DATASHEET - DILM12-XSPR240
RC suppressor circuit, 110-240VAC, for DILA, DILM7-12
Similar to illustration
Part no.
Catalog No.
Alternate Catalog
No.
EL-Nummer
(Norway)
DILM12-XSPR240
281200
XTCEXRSBB
0004131888
Delivery program
Product range
Accessories
Accessories
Suppressor circuit
Voltage
Us
V
110 - 240 AC
For use with
DILM7 - DILM15
DILMP20
DILA
Contact sequence
Instructions
For AC operation contactors 50 - 60 Hz.
With DC operated contactors and with DILM115 and DILM150 the suppressor is
integrated.
Note drop-out delay
Design verification as per IEC/EN 61439
Technical data for design verification
Rated operational current for specified heat dissipation
In
A
Heat dissipation per pole, current-dependent
Pvid
W
Equipment heat dissipation, current-dependent
Pvid
W
Static heat dissipation, non-current-dependent
Pvs
W
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
60
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
IEC/EN 61439 design verification
05/05/2020
Eaton 281200 ED2020 V67.0 EN
1/3
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
Is the panel builder's responsibility. The specifications for the switchgear must be
observed.
10.12 Electromagnetic compatibility
observed.
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical data ETIM 7.0
Low-voltage industrial components (EG000017) / Surge protection module (EC000683)
Electric engineering, automation, process control engineering / Low-voltage switch technology / Contactor (LV) / Component for protective circuit (ecl@ss10.0.1-27-37-10-10 [AKF019013])
Function
RC-element
Rated control supply voltage Us at AC 50HZ
V
110 - 240
Rated control supply voltage Us at AC 60HZ
V
110 - 240
Rated control supply voltage Us at DC
V
0-0
Voltage type for actuating
AC
With LED indication
No
Product Standards
IEC/EN 60947-4-1; UL 508; CSA-C22.2 No. 14-05; CE marking
UL File No.
E29184
UL Category Control No.
NKCR2, NKCR8
CSA File No.
256465
CSA Class No.
3211-07
North America Certification
UL recognized, CSA certified
Specially designed for North America
No
05/05/2020
Approvals
2/3
Dimensions
Additional product information (links)
IL03407013Z (AWA2100-2126) Contactors
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03407013Z2020_05.pdf
Motor starters and "Special Purpose Ratings"
for the North American market
http://www.eaton.eu/ecm/groups/public/@pub/@europe/@electrical/documents/content/pct_3258146.pdf
Switchgear of Power Factor Correction
Systems
http://www.moeller.net/binary/ver_techpapers/ver934en.pdf
X-Start - Modern Switching Installations
Efficiently Fitted and Wired Securely
http://www.moeller.net/binary/ver_techpapers/ver938en.pdf
Mirror Contacts for Highly-Reliable Information http://www.moeller.net/binary/ver_techpapers/ver944en.pdf
Relating to Safety-Related Control Functions
Effect of the Cabel Capacitance of Long Control http://www.moeller.net/binary/ver_techpapers/ver949en.pdf
Cables on the Actuation of Contactors
Switchgear for Luminaires
http://www.moeller.net/binary/ver_techpapers/ver955en.pdf
http://www.moeller.net/binary/ver_techpapers/ver956en.pdf
Standard Compliant and Functionally Safe
Engineering Design with Mechanical Auxiliary
Contacts
The Interaction of Contactors with PLCs
http://www.moeller.net/binary/ver_techpapers/ver957en.pdf
Busbar Component Adapters for modern
Industrial control panels
http://www.moeller.net/binary/ver_techpapers/ver960en.pdf
05/05/2020
Eaton Industries GmbH
http://www.eaton.eu
© 04/2020 by Eaton Industries GmbH
3/3
很抱歉,暂时无法提供与“DILM12-XSPR240”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+270.74194
- 3+255.65141
