CCP2S-3-30CC
CCP2S-3-30CC
    EATON(伊顿)
    EATON BUSSMANN SERIES - CCP2S-3-30CC - 3 POLE COMP CKT PROTECT 30A 98AC5953 - 3 POLE COMP CKT PROTEC...
CCP2S-3-30CC 数据手册
Effective January 2019 Supersedes October 2018 Technical Data 10789 BUSSMANN SERIES Next generation Compact Circuit Protector (cat. no. CCP2) For use with Class CC, Supplemental and IEC 10x38 mm fuses Contents Page Description and specifications. . . . . . . . . . . . . . . . . 2-3 2011/65/EU Catalog numbers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Conductor information and available fuses. . . . . . . . . 5 Dimensions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Accessories. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Multi-wire lug kit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Selector and pistol handles. . . . . . . . . . . . . . . . . . . . . 7 Shafts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 NFPA 79 compliant handle . . . . . . . . . . . . . . . . . . . . . 7 Auxiliary contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 PLC fuse monitor . . . . . . . . . . . . . . . . . . . . . . . . . . 9-10 How to order tables . . . . . . . . . . . . . . . . . . . . . . 11 CCP2 switch Switches only . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Clockwise rotary operated switches. . . . . . . . . . . 12-13 Counterclockwise rotary operates switches. . . . . . . 14 Motor fuse sizing table. . . . . . . . . . . . . . . . . . . 15 CCP2 right front rotary switch CCP2 left front rotary switch CCP2 right side rotary switch CCP2 left side rotary switch Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Catalog symbols Symbol CCP2-(poles)-30CC CCP2-(poles)-30M CCP2-1-DCC CCP2-1-DCM CCP2R-(pole)-30CC CCP2R-(pole)-30M CCP2RL-(pole)-30CC CCP2RL-(pole)-30M CCP2S-(pole)-30CC CCP2S-(pole)-30M CCP2SL-(pole)-30CC CCP2SL-(pole)-30M • Fuse type Class CC UL sup./IEC 10x38 Class CC Vdc UL sup./IEC 10x38 Vdc Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Class CC UL sup./IEC 10x38 Description Switch only UL Supplemental and IEC 10x38 mm fuse versions • UL 508 Listed, Guide NRNT, File E320230 • cULus Certified 22.2 No. 14-05 • IEC 60947-3 AC-23A • DC voltage UL Class CC version (CCP2-1-DCC) • UL 508 Listed, cULus 22.2, No. 1405 Right front rotary switch • DC IEC 10x38 version (CCP2-1-DCM) • IEC 60947-3, DC-23A Left front rotary switch • RoHS compliant • CE 1-pole switch only Right side rotary switch Left side rotary switch Description The revolutionary next generation Bussmann™ series Compact Circuit Protector (cat. no. CCP2) fused disconnect switch is 3/5 the footprint of a traditional fusible switch and provides up to a high 200 kA Short-Circuit Current Rating (SCCR) to help improve panel and assembly SCCR. The 35 mm DIN-Rail mount CCP is available in a variety of configurations to meet many application needs including rotary operation. Application flexibility is extended with an optional multi-wire lug kit, with finger-safe shrouds, that provides three additional wire ports on each pole for power distribution applications. Other accessories include a PLC interface device for open fuse monitoring and NO/NC auxiliary contacts that easily integrate into many monitoring systems. Conductors/terminals • 75°C Cu/Al, see conductor tables for size, type and torque information • Box lug, single/dual conductor • Fork terminal suitable for line, load or accessory connection • Multi-wire lug kit — see accessories for details Storage and operating temperature • - 20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions • Switch only — 4 mm lock or Brady pin-out device part number 90850 • Switch with rotary operating mechanism — 1/4” lock Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Minimum enclosure size Ratings Mounting • • • • Volts 600 Vac (UL Class CC) Local open fuse indication minimum voltage** 240 Vac (UL Supplemental) • 90 Vac for AC switches • 400 Vac (IEC 10x38 mm) • 12 Vdc for DC switches • 80 Vdc (DC Class CC, DC UL Supplemental/IEC) Amps • 30 A (UL) • 32 