Technical Data 4139
Effective April 2016
Supersedes March 2007
DR1050
Shielded power inductors
Applications
LED/LCD backlighting
High definition televisions (HDTV)
Server and desktop power supplies
Graphics cards and battery powered systems
Point-of-load (POL) modules
Printers and peripherals
Portable electronics
Environmental Data
Description
Shielded drum core
Inductance range from 0.7 μH to 1000 μH
Current range from 0.43 A to 13.5 A
10.5 mm x 10.3 mm footprint surface mount
package in a 5.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
DR1050
Technical Data 4139
Product Specifications
OCL1
(μH) ±30%
Irms2
(A)
Isat3
(A)
DCR (mΩ)
typical
@ 20°C
DCR (mΩ)
maximum
@ 20°C
K-factor4
DR1050-R80-R
0.70
9.70
13.5
3.2
4.0
20.47
DR1050-1R5-R
1.37
8.60
10.5
4.0
5.0
14.62
DR1050-2R2-R
2.27
7.52
9.3
5.6
6.8
11.37
DR1050-3R3-R
3.21
6.50
8.2
8.0
10
9.30
DR1050-4R7-R
4.43
6.13
6.7
10
12
7.87
DR1050-6R8-R
6.30
5.45
5.8
13
17
6.82
DR1050-8R2-R
8.09
5.24
5.0
15
19
6.02
DR1050-100-R
10.1
4.80
4.6
18
23
5.39
DR1050-120-R
11.6
3.94
4.1
24
30
4.87
DR1050-150-R
14.8
3.80
3.7
26
33
4.45
DR1050-180-R
17.5
3.39
3.3
33
41
4.09
DR1050-220-R
23.5
3.12
3.0
39
48
3.53
DR1050-270-R
26.9
2.82
2.8
43
53
3.30
DR1050-330-R
34.3
2.56
2.5
58
72
2.92
DR1050-390-R
38.3
2.35
2.35
61
76
2.77
DR1050-470-R
47.1
2.06
2.10
89
111
2.50
DR1050-560-R
56.7
1.96
1.94
98
123
2.27
DR1050-680-R
67.2
1.84
1.70
111
139
2.09
DR1050-820-R
84.4
1.60
1.58
147
184
1.86
DR1050-101-R
97.5
1.52
1.45
164
205
1.73
DR1050-121-R
118
1.30
1.30
223
279
1.57
DR1050-151-R
149
1.26
1.15
238
298
1.40
DR1050-181-R
184
1.18
1.08
273
341
1.26
DR1050-221-R
222
1.00
0.98
377
472
1.15
DR1050-271-R
264
0.96
0.90
410
513
1.06
DR1050-331-R
321
0.83
0.80
554
693
0.96
DR1050-391-R
397
0.76
0.72
648
810
0.86
DR1050-471-R
481
0.64
0.62
855
1069
0.78
DR1050-561-R
573
0.62
0.60
970
1213
0.72
DR1050-681-R
708
0.56
0.55
1095
1369
0.64
DR1050-821-R
819
0.54
0.50
1185
1481
0.60
DR1050-102-R
1000
0.43
0.48
1528
1950
0.54
Part Number
5
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating
conditions verified in the end application.
3. Isat: Peak current for approximately 35% rolloff @ +25 °C
2
www.eaton.com/elx
4. K-factor: K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (mT),
K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
5. Part Number Definition: DR1050-xxx-R
DR1050 = Product code and size
-xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
DR1050
Technical Data 4139
Dimensions (mm)
Part marking: inductance value in uH. R = decimal point. If no R is present then last character equals number of zeroes.
wwlly = date code, R = revision level
Do not route traces or vias underneath the inductor
Packaging information (mm)
Supplied in tape and reel packaging , 500 parts per 13” diameter reel
www.eaton.com/elx
3
DR1050
Technical Data 4139
Temperature rise vs. total loss
160
Temperature Rise (°C)
140
120
100
80
60
40
0.2
0.4
0.6
0.8
1.0
1.2
Total Loss (W)
Core loss vs. Bp-p
10
1MHz
500kHz
300kHz
200kHz
100kHz
Core Loss (W)
1
0.1
0.01
0.001
1
10
100
Bp-p (mT)
4
www.eaton.com/elx
1000
DR1050
Technical Data 4139
Inductance characteristics
% of OCL vs. % of Isat
120%
100%
% of OCL
80%
60%
-40 °C
40%
+25 °C
20%
0%
+85 °C
0%
20%
40%
60%
80%
100%
120%
140%
% of Isat
www.eaton.com/elx
5
DR1050
Technical Data 4139
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“DR1050-271-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.764871+1.00583
- 国内价格 香港价格
- 1+7.757221+1.00483
- 10+6.3442910+0.82181
- 100+5.21918100+0.67607
