Technical Data 10414
BUSSMANN
SERIES
Effective October 2015
Compact high speed fuses — 500Vac/dc, 50-400A
Agency information
UL® Recognized, File E56412, Guide JFHR2
CSA® Component Acceptance, Class 1422-30,
File 53787
IEC aR (self certified)
CE
RoHS compliant
REACH declaration available upon request
Features:
Catalog symbol:
Use up to 48% less enclosure space to help
reduce the overall assembly size
Innovative design allows for a significantly
smaller package without compromising
heat rise performance, preventing extensive
equipment redesign
Global acceptance with UL, CSA, IEC and RoHS
for products sold worldwide
Bolt-on design provides design flexibility for
installation in fuse blocks or direct mounting on
busbars
Meets JASO D622 spec for thermal shock,
humidity, and vibration
Superior current cycling performance helps
withstand demanding applications
CHSF-(amp)
Description:
Eaton’s Bussmann® series compact high speed
fuses feature space-saving case sizes for
protecting semiconductor devices up to 500Vac/dc
in ratings from 50 to 400 amps.
Specifications:
Ratings
Recommended fuse blocks
Up to 100 amps
Catalog numbers
Wire size
Stud size
Volts - 500Vac/dc
BH-0111
#14-2/0 Cu
1/4-20
Amps – 50-400A
BH-0112
#14-2/0 Cu
5/16-18
Interrupting rating
BH-0121
(2) #14-1/0 Cu
1/4-20
(2) #14-1/0 Cu
5/16-18
#14-2/0 Cu
1/4-20 x 1/2
Max AC – 200kA
BH-0122
Min AC 400%
1BS101
Max DC – 50kA
Min DC 800%
See data sheet No. 1200 (BH-01_) and No. 1206
(1BS101) for details.
Conforms to IEC® aR specifications for shortcircuit protection
Up to 400 amps
Catalog numbers
Wire size
Stud size
BH-1131
#6-250kcmil Cu
1/4-20
BH-1132
#6-250kcmil Cu
5/16-18
1BS102
#6-250kcmil Cu
1/4-20 x 1/2
See data sheet No. 1201 (BH-11_) and No. 1207
(1BS102) for details.
Catalog numbers:
Watts loss / percent of rated current
Amps
AC/DC I2t (A2s)
pre-arcing
@ 80%
@ 50%
CHSF-50
50
304
1875
935
3.8
1.3
CHSF-60
60
438
2700
1346
4.5
1.5
CHSF-70
70
596
3675
1833
5.3
1.8
CHSF-80
80
778
4800
2394
6.1
2.0
CHSF-100
100
1216
7500
3740
7.6
2.5
CHSF-125
125
2042
12,721
6465
12.0
3.6
CHSF-150
150
2941
18,318
9309
14.3
4.3
CHSF-175
175
4003
24,933
12,671
16.7
5.1
CHSF-200
200
5228
32,566
16,550
19.1
5.8
CHSF-225
225
6835
48,028
21,278
26.1
7.0
CHSF-250
250
8438
59,293
26,270
29.0
7.8
CHSF-300
300
12,151
85, 382
37,828
34.8
9.4
CHSF-350
350
16,539
116,215
51,488
40.6
10.9
CHSF-400
400
21,603
151,791
67,250
46.4
12.5
Catalog number
AC* I2t (A2s)
total clear
DC** I2t (A2s)
total clear
* @ 200kA/500Vac.
** @ 50kA/500Vdc.
Dimensions — mm:
H
A
C
G
F
E
B
D2
D1
Case size amp range
50-100
A
B
C
D1
D2
E
F
G
H
81
61
57
8.7
16
7.7
3.2
125-200
92
25
53
77
68
8.7
19
7.8
3.2
225-400
92
30
53
74
68
8.7
25
9.0
4.8
2
Eaton.com/bussmannseries
AC minimum melt
10
A
A
Virtual pre-arcing time (s)
1
CHSF-125
CHSF-150
CHSF-175
CHSF-200
CHSF-225
CHSF-250
CHSF-300
CHSF-350
CHSF-400
CHSF-50
CHSF-60
CHSF-70
CHSF-80
CHSF-100
0.1
0.01
0.001
100
1000
Prospective current (ARMS)
10,000
3
AC total clearing
10
A
A
Virtual clearing time (s)
1
CHSF-125
CHSF-150
CHSF-175
CHSF-200
CHSF-225
CHSF-250
CHSF-300
CHSF-350
CHSF-400
CHSF-50
CHSF-60
CHSF-70
CHSF-80
CHSF-100
0.1
0.01
0.001
100
4
1000
10,000
AC peak let-through
B
Peak let-through current
100,000
10,000
CHSF-400
CHSF-300
CHSF-200
CHSF-100
CHSF-50
1000
A
100
100
1000
10,000
100,000
Prospective short-circuit current RMS Sym.
5
AC arc voltage
AC clearing I2t voltage correction factor
1.0
950
0.9
900
0.8
I2t correction factor
1,000
Peak arc voltage
850
800
750
700
0.7
0.6
0.5
0.4
650
0.3
600
0.2
200
550
250
300
350
400
System voltage (ACRMS)
450
500
500
100
150
200
250
300
350
400
450
500
DC arc voltage
DC clearing I2t voltage correction factor
1.0
1000
950
0.9
900
0.8
Peak arc voltage
850
800
750
700
650
600
0.7
0.6
0.5
0.4
550
0.3
500
100
6
150
200
250
300
350
System voltage (DC)
400
450
500
100
150
200
250
300
350
System voltage (DC)
400
450
500
Temperature derating
1.4
Melting time correction factor
1.3
1.2
1.1
1
0.9
0.8
0.7
-40 -30 -20 -10
10 20 30 40 50 60 70 80 90 100
Ambient temperature (°C)
7
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document
are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help
the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or
limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin.
Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 10414 — BU-MC15041
October 2015
Eaton and Bussmann are valuable trademarks
of Eaton in the US and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
IEC is a registered trademark of the
International Electrotechnical Commission.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“CHSF-150”相匹配的价格&库存,您可以联系我们找货