A (IEC) ** Open fuse indication requires an open fuse to be in the CCP2 and the switch in the ON position. Accessories SCCR • Multi-wire lug kit with terminal shrouds • Selector and pistol handles for use with rotary operated switches • 200 kA (UL Class CC) • 10 kA (UL Supplemental) 8 mm shafts for use with selector and pistol handles • • 120 kA (IEC 10x38 mm max) Auxiliary contacts • • 20 kA (DC Class CC/UL) PLC fuse monitor • • 10 kA (DC UL Supplemental/IEC) 1-, 2- and 3-poles catalog number dependent UL Class CC fuse versions • UL 98 Listed, Guide WHTY, File E302370 • 2 35 mm DIN-Rail • Agency information • 10” x 8” x 6” (254 x 203 x 152 mm) • ® Poles • • cULus to Canadian Standard 22.2 No. 4-04, UL Guide WHTY7, File 302370 Eaton.com/bussmannseries Carton quantity and shipping weight Item Switch only Switch with side rotary mechanism Switch with front rotary mechanism Poles 12 2 3 2 Weight lbs (kg) 2.84 (1.29) 0.9 (0.404) 1.12 (0.509) 0.95 (0.431) 3 1.18 (0.537) Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Technical Data 10789 Effective January 2019 Features • Extremely compact (18 mm wide per pole ) design • High SCCR up to 200 kA (UL Class CC) and 120 kA (IEC) • Disconnect rated for load isolation • Full voltage rated up to 600 Vac or 80 Vdc • UL 98 Listed Class CC version is horsepower rated and suitable for branch circuit protection and disconnect • IEC 10x38 version complies with IEC 60947-3 and suitable for branch circuit protection and disconnect • Suitable for global installations, the switches comply with UL, cULus and IEC standards accepting UL Class CC, Supplemental or IEC aM and gG/gL fuses • Open fuse indication • Standard local open fuse indicating light for each pole • Optional PLC fuse monitor can be utilized to signal a PLC and open a contactor to de-energize all phases, if required • IP20 finger-safe with 10 AWG (6 mm2) or larger wire (box lug terminals only) • Built-in switch interlock prohibits removing the fuse under load • Padlockable handle for lockout/tagout • 4 mm lock for switch only • • 1/4” lock for rotary operated switches Rotary operated versions provide for through-the-door and through-the-side operation flexibility and enhanced safety with: • Right front switch operation • Left front switch operation • Right side switch operation • Left side switch operation Right front rotary operated CCP2 switch with PLC fuse monitor. • Optional selector, pistol and NFPA 79 compliant handles available for use with rotary operated versions • Multi-wire lug kit with terminal shrouds allows for power distribution to multiple loads. Each lug has three ports rated for single and dual wires (see lug kit in accessories for conductor and torque details). Open fuse indicating light Rotary operating switch versions Switch handle (ganged on 2- and 3-pole versions) Fuse access door Left front rotary switch Right front rotary switch Clockwise operating handles Clockwise operating handles Fork terminal Box lug terminal Lockout/tagout provision Right side rotary switch Left side rotary switch Clockwise operating handles Counterclockwise operating handles Eaton.com/bussmannseries 3 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Catalog numbers Max horsepower rating (Vac) Catalog no. Poles Description Amps Volts SCCR 120 240 480 600 1/2 — — — Wire type/ size* Class CC CCP2-1-30CC 1 CCP2-2-30CC 2 CCP2-3-30CC 3 CCP2R-2-30CC 2 CCP2R-3-30CC 3 CCP2RL-2-30CC 2 CCP2RL-3-30CC 3 CCP2S-2-30CC 2 CCP2S-3-30CC 3 CCP2SL-2-30CC 2 CCP2SL-3-30CC 3 347 Vac Switch only 600 Vac Switch with right front rotary operation Switch with left front rotary operation 600 Vac 30 A Switch with right side rotary operation 600 Vac 200 kA 600 Vac Switch with left side rotary operation 600 Vac — 2 — — 3/4 3 5 7.5 — 2 3/4 3 5 7.5 75°C Cu/Al — 2 — — 18-4 AWG 3/4 3 5 7.5 Fork terminal†† — 2 — — 3/4 3 5 7.5 — 2 — — 3/4 3 5 7.5 UL Supplemental and IEC 10x38 mm CCP2-1-30M 1 CCP2-2-30M 2 CCP2-3-30M 3 CCP2R-2-30M 2 CCP2R-3-30M 3 CCP2RL-2-30M 2 CCP2RL-3-30M 3 CCP2S-2-30M 2 CCP2S-3-30M 3 