E57PS-12SPC2-C2
E57PS-12SPC2-C2
    EATON(伊顿)
    EATON CUTLER HAMMER - E57PS-12SPC2-C2 - SENSOR, INDUCTIVE, 2MM, 10-48VDC, PNP
E57PS-12SPC2-C2 数据手册
3.3 3 Inductive Proximity Sensors E57PS Performance Short Body Sensors Contents E57PS Performance Short Body Sensors Description 3 Page E57PS Performance Short Body Sensors Product Selection E57PS Performance Short Body Sensors . . Compatible Connector Cables . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 3 3 3 V8-T3-25 V8-T3-25 V8-T3-26 V8-T3-26 V8-T3-27 V8-T3-27 3 3 3 3 3 E57PS Performance Short Body Sensors 3 Product Description Features For demanding sensing applications in areas too small for standard length units, the E57PS Performance Short Body series is an ideal solution as it incorporates the premium features of the E57P series but in a shorter body length. With its stainless steel tubular body, IP69K rating, wide temperature range (down to –40 °C), fast switching speed and laser-etched markings, the E57PS series provides value at a low price point. ● 3 3 3 3 3 3 3 ● ● ● ● ● ● ● 360° LED indicator Stainless steel tube 10–48 Vdc operating voltage Short-circuit protection –40 to 70 °C temperature range IP69K environmental rating Durable laser-engraved label Available in cable and micro-connector styles Standards and Certifications ● ● cULus Listed CE 3 3 DANGER THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage. 3 3 3 3 3 3 3 3 3 For the most current information on this product, visit our Web site: www.eaton.com V8-T3-24 For Customer Service in the U.S. call 1-877-ETN CARE (386-2273), in Canada call 1-800-268-3578. For Application Assistance in the U.S. and Canada call 1-800-426-9184. Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com 3.3 Inductive Proximity Sensors E57PS Performance Short Body Sensors Product Selection 3 E57PS Performance Short Body Sensors 3 Three-Wire Sensors Operating Voltage 12 mm NO Output Catalog Number NC Output Catalog Number 2 mm Shielded (standard range) (PNP) 2-meter cable E57PS-12SNN2-C2 E57PS-12SNC2-C2 4-pin micro DC connector E57PS-12SNN2-Q E57PS-12SNC2-Q Shielded (NPN) 2-meter cable E57PS-12SPN2-C2 E57PS-12SPC2-C2 4-pin micro DC connector E57PS-12SPN2-Q E57PS-12SPC2-Q 4 mm Unshielded (standard range) (PNP) 2-meter cable E57PS-12UNN4-C2 E57PS-12UNC4-C2 4-pin micro DC connector E57PS-12UNN4-Q E57PS-12UNC4-Q Unshielded (NPN) 2-meter cable E57PS-12UPN4-C2 E57PS-12UPC4-C2 4-pin micro DC connector E57PS-12UPN4-Q E57PS-12UPC4-Q 5 mm Shielded (standard range) (PNP) 2-meter cable E57PS-18SNN2-C2 E57PS-18SNC2-C2 4-pin micro DC connector E57PS-18SNN2-Q E57PS-18SNC2-Q Shielded (NPN) 2-meter cable E57PS-18SPN2-C2 E57PS-18SPC2-C2 4-pin micro DC connector E57PS-18SPN2-Q E57PS-18SPC2-Q 8 mm Unshielded (standard range) (PNP) 2-meter cable E57PS-18UNN4-C2 E57PS-18UNC4-C2 4-pin micro DC connector E57PS-18UNN4-Q E57PS-18UNC4-Q Unshielded (NPN) 2-meter cable E57PS-18UPN4-C2 E57PS-18UPC4-C2 4-pin micro DC connector E57PS-18UPN4-Q E57PS-18UPC4-Q 3 10 mm Shielded (standard range) (PNP) 2-meter cable E57PS-30SNN2-C2 E57PS-30SNC2-C2 3 4-pin micro DC connector E57PS-30SNN2-Q E57PS-30SNC2-Q Shielded (NPN) 2-meter cable E57PS-30SPN2-C2 E57PS-30SPC2-C2 3 3 3 3 3 3 18 mm Diameter 10–48 Vdc 30 mm 3 Connection Type 1 Shielding 12 mm Diameter 10–48 Vdc 18 mm Sensing Range (Sn) 3 3 3 3 30 mm Diameter 10–48 Vdc 4-pin micro DC connector E57PS-30SPN2-Q E57PS-30SPC2-Q 15 mm Unshielded (standard range) (PNP) 2-meter cable E57PS-30UNN4-C2 E57PS-30UNC4-C2 4-pin micro DC connector E57PS-30UNN4-Q E57PS-30UNC4-Q Unshielded (NPN) 2-meter cable E57PS-30UPN4-C2 E57PS-30UPC4-C2 4-pin micro DC connector E57PS-30UPN4-Q E57PS-30UPC4-Q 3 3 3 3 3 Compatible Connector Cables 3 Standard Cables 2 Voltage Style Micro-Style Straight Female Number of Pins Gauge Length 22 AWG 6.0 ft (2m) Pin Configuration/Wire Colors (Face View Female Shown) PVC Jacket Catalog Number PUR Jacket Catalog Number 1-Brown 2-White 3-Blue 4-Black CSDS4A4CY2202 CSDS4A4RY2202 Micro-Style, Straight Female DC 4-pin, 4-wire 3 3 3 3 Notes See listing of compatible connector cables above. 