E57G-30SPC10-Q
E57G-30SPC10-Q
    EATON(伊顿)
    EATON CUTLER HAMMER - E57G-30SPC10-Q - SENSOR, INDUCTIVE, 10MM, 10-30VDC, PNP
E57G-30SPC10-Q 数据手册
Inductive Proximity Sensors E57G General Purpose Proximity Sensors 3.4 Contents E57G General Purpose Proximity Sensors Description Page E57G General Purpose Proximity Sensors Product Selection E57G General Purpose Proximity Sensors . Compatible Connector Cables . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . V8-T3-30 V8-T3-31 V8-T3-31 V8-T3-32 V8-T3-33 V8-T3-34 3 3 3 3 3 3 3 3 3 3 3 E57G General Purpose Proximity Sensors Product Description Features For global sensing applications, the E57G General Purpose series is designed for most standard inductive sensing needs.   With its stainless steel tubular body, 360 degree visible LED, fast switching speed and laser-etched markings, the E57G series is an ideal cost-effective solution. ● ● ● ● ● ● ● ● ● Standards and Certifications 360° LED indicator Stainless steel tube 10–30 Vdc operating voltage Short-circuit protection –25 to 70 °C temperature range IP67 environmental rating Durable laser-engraved label Available in cable and micro-connector styles Nickel-brass mounting nuts ● ● cULus Listed CE 3 DANGER THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage. 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 For the most current information on this product, visit our Web site: www.eaton.com For Customer Service in the U.S. call 1-877-ETN CARE (386-2273), in Canada call 1-800-268-3578. For Application Assistance in the U.S. and Canada call 1-800-426-9184. Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com V8-T3-29 3 3 3.4 Inductive Proximity Sensors E57G General Purpose Proximity Sensors 3 Product Selection 3 E57G General Purpose Proximity Sensors Three-Wire Sensors 3 3 Operating Voltage 12 mm 3 Sensing Range Shielding Output Type Connection Type NO Output Catalog Number Shielded PNP 2-meter cable E57G-12SPN2-C2 E57G-12SPC2-C2 4-pin micro DC connector E57G-12SPN2-Q E57G-12SPC2-Q 2-meter cable E57G-12SNN2-C2 E57G-12SNC2-C2 4-pin micro DC connector E57G-12SNN2-Q E57G-12SNC2-Q 2-meter cable E57G-12UPN4-C2 E57G-12UPC4-C2 4-pin micro DC connector E57G-12UPN4-Q E57G-12UPC4-Q NPN 2-meter cable E57G-12UNN4-C2 E57G-12UNC4-C2 4-pin micro DC connector E57G-12UNN4-Q E57G-12UNC4-Q PNP 2-meter cable E57G-12SPN4-C2 E57G-12SPC4-C2 4-pin micro DC connector E57G-12SPN4-Q E57G-12SPC4-Q 2-meter cable E57G-12SNN4-C2 E57G-12SNC4-C2 4-pin micro DC connector E57G-12SNN4-Q E57G-12SNC4-Q 2-meter cable E57G-12UPN8-C2 E57G-12UPC8-C2 4-pin micro DC connector E57G-12UPN8-Q E57G-12UPC8-Q 2-meter cable E57G-12UNN8-C2 E57G-12UNC8-C2 4-pin micro DC connector E57G-12UNN8-Q E57G-12UNC8-Q 2-meter cable E57G-18SPN5-C2 E57G-18SPC5-C2 4-pin micro DC connector E57G-18SPN5-Q E57G-18SPC5-Q 2-meter cable E57G-18SNN5-C2 E57G-18SNC5-C2 4-pin micro DC connector E57G-18SNN5-Q E57G-18SNC5-Q 2-meter cable E57G-18UPN8-C2 E57G-18UPC8-C2 4-pin micro DC connector E57G-18UPN8-Q E57G-18UPC8-Q 2-meter cable E57G-18UNN8-C2 E57G-18UNC8-C2 4-pin micro DC connector E57G-18UNN8-Q E57G-18UNC8-Q 2-meter cable E57G-18SPN8-C2 E57G-18SPC8-C2 4-pin micro DC connector E57G-18SPN8-Q E57G-18SPC8-Q 2-meter cable E57G-18SNN8-C2 E57G-18SNC8-C2 4-pin micro DC connector E57G-18SNN8-Q E57G-18SNC8-Q 2-meter cable E57G-18UPN12-C2 E57G-18UPC12-C2 4-pin micro DC connector E57G-18UPN12-Q