CCP2SL-2-30M 2 CCP2SL-3-30M 3 Switch only Switch with right front rotary operation Switch with left front rotary operation UL 30 A IEC 32 A** UL 240 Vac† IEC 400 Vac† 75°C Cu/Al UL 10 kA† IEC 120 kA† — — — — 18-4 AWG Fork terminal†† Switch with right side rotary operation Switch with left side rotary operation Single-pole DC switches CCP2-1-DCC CCP2-1-DCM 1 1 UL Class CC 30 A UL supplemental 30 A IEC 10x38 32 A** 80 Vdc† 20 kA† — — — — 80 Vdc† 10 kA† — — — — * See box lug terminal conductor data table for details. ** 32 A Class aM, 25 A Class gG. † SCCR may be lower, refer to installed fuse data sheet for interrupting rating at applied voltage. †† Fork terminal with a 4.3 mm gap for a #8-32 stud, 30 A max, insulated flange, wire size 12-10 AWG. 4 Eaton.com/bussmannseries 75°C Cu/Al 18-4 AWG Fork terminal†† Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Type Cu Class Stranded, Stranded, Stranded, Stranded, 10-18 Solid 4-18 6-18 4-18 6-18 Class Class Class Class B to K B/C K B to K Quantity Single Dual 6 Torque N•m (lb-in) 2.26 (20) 3.39 (30) Dual 78 3.1 99 3.9 49 1.9 53 2.1 35 1.4 18 0.7 2.26 (20) Single/dual Single Stranded, UL ferrule, Class B/C 3.39 (30) Twin † Single Stranded, UL ferrule, Class K Single Stranded 2.26 (20) 80 3.1 2.82 (25) Dual 8 93 3.7 2.82 (25) Twin† 4-8 Al Effective January 2019 Left front and right front rotary switches Box lug terminal conductor data AWG range 4-18 6-8 6-8 10-18 Technical Data 10789 2.26 (20) 99 [3.9] † Two stranded conductors placed in one UL Listed twin ferrule. 49 [1.9] 18 [0.7] 35 [1.4] 78 [3.1] 53 [2.1] Available Bussmann series fuses Fuse class CC M gG/gL aM Type/description LP-CC time-delay FNQ-R time-delay KTK-R fast-acting FNM time-delay FNQ time-delay KTK fast-acting BAF fast-acting KLM fast-acting C10G C10M Data sheet Volts no. 600 Vac/300 Vdc* 1023 600 Vac/300 Vdc 1014 600 Vac 1015 250 Vac 2028 500 Vac 1012 600 Vac 1011 250 Vac 2011 600 Vac/dc 2020 500 V (400 V@32 A) 720115 500 V (400 V@20@25 A) 720115 93 [3.7] 93 [3.7] 80 [3.1] Left side and right side rotary switches 78 3.1 * 1/2 to 2-1/2 and 20 to 30 A are 300 Vdc, 2-8/10 to 15 A are 150 Vdc. Dimensions – mm (in) 53 2.1 35 1.4 49 1.9 18 0.7 93 3.7 Switch 49 1.9 18 0.7 35 1.4 53 2.1 80 3.1 49 1.9 18 0.7 35 1.4 53 2.1 78 3.1 93 3.7 93 3.7 80 3.1 80 3.1 Eaton.com/bussmannseries 5 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Multi-wire lug kit Installed on CCP2-3-xx Catalog number • CCP2-MW1-3 Description The multi-wire lug kit permits expanding each box lug terminal on the switch into a three-port terminal for power distribution applications. Each multi-wire lug kit comes with three (3) three-port lugs and three terminal shrouds. Shrouds provide finger-safe protection when properly installed. Lugs may be mounted on either the loadside or lineside to meet various application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the three ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Ratings • Volts 600 V • Amps 60 A max • SCCR 200 kA Multi-wire lugs mount in switch box lug terminals to provide three additional wire ports per pole. Lugs can be mounted on the switch lineside or loadside. Each multi-wire lug kit comes with three lugs and three shrouds. Agency information • UL Recognized (lug only) • RoHS compliant Wire insulation strip lengths 1/8” Allen head screw Storage and operating temperature • 1 = 11/16” - 20°C to 75°C (-4°F to 167°F) 2 = 1-1/8” Multi-wire lug conductor information 3 = 1-9/16” • 75°C Cu/AL • AWG size and quantity per port - see table below Type Cu/Al Cu AWG range Class Quantity Stranded, Class B/C Single 10-14 Stranded, Class B/C 10-14 4-6 8 8 10-14 Torque N•m (lb-in) Strip back wire insulation to the lengths as indicated in the illustration above and the table below. 