3 1 3 2 Cable models are supplied as standard with a 2-meter cable. A 5-meter cable is available by adding S5 to the catalog number. Example: E57SAL12T110 becomes E57SAL12T110S5. For a full selection of connector cables, see Tab 10, section 10.1. 3 3 3 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com V8-T3-25 3.3 3 3 Inductive Proximity Sensors E57PS Performance Short Body Sensors Accessories E57PS Performance Short Body Sensors Description Reference 3 Mounting brackets See Tab 8, section 8.2 3 Replacement mounting nuts and other accessories See Tab 8, section 8.3 3 Connector cables See Tab 10, section 10.1 3 3 Technical Data and Specifications 3 E57PS Performance Short Body Sensors 3 Description Three-Wire DC Sensors 3 Operating voltage 10–48 Vdc Maximum load current 300 mA Switching frequency [Hz] 12 mm—Shielded: 2000; Unshielded: 2000 18 mm—Shielded: 1200; Unshielded: 1200 30 mm—Shielded: 600; Unshielded: 500 Leakage current 100 μA maximum 3 Voltage drop ≤2.5 V Holding current ≤10 mA 3 Short-circuit protection Yes (Auto Reset) Switching hysteresis 2–20% of rated sensing distance 3 3 3 Repeat accuracy 1% shielded, 3% unshielded 3 Output indicator LED 360° amber LED Operating temperature –40 to 158 °F (–40 to 70 °C) 3 Enclosure ratings IP67, IP69K; NEMA 4, 4X, 6, 6P Shock 30 g sine wave, 11 ms per IEC68-2-76 3 Vibration 10 to 55 Hz, 1 mm amplitude Material of construction Stainless steel, polycarbonate end bells, Ryton® front cap Cable AWM Style 20387 (PVC) 3 3 Note Ryton® is a registered trademark of Phillips Chemical (division of Phillips Petroleum). 3 3 3 3 3 3 3 3 3 3 V8-T3-26 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com Inductive Proximity Sensors E57PS Performance Short Body Sensors 3.3 Wiring Diagrams Pin numbers are for reference, rely on pin location when wiring. 3 E57PS Performance Short Body Sensors 3 Operating Voltage Output 3 Micro-Connector Models (Face View Male Shown) Cable Models 3 Three-Wire Sensors 10–48 Vdc NO (NPN) BN BK (–) Load BU NO (PNP) (_) 3 Load +V Load 3 (–) (–) BN BK 3 Load +V BU NC (PNP) 3 +V (–) Load BN BK 3 +V BU NC (NPN) 3 Load (–) BN BK +V +V 3 +V BU Load (–) Load 3 +V 3 (_) 3 Dimensions Approximate Dimensions in Inches (mm) 3 E57PS Performance Short Body Sensors—Cable Models 3 12 mm 18 mm A A A B B C 3 30 mm C C 3 B 3 D Size Shielding 3 D Sensing Face D Sensing Face Sensing Face 3 Overall Length A Threaded Length B Cap Height C Thread Size D M12 x 1 3 3 Three-Wire DC Sensors 12 mm Shielded 1.61 (40.9) 1.07 (27.2) — Unshielded 1.61 (40.9) 0.89 (22.7) 0.20 (5.0) M12 x 1 18 mm Shielded 1.77 (44.9) 1.17 (29.8) — M18 x 1 Unshielded 1.77 (44.9) 0.92 (23.3) 0.28 (7.0) M18 x 1 30 mm Shielded 1.84 (46.6) 1.15 (29.3) — M30 x 1.5 Unshielded 1.84 (46.6) 0.66 (16.8) 0.51 (13.0) M30 x 1.5 3 3 3 3 3 3 3 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com V8-T3-27 3.3 3 3 3 3 E57PS Performance Short Body Sensors Approximate Dimensions in Inches (mm) E57PS Performance Short Body Sensors—Micro-Connector Models 12 mm 3 3 Inductive Proximity Sensors 18 mm A A C C C D D D Sensing Face Sensing Face Sensing Face Size Shielding Overall Length A Threaded Length B Cap Height C Thread Size D Three-Wire DC Sensors 3 12 mm 3 3 A B B B 3 3 30 mm Shielded 1.64 (41.5) 1.07 (27.2) — M12 x 1 Unshielded 1.64 (41.5) 0.89 (22.7) 0.20 (5.0) M12 x 1 18 mm Shielded 1.59 (40.3) 1.17 (29.8) — M18 x 1 Unshielded 1.59 (40.3) 0.92 (23.3) 0.28 (7.0) M18 x 1 30 mm Shielded 1.77 (45.0) 1.15 (29.3) — M30 x 1.5 Unshielded 1.96 (49.7) 0.66 (16.8) 0.51 (13.0) M30 x 1.5 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 V8-T3-28 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com
E57PS-12SPC2-C2 价格&库存
很抱歉,暂时无法提供与“E57PS-12SPC2-C2”相匹配的价格&库存,您可以联系我们找货