E57G-18UPC12-Q 2-meter cable E57G-18UNN12-C2 E57G-18UNC12-C2 4-pin micro DC connector E57G-18UNN12-Q E57G-18UNC12-Q 12 mm Diameter 10–30 Vdc 2 mm (standard range) 3 NPN 3 4 mm (standard range) Unshielded 3 3 4 mm Shielded (extended range) 3 PNP NPN 3 8 mm Unshielded (extended range) 3 3 3 PNP NPN 18 mm 18 mm Diameter 10–30 Vdc 3 5 mm (standard range) Shielded 3 PNP NPN 3 8 mm (standard range) Unshielded 3 PNP NPN 3 8 mm Shielded (extended range) 3 PNP NPN 3 12 mm Unshielded (extended range) 3 PNP NPN 3 3 Note See listing of compatible connector cables on Page V8-T3-31. 3 3 3 3 3 3 V8-T3-30 NC Output Catalog Number Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com 3.4 Inductive Proximity Sensors E57G General Purpose Proximity Sensors Three-Wire Sensors, continued Operating Voltage 30 mm Sensing Range 3 Shielding Output Type Connection Type NO Output Catalog Number NC Output Catalog Number Shielded PNP 2-meter cable E57G-30SPN10-C2 E57G-30SPC10-C2 4-pin micro DC connector E57G-30SPN10-Q E57G-30SPC10-Q 2-meter cable E57G-30SNN10-C2 E57G-30SNC10-C2 4-pin micro DC connector E57G-30SNN10-Q E57G-30SNC10-Q 3 30 mm Diameter 10–30 Vdc 10 mm (standard range) NPN 15 mm (standard range) Unshielded PNP 2-meter cable E57G-30UPN15-C2 E57G-30UPC15-C2 4-pin micro DC connector E57G-30UPN15-Q E57G-30UPC15-Q 2-meter cable E57G-30UNN15-C2 E57G-30UNC15-C2 4-pin micro DC connector E57G-30UNN15-Q E57G-30UNC15-Q PNP 2-meter cable E57G-30SPN15-C2 E57G-30SPC15-C2 4-pin micro DC connector E57G-30SPN15-Q E57G-30SPC15-Q NPN 2-meter cable E57G-30SNN15-C2 E57G-30SNC15-C2 4-pin micro DC connector E57G-30SNN15-Q E57G-30SNC15-Q NPN 15 mm Shielded (extended range) 22 mm Unshielded (extended range) PNP NPN 2-meter cable E57G-30UPN22-C2 E57G-30UPC22-C2 4-pin micro DC connector E57G-30UPN22-Q E57G-30UPC22-Q 2-meter cable E57G-30UNN22-C2 E57G-30UNC22-C2 4-pin micro DC connector E57G-30UNN22-Q E57G-30UNC22-Q Number of Pins 3 3 3 3 3 3 3 Gauge Length 22 AWG 6.0 ft (2m) Pin Configuration/Wire Colors (Face View Female Shown) PVC Jacket Catalog Number PUR Jacket Catalog Number CSDS4A3CY2202 CSDS4A3RY2202 Micro-Style, Straight Female DC 3 3 Standard Cables 1 Micro-Style Straight Female 3 3 Compatible Connector Cables Voltage Style 3 4-pin, 3-wire 1-Brown 2-No Wire 3-Blue 4-Black 3 3 3 3 3 3 Accessories 3 E57G General Purpose Proximity Sensors Description Reference Mounting brackets See Tab 8, section 8.2 Replacement mounting nuts and other accessories See Tab 8, section 8.3 Connector cables See Tab 10, section 10.1 3 3 3 3 Notes See listing of compatible connector cables on Page V8-T3-31. 1 3 For a full selection of connector cables, see Tab 10, section 10.1. 3 3 3 3 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com V8-T3-31 3.4 Inductive Proximity Sensors E57G General Purpose Proximity Sensors 3 Technical Data and Specifications 3 E57G General Purpose Proximity Sensors Description Three-Wire DC Sensors 3 Operating voltage 10–30 Vdc Output current (continuous) 100 mA 3 Switching frequency [Hz] Standard range: 12 mm—Shielded: 2000; Unshielded: 2000 18 mm—Shielded: 1200; Unshielded: 1200 30 mm—Shielded: 600; Unshielded: 500 Extended range: 12 mm—Shielded: 1200; Unshielded: 500 18 mm—Shielded: 300; Unshielded: 300 30 mm—Shielded: 400; Unshielded: 200 3 3 3 3 Leakage current
E57G-30SPC10-Q 价格&库存
很抱歉,暂时无法提供与“E57G-30SPC10-Q”相匹配的价格&库存,您可以联系我们找货
