C22-D-G-K10-P62
C22-D-G-K10-P62
    EATON(伊顿)
    PB SW, SPST-NO, 4A, 24VAC, WIRE LEADED
C22-D-G-K10-P62 数据手册
DATASHEET - C22-D-G-K10-P62 Pushbutton, classic, flat, tasted, 1 N/O, green, cable (black) with nonterminated end, 4 pole, 1 m Delivery program Part no.  Catalog No.      C22-D-G-K10-P62 185670 Product range     RMQ compact solution Basic function     Pushbutton actuators Single unit/Complete unit     Complete unit Design     Flat       momentary Connection type     Cable (black) with non-terminated end, 4 pole Cable Length   m 1 Button plate       button plate     green Button plate           Blank Name     None Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Front ring     Bezel: titanium Connection to SmartWire-DT     no Contacts       1 N/O     Contact sequence N/O = Normally open     Contact travel■ = Contact closed□ = Contact open         Contact diagram 03/19/2018   Eaton 185670 ED2018 V42.0 EN 1/3 Technical data General Standards     IEC/EN 60947-5-1 VDE 0660 Certifications     CE, UL, CSA Operating frequency Operations/h   ≦ 3600 Actuating force   n ≦5 Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Control circuit reliability       HF   N/O: 1 failure per 17 × 10 switching operations, statistically determined       Contacts At 17 V DC/7 mA Max. short-circuit protective device Fuse 6 gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Rated operational current Ie A         Ie A 4       Ie A 3 Switching capacity AC-15 24 V DC-13 24 V Cable characteristics       Design     Cable end open Cable Length   m 1 Material characteristic     PUR Diameter ⌀ mm 4.7       Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 70 Design verification as per IEC/EN 61439 Technical data for design verification Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Push button, complete (EC001028) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Push-button actuator, complete unit (ecl@ss8.1-27-37-12-28 [AKF046011]) Number of command positions     1 Colour button     Green Construction type lens     Round Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Degree of protection (IP)     Other Type of button     Flat Suitable for illumination     No Switching function latching     No Spring-return     Yes Supply voltage lamp   V 0 Number of contacts as normally open contact     1 03/19/2018 Eaton 185670 ED2018 V42.0 EN 2/3 Number of contacts as normally closed contact     0 Number of contacts as change-over contact     0 Type of electric connection     Other With front ring     Yes Material front ring     Plastic Colour front ring     Grey Dimensions Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 185670 ED2018 V42.0 EN 3/3
C22-D-G-K10-P62
物料型号:C22-D-G-K10-P62
器件简介: - 产品系列:RMQ compact solution - 基本功能:按钮执行器 - 单位:完整单元 - 设计:平面 - 连接类型:黑色电缆,未端接,4极 - 电缆长度:1米 - 按钮板颜色:绿色 - 保护等级:IP66, IP67, IP69K(前部), IP65(后部) - 连接到SmartWire-DT
引脚分配: - 接触类型:常开(N/O) - 接触顺序:BN, BK
参数特性: - 操作频率:≤3600次/小时 - 操作力:≤5牛顿 - 螺纹环紧固扭矩:2牛顿米 - 气候防护:符合IEC 60068-2-78和IEC60068-2-30的湿热测试 - 机械冲击抗性:>30g - 额定脉冲耐受电压:800V AC - 额定绝缘电压:30V - 过电压类别/污染等级:11/3 - 控制电路可靠性:在17VDC/7mA下,N/O:每17x10次开关操作中1次失败(统计确定) - 最大短路保护装置:gG/gL,4A - 额定条件短路电流:1kA - 额定操作电流:4A(AC-15),3A(DC-13)
功能详解: - 按钮类型:平面 - 颜色:绿色 - 透镜构造类型:圆形 - 孔径:22毫米 - 宽度开口:0毫米 - 高度米开口:0毫米 - 保护等级:其他 - 适合照明:否 - 切换功能锁定:否 - 弹簧返回:是 - 供电电压灯:0
应用信息: - 适用于工业自动化和过程控制工程中的低压开关技术 - 适用于命令和报警设备
封装信息: - 电缆特性:电缆端开放 - 材料特性:PUR(聚氨酯) - 直径:4.7毫米
C22-D-G-K10-P62 价格&库存
很抱歉,暂时无法提供与“C22-D-G-K10-P62”相匹配的价格&库存,您可以联系我们找货
