Inductive Proximity Sensors
E57G General Purpose Proximity Sensors
3.4
Contents
Description
Page
Product Selection
E57G General Purpose Proximity Sensors .
Compatible Connector Cables . . . . . . . . . . .
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . .
Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . .
V8-T3-30
V8-T3-31
V8-T3-31
V8-T3-32
V8-T3-33
V8-T3-34
3
3
3
3
3
3
3
3
3
3
3
Product Description
Features
For global sensing
applications, the E57G
General Purpose series is
designed for most standard
inductive sensing needs.
With its stainless steel
tubular body, 360 degree
visible LED, fast switching
speed and laser-etched
markings, the E57G series
is an ideal cost-effective
solution.
Standards and Certifications
360° LED indicator
Stainless steel tube
10–30 Vdc operating
voltage
Short-circuit protection
–25 to 70 °C temperature
range
IP67 environmental rating
Durable laser-engraved
label
Available in cable and
micro-connector styles
Nickel-brass mounting nuts
cULus Listed
CE
3
DANGER
THIS SENSOR IS NOT A
SAFETY DEVICE AND IS NOT
INTENDED TO BE USED AS A
SAFETY DEVICE. This sensor
is designed only to detect
and read certain data in an
electronic manner and
perform no use apart from
that, specifically no safetyrelated use. This sensor
product does not include
self-checking redundant
circuitry, and the failure of
this sensor product could
cause either an energized
or de-energized output
condition, which could result
in death, serious bodily
injury, or property damage.
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
For the most current information
on this product, visit our Web site:
www.eaton.com
For Customer Service in the U.S. call 1-877-ETN CARE (386-2273),
in Canada call 1-800-268-3578.
For Application Assistance in the U.S. and Canada
call 1-800-426-9184.
Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com
V8-T3-29
3
3
3.4
3
Product Selection
3
Three-Wire Sensors
3
3
Operating
Voltage
12 mm
3
Sensing
Range
Shielding
Output Type
Connection Type
NO Output
Catalog Number
Shielded
PNP
2-meter cable
E57G-12SPN2-C2
E57G-12SPC2-C2
4-pin micro DC connector
E57G-12SPN2-Q
E57G-12SPC2-Q
2-meter cable
E57G-12SNN2-C2
E57G-12SNC2-C2
E57G-12SNN2-Q
E57G-12SNC2-Q
2-meter cable
E57G-12UPN4-C2
E57G-12UPC4-C2
E57G-12UPN4-Q
E57G-12UPC4-Q
NPN
2-meter cable
E57G-12UNN4-C2
E57G-12UNC4-C2
E57G-12UNN4-Q
E57G-12UNC4-Q
PNP
2-meter cable
E57G-12SPN4-C2
E57G-12SPC4-C2
E57G-12SPN4-Q
E57G-12SPC4-Q
2-meter cable
E57G-12SNN4-C2
E57G-12SNC4-C2
E57G-12SNN4-Q
E57G-12SNC4-Q
2-meter cable
E57G-12UPN8-C2
E57G-12UPC8-C2
E57G-12UPN8-Q
E57G-12UPC8-Q
2-meter cable
E57G-12UNN8-C2
E57G-12UNC8-C2
E57G-12UNN8-Q
E57G-12UNC8-Q
2-meter cable
E57G-18SPN5-C2
E57G-18SPC5-C2
E57G-18SPN5-Q
E57G-18SPC5-Q
2-meter cable
E57G-18SNN5-C2
E57G-18SNC5-C2
E57G-18SNN5-Q
E57G-18SNC5-Q
2-meter cable
E57G-18UPN8-C2
E57G-18UPC8-C2
E57G-18UPN8-Q
E57G-18UPC8-Q
2-meter cable
E57G-18UNN8-C2
E57G-18UNC8-C2
E57G-18UNN8-Q
E57G-18UNC8-Q
2-meter cable
E57G-18SPN8-C2
E57G-18SPC8-C2
E57G-18SPN8-Q
E57G-18SPC8-Q
2-meter cable
E57G-18SNN8-C2
E57G-18SNC8-C2
E57G-18SNN8-Q
E57G-18SNC8-Q
2-meter cable
E57G-18UPN12-C2
E57G-18UPC12-C2
E57G-18UPN12-Q
E57G-18UPC12-Q
2-meter cable
E57G-18UNN12-C2
E57G-18UNC12-C2
E57G-18UNN12-Q
E57G-18UNC12-Q
12 mm Diameter
10–30 Vdc
2 mm
(standard range)
3
NPN
3
4 mm
(standard range)
Unshielded
3
3
4 mm
Shielded
(extended range)
3
PNP
NPN
3
8 mm
Unshielded
(extended range)
3
3
3
PNP
NPN
18 mm
18 mm Diameter
10–30 Vdc
3
5 mm
(standard range)
Shielded
3
PNP
NPN
3
8 mm
(standard range)
Unshielded
3
PNP
NPN
3
8 mm
Shielded
(extended range)
3
PNP
NPN
3
12 mm
Unshielded
(extended range)
3
PNP
NPN
3
3
Note
See listing of compatible connector cables on Page V8-T3-31.