3.95 (35) Lug port 2.82 (25) 1 11/16 Single/dual* 2.26 (20) 2 1-1/8 Solid Single 2.26 (20) 3 1-9/16 UL ferrule, Class B to K Single/twin † Strip wire insulation back (inch) 2.82 (25) 2.26 (20) * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. CCP2 box lug torque for multi-wire lug • 4.52 N•m (40 lb-in) Terminal shroud accessory Terminal shrouds are available without multi-wire terminals. Catalog no. Description CCP2-TS1-3 Pack of three Wiring versatility is provided by single/dual rated box lug terminals on the switch, or by the three-port multi-wire lug kit that’s also single/dual wire rated. 6 Eaton.com/bussmannseries Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Selector and pistol handles Technical Data 10789 Effective January 2019 Selector handles Catalog symbol • CCP2-H4X-_ Description Selector and pistol handles for use with any 2- and 3-pole CCP2 rotary operated switch. Both selector and pistol handles are available in black/grey and red/yellow colors and clockwise/counterclockwise operating modes. Applying clockwise and counterclockwise operation depends upon the CCP2 rotary switch configuration. Installation requires an 8 mm shaft (ordered separately). Each handle is rated NEMA 4X and capable of accepting up to three (3) 1/4” diameter shank locks for lockout/tagout in the OFF position. They can also be field configured for lock-on. Counterclockwise Clockwise • CCP2-H4X-B1L • CCP2-H4X-R1L • CCP2-H4X-B1 • CCP2-H4X-R1 Pistol handles In application, only the clockwise operating handles in combination with either the left front or right front rotary switches provide a door interlock means to ensure the enclosure door remains shut during lockout/tagout or lock-on. Both clockwise and counterclockwise operating handles when mounted on the enclosure’s left or right side do NOT provide a door interlock means. See the catalog number table below for applicable rotary switch, handle and shaft combinations. Agency information • UL Listed, Guide DIHS, File E140305 • NEMA 4X rating • RoHS complaint • CE Counterclockwise Clockwise • CCP2-H4X-B2L • CCP2-H4X-R2L • CCP2-H4X-B2 • CCP2-H4X-R2 Handle shafts Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Packaging • Each handle is packaged individually NFPA 79 compliant handles Handle shafts Catalog number Catalog symbol • • Description CCP2-SH1-_ Description Eight millimeter square shafts available in 290 and 490 millimeter (11.5 and 19.3 inch) lengths. Shafts are indexed to ensure handle/ switch orientation for correct operation. Shafts are cut to length when installed. Packaging • Each shaft is packaged separately For these switch catalog numbers CCP2R-(pole)-30CC CCP2R-(pole)-30M CCP2RL-(pole)-30CC CCP2RL-(pole)-30M CCP2S-(pole)-30CC CCP2S-(pole)-30M Description/operation Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise NFPA 79 handle mounts on the shaft of front rotary operated switch installations and provides a lockout means independent of the door position. Carton quantity Catalog no. Left side rotary, counterclockwise Fits shaft size Qty. 8 mm 1 CCP2-NFPA-1 Order these handle catalog numbers (description) Order either shaft catalog number • CCP2-H4X-B1 (selector, black/grey) • CCP2-H4X-R1(selector, red/yellow) • CCP2-H4X-B2 (pistol, black/grey) • CCP2-H4X-R2 (pistol, red/yellow) • CCP2-H4X-B1L (selector, black/grey) CCP2SL-(pole)-30CC CCP2SL-(pole)-30M CCP2-NFPA-1 • CCP2-SH1-290 (11.5”/290 mm) • CCP2-SH1-490 (19.3”/490 mm) • CCP2-H4X-R1L (selector, red/yellow) • CCP2-H4X-B2L (pistol, black/grey) • CCP2-H4X-R2L (pistol, red/yellow) Eaton.com/bussmannseries 7 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Auxiliary contacts Installed on a CCP2-3-xx Catalog number Note: CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. • CCP2-AUX Description NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on any 1-, 2- or 3-pole CCP2 switch and the left front/left side rotary operated switches. Ratings • Amps up to 5 A • Volts up to 240 Vac • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Description Max per CCP2* Auxiliary contacts NO+NC for switch status 1 per CCP2 (1-, 2- or 3-pole) Dimensions — in Signal output 1.8 5 A / 240 Vac * The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. De-energize all circuits and follow all prevailing safety procedures before installing or removing the CCP2-AUX. