A Major Advance
in RTD Technology!
OMEGA® Thinfilm RTD Elements
C
Model F3105
19
2.
2
Features:
Size:
Some are as small as thermistors
Shape:
Flat or cylindrical packages
Calibration:
α = .00385
DIN 43760 curve
Accuracy:
Equal to conventional
wire-wound units
Response:
Better than equivalent size
wire-wound units
Temperature
Range:
-70 to 500°C (-95 to 930°F)
Configuration: Single and dual resistance 100 Ω
OMEGA introduces the OMEGAFILM® platinum
Discount Schedule
RTD element—an element achieved by employing 1 to 10 units . . . . . . . . . . .Net
construction techniques similar to those used to
11 to 24 units . . . . . . . . .10%
manufacture miniature electronic integrated
25 to 49 units . . . . . . . . .15%
circuits. The result: a precision element available
50 to 99 units . . . . . . . . .20%
in sizes considerably smaller than the head of a
100 units and up . . . . . . .25%
match. All this in a rugged, accurate, ceramic
encased package! Best of all, OMEGAFILM elements
are calibrated to the worldwide accepted DIN 43760
curve (alpha=0.00385), allowing use with standard
off-the-shelf instrumentation available from OMEGA
and others, both in the United States and abroad.
Accuracy and Specifications:
OMEGAFILM® platinum RTD’s are calibrated to
the internationally accepted DIN 43760 curve
(alpha=0.00385) and meet 0.1% DIN standard
tolerance. When you use these tables, please
note that the specific operating ranges for elements
vary and are listed on their specifications pages.
Applications:
Because of their small size and thin, flat packaging,
OMEGAFILM® sensors greatly extend the field of RTD
applications. Series W elements (such as the W2103)
lend themselves to encapsulation in short 1⁄8" O.D.
protection tubes or shallow holes bored in a metal
casing. Series F are ideal for surface measurement.
These may be taped, cemented or embedded. To
obtain accurate representative measurements, good
thermal contact between the surface and the element
is important. For temporary installations, a compatible
temperature-rated heat- conductive compound, such
as a heat sink grease can be used.
C-28
m
m
m
m
Shown larger
than actual
size
2.
2
Basic Unit
OMEGA Thinfilm RTD Elements
OMEGAFILM® RTD’s can be used
with various OMEGA® controllers
and digital readout thermometers.
The following shows where some
of these instruments can be found
in this catalog:
Instrument
Section
1. DP41-RTD series meters
2. DP25-RTD digital indicators
3. CN77000 series controllers
All RTD elements
available with
Teflon® insulated
lead wire.
Pricing is dependent
on lead style,
See page with
“RTD Elements with
Lead Wires Attatched”
(page C-12).
M
M
P
OMEGA can offer Series W
and Series F OMEGAFILM® RTD’s
encapsulated in hex head
machine screws and other
metal holders. Please contact
OMEGA’s Applications Engineering
Department about other
custom assemblies.
Discount Schedule
Shown
larger than
actual size
OMEGAFILM® – Platinum RTD Elements (Alpha=.00385)
Series
Dimensions in millimeters
(1 mm = .03937")
3.0 mm
W
12*
W
3.0 mm
12*
2.0 mm
W
Nominal
Resistance
(ohms)
100
200
400
500
1000
2000
100
200
400
500
1000
Single or
Dual
1
1
1
1
1
1
2
2
2
2
2
Temperature
Range
x
x
x
x
x
x
x
x
x
x
x
1
x
100
W2103
36
2
x
100
W2204
64
-50
to
600°C
(-58
to
1112°F)
Model
Number
W2102
W2112
W2122
W2132
W2142
W2152
W2202
W2212
W2222
W2232
W2242
Price
$32
35
39
39
48
97
58
68
66
61
71
7
3.0 mm
7
STOCKED FOR IMMEDIATE DELIVERY
* Length is 17 mm for 1000 and 2000 ohm elements
C-29
OMEGAFILM RTD Elements
Series W. Series W are rugged,
ceramic, cylindrically shaped
elements for use in the temperature
range from -50 to 600°C (-58 to
1112°F). Elements have .015"
gold palladium alloy leads
approximately 0.4" long, which
are strain relieved in the stress free
ceramic body. Elements are available
in both single and dual configurations
with resistances at 0°C (32°F) of 100,
200, 400, 500, 1000 and 2000 ohms.
Calibration conforms to standard DIN
43760 with 0.1% resistance tolerance.
Resistance vs. Temperature values
are shown in the technical section.
Series F. Series F are small, thin, flat
ceramic encased elements with strain
relieved leads approximately 10 mm
(0.4") long. Temperature rating is
from -50 to 600°C (-60 to 1110°F).
Calibration is to DIN standard 43760,
0.1% tolerance. Available in a single
winding configuration with a choice
of 100, 500 and 1000 ohm resistance
at 0°C (32°F). Series F elements
yield a superior approach to
accurate, reliable, surface
temperature measurement.
Model WS81. The WS81 donut
shaped 100 ohm RTD element
offers fast, accurate temperature
measurement as well as a
convenient means of attaching to
a surface without cement. These
highly versatile units can be secured
to a surface by a machine screw and
washer or by a rivet. They can also
be directly cemented with or without
the use of a vertical centering post.
Rated temperature is from -50 to
850°C (-58 to 1562°F). Accuracy
and speed of response are enhanced
by locating the winding deposition
only 0.007" beneath the mounting
surface. The rugged ceramic body,
with firmly strain relieved 0.015"
diameter platinum, is designed to
withstand high vibration conditions.
This versatile 100 ohm unit meets
DIN standard 43760, “0.1%”
resistance tolerance. Resistance vs.
Temperature tables and polynomials
Shown
larger than
actual size
Discount Schedule
OMEGAFILM®– Platinum RTD Elements (Alpha=.00385)
Series
(1 mm = .03937")
F
1 mm Thick
F
1 mm Thick
F
Nominal
Single or
Resistance
Dual
(ohms)
1
x
100
Temperature
Range
Model
Number
F3101
Price
$19
1
x
500
F3131
19
1
1
x
x
1000
100
F3141
F3102
19
19
F3132
19
F3142
19
-50
to
600°C
(-60
to
1110°F)
1
x
500
1
x
1000
1
x
100
F3105
19
1
x
100
F3107
19
WS81
87
1 mm Thick
F
1.0
WS
2.2
6.7
1
x
2.1 thick
C-30
100
-50 to
850°C
(-60 to
1560°F)
C
很抱歉,暂时无法提供与“E34VFBK1”相匹配的价格&库存,您可以联系我们找货