3
3
3
3
3
3
V8-T3-30
NC Output
Catalog Number
3.4
Three-Wire Sensors, continued
Operating
Voltage
30 mm
Sensing
Range
3
Shielding
Output Type
Connection Type
NO Output
Catalog Number
NC Output
Catalog Number
Shielded
PNP
2-meter cable
E57G-30SPN10-C2
E57G-30SPC10-C2
E57G-30SPN10-Q
E57G-30SPC10-Q
2-meter cable
E57G-30SNN10-C2
E57G-30SNC10-C2
E57G-30SNN10-Q
E57G-30SNC10-Q
3
30 mm Diameter
10–30 Vdc
10 mm
(standard range)
NPN
15 mm
(standard range)
Unshielded
PNP
2-meter cable
E57G-30UPN15-C2
E57G-30UPC15-C2
E57G-30UPN15-Q
E57G-30UPC15-Q
2-meter cable
E57G-30UNN15-C2
E57G-30UNC15-C2
E57G-30UNN15-Q
E57G-30UNC15-Q
PNP
2-meter cable
E57G-30SPN15-C2
E57G-30SPC15-C2
E57G-30SPN15-Q
E57G-30SPC15-Q
NPN
2-meter cable
E57G-30SNN15-C2
E57G-30SNC15-C2
E57G-30SNN15-Q
E57G-30SNC15-Q
NPN
15 mm
Shielded
(extended range)
22 mm
Unshielded
(extended range)
PNP
NPN
2-meter cable
E57G-30UPN22-C2
E57G-30UPC22-C2
E57G-30UPN22-Q
E57G-30UPC22-Q
2-meter cable
E57G-30UNN22-C2
E57G-30UNC22-C2
E57G-30UNN22-Q
E57G-30UNC22-Q
Number
of Pins
3
3
3
3
3
3
3
Gauge
Length
22 AWG
6.0 ft (2m)
Pin Configuration/Wire Colors
(Face View Female Shown)
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
CSDS4A3CY2202
CSDS4A3RY2202
Micro-Style, Straight Female
DC
3
3
Standard Cables 1
Micro-Style
Straight Female
3
3
Voltage
Style
3
4-pin,
3-wire
1-Brown
2-No Wire
3-Blue
4-Black
3
3
3
3
3
3
Accessories
3
Description
Reference
Mounting brackets
See Tab 8,
section 8.2
Replacement mounting nuts and other accessories
See Tab 8,
section 8.3
Connector cables
See Tab 10,
section 10.1
3
3
3
3
Notes
1
3
For a full selection of connector cables, see Tab 10, section 10.1.
3
3
3
3
V8-T3-31
3.4
3
3
Description
Three-Wire DC Sensors
3
Operating voltage
10–30 Vdc
Output current (continuous)
100 mA
3
Switching frequency [Hz]
Standard range:
12 mm—Shielded: 2000; Unshielded: 2000
18 mm—Shielded: 1200; Unshielded: 1200
30 mm—Shielded: 600; Unshielded: 500
Extended range:
12 mm—Shielded: 1200; Unshielded: 500
18 mm—Shielded: 300; Unshielded: 300
30 mm—Shielded: 400; Unshielded: 200
3
3
3
3
Leakage current
很抱歉,暂时无法提供与“E57G-30UPC15-C2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+654.064241+84.88560
- 5+610.442555+79.22430
- 10+566.9079210+73.57430