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • IP20 finger-safe in installed state • RoHS compliant • CE 2.6 STRIP 33 NO 34 NO 41 NC 42 NC 3.7 1.9 0.19 0.3 Wiring • 75°C Cu, 20-16 AWG (0.5 to 1.5 mm2) wire • Torque 0.56 N•m (5 lb-in) Packaging • The CCP2-AUX is packaged individually Installation technique • Mounts on the CCP2’s right side ONLY and mechanically interlocks with the CCP2 switch handle with provided hardware. The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) CCP2-AUX auxiliary contacts mounted on a 3-pole CCP2 switch. 8 Eaton.com/bussmannseries Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses PLC fuse monitor Wiring Catalog number • • CCP2-PLC-IND Technical Data 10789 Effective January 2019 For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire Packaging Description A resettable three-phase fuse monitor that integrates with the I/O card in a Programmable Logic Controller (PLC). A single unit can be mounted on any 1-, 2- or 3-pole CCP2 switch and the right front/ right side rotary operated switches. A single unit monitors up to three phases. When used on 1- and 2-pole switches unused conductor(s) are removed after installation. The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. Ratings • The CCP2-PLC-IND is packaged individually • Includes 0.110” (2.8 mm) quick connects for power, signal and ground connections Installation technique • IP20 rating — yes Storage and operating temperature • • Signal output to PLC* • +24 Vdc, 10 mA max • Output signals • Digital 0 Vdc (low), 24 Vdc max (high) Mounts on the left side ONLY of the CCP2 and mechanically interlocks with the CCP2 switch handle with hardware provided. The CCP2-PLC-IND CANNOT be mounted on the left front/ left side rotary operated versions or if the multi-wire lug kit is installed. -20°C to 75°C (-4°F to 167°F) PLC programming • 0 Vdc Low – fuse is good • 24 Vdc High – fuse has opened • * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. The CCP2-PLC-IND signal line is designed to provide a digital input to a PLC I/O card. In this case, a Programmable Logic Control program must be written to properly interpret the input signal to the PLC. The PLC program should check for consecutive high signals before taking action on a critical process. Installed on a CCP2-3-xx Emissions and immunity testing • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2 kV - Power Port and ±1 kV - I/O Ports) • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) Description Wired remote fuse indication for PLC applications Max per CCP2** Signal output to PLC Min. circuit volts 1 per CCP2 (1, 2- or 3-pole) 24 Vdc/ 10 mA 100 Vac CCP2-PLC-IND mounted on a 3-pole switch and using the fork terminals. When mounted on a 2- or 1-pole switch, remove unused leads. Note: The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. ** The CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the CCP2-PLC-IND. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian, Standard 22.2 No. 4-04 Local indication • Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and actuating the reset switch. CCP2-PLC-IND fuse monitor mounted on a right front rotary operated switch. Eaton.com/bussmannseries 9 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 PLC wiring schematic PLC power supply PLC fuse monitor Circuit monitoring leads from CCP2-PLC-IND to CCP2 (100 – 600 Vac) +24 Vdc +24 Vdc 0 Vdc/Gnd 0 Vdc/Gnd CCP2-PLC-IND connections from a CCP2-3-xx to a remote monitoring device Signal 10 mA max. Circuit monitoring leads from PLC or remote monitoring device. The PLC fuse monitor needs to be powered by the same +24 Vdc and ground (0 Vdc/Gnd return) terminals that feed the PLC input card. If it is not, it may improperly signal. If feeding multiple PLC fuse monitors from different power supplies, there must be multiple input cards being powered by those same power supplies as well. +24 Vdc 0 Vdc/Gnd PLC input card Connection from CCP2-PLC-IND