DATASHEET - C22-WS3-MS1-K02-P62
Key-operated actuator, classic, tasted, 3 positions, MS1, 2 N/C, cable
(black) with non-terminated end, 4 pole, 1 m
Delivery program
Part no.
Catalog No.
C22-WS3-MS1-K02-P62
186264
Product range
RMQ compact solution
Basic function
Key-operated buttons
Single unit/Complete unit
Complete unit
momentary
Function:
Connection type
Cable (black) with non-terminated end, 4 pole
Cable Length
m
1
Not suitable for master key systems
3 positions
Lock mechanism
MS1
Key withdrawable in position
40°
40°
Degree of Protection
IP66 (front)
IP65 (on rear)
Front ring
Bezel: titanium
Connection to SmartWire-DT
no
Contacts
N/C = Normally closed
Notes
mm
4.65
Maximum travel
mm
5.7
Minimum force for positive opening
N
30
Contact sequence
Contact travel■ = Contact closed□ = Contact open
Positive opening (ZW)
yes
Information about equipment supplied
With 1 key
Standards
IEC/EN 60947-5-1
03/19/2018
Eaton 186264 ED2018 V42.0 EN
Actuator travel and actuation force as per DIN EN 60947-5-1,
K.5.4.1
Contact diagram
2 NC
= safety function, by positive opening to IEC/EN 60947-5-1
Technical data
General
1/3
VDE 0660
Certifications
Operating frequency
Operations/h
≦ 100
Operating torque
Nm
≦ 0.5
Tightening torque Threaded ring
Nm
2
Climatic proofing
Damp heat, constant, to IEC 60068-2-78
Damp heat, cyclic, to IEC 60068-2-30
IP66 (front)
IP65 (on rear)
Mounting position
As required
Mechanical shock resistance, shock duration 11 ms
g
> 30
Rated impulse withstand voltage
Uimp
V AC
800
Rated insulation voltage
Ui
V
30
Overvoltage category/pollution degree
III/3
Control circuit reliability
HF
N/C contact: statistically determined 1 failure per 0.9 × 10 Operations
gG/gL
A
4
Rated conditional short-circuit current
Iq
kA
1
Rated operational current
Ie
A
Ie
A
4
Ie
A
3
Design
Cable end open
Cable Length
m
1
Material characteristic
PUR
Diameter
mm
4.7
Contacts
At 17 V DC/7 mA
Max. short-circuit protective device
Fuse
Switching capacity
AC-15
24 V
DC-13
24 V
Cable characteristics
Design verification as per IEC/EN 61439
Technical data for design verification
CE, UL, CSA
6
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
70
Technical data ETIM 6.0
Low-voltage industrial components (EG000017) / Selector switch, complete (EC001029)
Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Selector switch, complete unit (ecl@ss8.1-27-37-12-43
[ACN984008])
Number of switch positions
3
Type of control element
Key
Suitable for illumination
No
With lamp
No
Colour button
Black
Hole diameter
mm
22
Width opening
mm
Height meter opening
mm
Switching function latching
No
Spring-return
Yes
Degree of protection (IP)
IP66
Supply voltage
V
0-0
Number of contacts as normally open contact
Number of contacts as normally closed contact
2
Number of contacts as change-over contact
2/3
Type of electric connection
Other
With front ring
Yes
Material front ring
Plastic
Colour front ring
Other
Dimensions
Assets (Links)
Declaration of Conformity
00002596
Additional product information (links)
IL047016ZU RMQ compact solution
03/19/2018
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf
Eaton Industries GmbH
http://www.eaton.eu
© 03/2018 by Eaton Industries GmbH
3/3
C22-WS3-MS1-K02-P62 价格&库存
很抱歉,暂时无法提供与“C22-WS3-MS1-K02-P62”相匹配的价格&库存,您可以联系我们找货
