DILA-22(230V50HZ,240V60HZ) 数据手册
Type: DILA−22(230V50HZ,240V60HZ)
Article No.: 276399
Ordering information
Connection technique
Screw terminals
Contacts M = Make
2M
Contacts B = Break
2B
Rated operational current AC–15 220 V 230 V 240 V
Ie
A
6
Rated operational current AC–15 380 V 400 V 415 V
Ie
A
4
Conventional current, open at 60 °C
Ith
A
10
Distinctive number and version of combination
DILA(C)−22
22E
Can be combined with auxiliary contact module
DILA−XHI(V)...
Contact sequence
Notes concerning the product group
With screw terminals:
1
Accessories
Page
1 Suppressor
281208
2 Auxiliary contact module
276420
Further actuating voltages
276315
With springloaded terminals:
Accessories
Page
1 Suppressor
281208
276420
276315
Contact numbers to EN 50011
Coil terminal markings to EN 50005
DC operated contactor relays have a built−in
suppressor circuit.
General
Standards
IEC/EN 60947, VDE 0660, UL, CSA
Lifespan, mechanical
AC operated
DC operated
Maximum operating frequency
2
Operations
× 106
Operations
106
Operations/h
9000
Climatic proofing
Damp heat, constant, to IEC
60068−2−78;
Damp heat, cyclic, to IEC 60068−2−30
Climatic proofing
60068−2−78; Damp heat, cyclical, to IEC
60068−2−30
Ambient temperature
Open
°C
−25/60
Enclosed
°C
−25/40
Ambient temperature, Storage
°C
−40/80
Mounting position
Mechanical shock resistance (IEC/EN 60068−2−27)
Half−sinusoidal shock, 10 ms
Basic unit with auxiliary contact module
Make contact
g
7
Break contact
g
5
Protection type
IP20
Protection against direct contact when actuated from
front (IEC 536)
Finger− and back−of−hand proof
Weight
AC operated
kg
0.23
DC operated
kg
0.28
Terminal capacities
Screw terminals
Solid
mm2
1 × (0,75 – 2,5)
2 × (0,75 – 2,5)
Flexible with ferrule
mm2
1 × (0,75 – 2,5)
2 × (0,75 – 2,5)
Solid or stranded
AWG
18 – 14
Terminal screw
M3.5
Pozidriv screwdriver
Size
2
Standard screwdriver
mm
0.8 × 5.5
1×6
max. tightening torque
Nm
1,2
Solid
mm2
1 × (0,75 – 2,5)
2 × (0,75 – 2,5)
Flexible with or without ferrule DIN 46228
mm2
1 × (0,75 – 2,5)
2 × (0,75 – 2,5)
Solid or stranded
AWG
18 – 14
mm
0.6 × 3.5
Spring loaded terminals
Contacts
Interlocked opposing contacts to ZH 1/457, including
Rated impulse withstand voltage
Yes
Uimp
V AC
Overvoltage category/pollution degree
6000
III/3
Rated insulation voltage
Ui
V AC
690
Rated operational voltage
Ue
V AC
690
3
Safe isolation to VDE 0106 Part 101 and Part 101/A1
between coil and auxiliary contacts
V AC
400
between the auxiliary contacts
V AC
400
AC–15
220/240 V
Ie
A
6
380/415 V
Ie
A
4
500 V
Ie
A
1,5
1
24 V
A
2,5
DV−13
DC−13 L/R f 15 ms
Contacts in series:
1
60 V
A
1
2
60 V
A
3
1
110 V
A
0,5
3
110 V
A
3
1
220 V
A
0,25
3
220 V
A
1
DC−13 L/R f 50 ms
Contacts in series:
3
24 V
A
4
3
60 V
A
4
3
110 V
A
2
3
220 V
A
1
Failure rate
−8, < one failure at 100 million operations
Ith
A
10
Control circuit reliability (at Ue = 24 V DC, Umin = 17
V, I min= 5.4 mA)
Conventional thermal current
Component lifespan at Ue = 240 V
Short−circuit rating without welding
Maximum overcurrent protective device
220/240 V
PKZM0 4
380/415 V
PKZM0 4
Short−circuit protection Maximum fuse
500 V
A gG/gL 10
Current heat loss at Ith
AC operated
W
0,3
DC operated
W
0,3
Magnet systems
Voltage tolerance
AC operated
Single−voltage coil 50 Hz and dual−voltage coil 50
Hz, 60 Hz
Pick−up
× Us
0,8 – 1,1
Dual−frequency coil 50/60 Hz
Pick−up
× Us
0,8 – 1,1
DC operated
4
Pick−up voltage
Anzug
× Us
0,8 – 1,1
Pick−up
× Uc
0,7 – 1,3
Hz, 60 Hz
Pick−up
VA
24
Hz, 60 Hz
Pick−up
W
19
Hz, 60 Hz
Sealing
VA
4
Hz, 60 Hz
Sealing
W
1,2
Without auxiliary contact module (40 °C)
Power consumption
Dual−frequency coil 50/60 Hz at 50 Hz
Pick−up
VA
28
Pick−up
W
22
Sealing
VA
4,6
Sealing
W
1,4
Dual−frequency coil 50/60 Hz at 60 Hz
Pick−up
VA
26
Pick−up
W
21
Sealing
VA
3,9
Sealing
W
1,2
DC operated
Pull−in =
sealing
W
3
Duty factor
% DF
100
Switching times at 100 % Uc (approximate values)
AC operated Closing delay
ms
AC operated Make contact Opening delay
ms
15
DC operated Closing delay
ms
35
DC operated Make contact Opening delay
ms
15
Notes
Making and breaking conditions to
DC−13, time constant as stated
See transparent overlay "Fuses" for
time/current characteristics (please
enquire)
Smoothed DC or three−phase bridge
rectifier
Mounting position
5
Moeller GmbH, Hein−Moeller−Str. 7−11, D−53115 Bonn
E−Mail: catalog@moeller.net, Internet: www.moeller.net, http://catalog.moeller.net
Copyright 2005 by Moeller GmbH. Subject to modifications. HPL−C2005GB−INT V3.0
6