to CCP2-3-xx Lead from CCP2-PLC-IND Power lead Leads from CCP2-PLC-IND are connected to the fork terminals as shown. Note: When monitoring a 1- or 2-pole switch, remove unused leads. Dimensions — in 2T 1 SIG 4T 3 1.9 6T 5L 3.7 10 Pin interlocks with CCP2 switch handle 2 3L 2 3 2.6 GND +24vDC +24vDC RESET STATUS 1L 1 ON 1.8 Eaton.com/bussmannseries 0.3 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Technical Data 10789 Effective January 2019 Class CC and UL Supplemental (IEC 10x38) Switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Required Switch CCP2-1-30CC 1 CCP2-2-30CC 2 CCP2-3-30CC 30 CCP2-1-30M CCP2-2-30M 3 1 2 CCP2-3-30M 3 Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description CCP2-PLC-IND Signal output 24 Vdc / 10 mA Accessories And Eaton.com/bussmannseries 11 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Class CC and UL Supplemental (IEC 10x38) clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-30CC 2 CCP2R-3-30CC 3 30 CCP2R-2-30M 2 CCP2R-3-30M 3 Left front rotary CCP2RL-2-30CC 2 CCP2RL-3-30CC 3 30 CCP2RL-2-30M 2 CCP2RL-3-30M 3 Right side rotary Required CCP2S-2-30CC 2 CCP2S-3-30CC 3 30 CCP2S-2-30M 2 CCP2S-3-30M 3 And Rotary handles Description NEMA rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow 4X CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Optional And 12 Eaton.com/bussmannseries Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Technical Data 10789 Effective January 2019 Accessories And Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — cannot be used on right front or right side operated switches CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description — Cannot be used on left front operated switches CCP2-PLC-IND Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries 13 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 Class CC and UL Supplemental (IEC 10x38) counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-30CC 2 CCP2SL-3-30CC 3 30 CCP2SL-2-30M 2 CCP2SL-2-30M 2 Required And Rotary handles Description NEMA rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow 4X CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Accessories And 14 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description —mounts on right side CCP2-AUX NO + NC, 5 A / 240 V Eaton.com/bussmannseries Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Technical Data 10789 Effective January 2019 Motor fuse sizing table: LP-CC time-delay Class CC fuses Voltage 115 Vac, 1-phase 230 Vac, 1-phase 200 Vac, 3-phase 208 Vac, 3-phase 230 Vac, 3-phase 460 Vac, 3-phase 575 Vac, 3-phase Motor size (Hp) 1/6 1/4 1/3 1/2 1/6 1/4 1/3 1/2 3/4 1 1-1/2 1/2 3/4 1 1-1/2 2 1/2 3/4 1 1-1/2 2 1/2 3/4 1 1-1/2 2 3 1/2 3/4 1 1-1/2 2 3 5 1/2 3/4 1 1-1/2 2 3 5 7-1/2 Motor FLA (amps) 4.4 5.8 7.2 9.8 2.2 2.9 3.6 4.9 6.9 8 10 2.5 3.7 4.8 6.9 7.8 2.4 3.5 4.6 6.6 7.5 2.2 3.2 4.2 6 6.8 9.6 1.1 1.6 2.1 3 3.4 4.8 7.6 0.9 1.3 1.7 2.4 2.7 3.9 6.1 9 Min (amps) 9 12 15 30 4.5 6 7 10 15 25 30 5 7.5 10 15 25 5 7 10 15 15 4.5 7 9 12 15 30 2.25 3.2 4.5 6 7 10 25 1.8 2.8 3.5 5 5.6 8 15 30 Code max (amps) 15 20 25 30 10 10 15 15 25 25 30 10 15 15 25 25 10 15 15 20 25 10 10 15 20 25 30 6 6 10 10 15 15 25 3 6 6 10 10 15 20 30 Heavy start (amps) 15 20 25 30 10 10 15 15 25 30 30 10 15 15 25 30 10 15 15 25 30 10 12 15 20 25 30 6 6.25 10 12 15 15 30 3.5 6 6.25 10 10 15 20 30 Note: NEMA motors only (no IEC or design B energy efficient). Minimum size if no more than 1 start/hour. Code max if low to moderate reverse/jog/plug applications. Heavy start permitted only if code max does not allow motor start-up. For high reverse/jog/plug applications or larger horsepower motors. Eaton.com/bussmannseries 15 Technical Data 10789 Compact Circuit Protector disconnect switches For use with Class CC, Supplemental and IEC 10x38 mm fuses Effective January 2019 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10789 – BU-MC18031 January 2019 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
CCP2S-3-30CC 价格&库存
很抱歉,暂时无法提供与“CCP2S-3-30CC”相匹配的价格&库存,您可以联系我们找货
