • 1+6.24054
  • 143+0.82169
  • 391+0.77737
  • 40000+0.74623
库存:500
