EASY-E4-UC-8RE1
EASY-E4-UC-8RE1
    EATON(伊顿)
    EATON MOELLER - EASY-E4-UC-8RE1 - Digital I/O Module, 4 I/O, 24 VAC/ VDC, easyE4 Series
EASY-E4-UC-8RE1 数据手册
DATASHEET - EASY-E4-UC-8RE1 I/O expansion, For use with easyE4, 12/24 V DC, 24 V AC, Inputs expansion (number) digital: 4, screw terminal Delivery program Part no.  Catalog No.    EL-Nummer (Norway)  EASY-E4-UC-8RE1 197217 4500550 Product range     Control relays easyE4 Subrange     easyE4 digital input/output enhancements Basic function     easyE4 extensions Description     Input/output extension for easyE4 control relay Expandable with the easyE4 series of digital input/output expansions with easy-E4CONNECT1 connector (Item Y7-197225) Rated operating voltage 12V DC, 24V DC or 24V AC Digital inputs: 4 Digital outputs: 4 relays Screw terminals Inputs           digital: 4       Display     with diagnostic LED Software     EASYSOFT-SWLIC/easySoft 7 Supply voltage     12/24 V DC 24 V AC For use with     easyE4 Standards     EN 61000-6-2 EN 61000-6-3 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-30 IEC 61131-2 EN 61010 EN 50178 Approvals       Approvals     cULus certificate     CE shipping classification     DNV GL       Dimensions (W x H x D)   mm 35.5 x 90 x 58 Weight   kg 0.125 Mounting     Top-hat rail IEC/EN 60715, 35 mm or screw fixing using fixing brackets ZB4-101-GF1 (accessories) Connection type     Screw terminal Screw terminals     Inputs expansion (number) Additional features Technical data General Terminal capacities   Solid   mm flexible   mm Solid or flexible conductor, with ferrule   mm 0,2 - 2,5 Solid or stranded   AWG 22 - 12 Standard screwdriver   mm 0.8 x 3.5 Tightening torque   Nm 0.5 - 0.7 Stripping length   mm 6.5 02/18/2020 2 0.2 - 4 2 0.2 - 2.5 2 Eaton Y7-197217 ED2020 V65.0 EN 1/7 Climatic environmental conditions Operating ambient temperature   °C -25 to 55, cold as per IEC 60068-2-1, heat as per IEC 60068-2-2 Condensation     Take appropriate measures to prevent condensation Storage ϑ °C -40 - +70 relative humidity   % in accordance with IEC 60068-2-30, IEC 60068-2-78 5 - 95 Air pressure (operation)   hPa 795 - 1080 Protection type (IEC/EN 60529, EN50178, VBG 4)     IP20 Vibrations   Hz In accordance with IEC 60068-2-6 constant amplitude 0.15 mm: 10 - 57 constant acceleration 2 g: 57 - 150 Mechanical shock resistance (IEC/EN 60068-2-27) semi-sinusoidal 15 g/11 ms   Impacts 18 Drop to IEC/EN 60068-2-31 Drop height mm 50 Free fall, packaged (IEC/EN 60068-2-32)   m 0.3 Mounting position     Vertical or horizontal Overvoltage category/pollution degree     III/2 Electrostatic discharge (ESD) Ambient conditions, mechanical Electromagnetic compatibility (EMC)       applied standard     according to IEC EN 61000-4-2 Air discharge   kV 8 Contact discharge   kV 6 Electromagnetic fields (RFI) to IEC EN 61000-4-3   V/m 0.8 - 1.0 GHz: 10 1.4 - 2 GHz: 3 2.0 - 2.7 GHz: 1 Radio interference suppression     EN 61000-6-3 Class B Burst   kV according to IEC/EN 61000-4-4 Supply cables: 2 Signal cables: 2 power pulses (Surge)     according to IEC/EN 61000-4-5 1 kV (supply cables, symmetrical) 2 kV (supply cables, asymmetrical) Immunity to line-conducted interference to (IEC/EN 61000-4-6)   V 10 Clearance in air and creepage distances     nach EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Insulation resistance     in accordance with EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Rated operational voltage Ue V 12/24 DC (-15/+20%) 24 AC (-15/+10%) Permissible range Ue   10.2 - 28.8 V DC 20.4 - 26.4 V AC Residual ripple   % ≦5 Siemens MPI, (optional)     yes Frequency   Hz 50/60 (± 5%) Input current     max. 150 mA at 12 V DC max. 80 mA at 24 V DC Voltage dips   ms ≤ 20 ms at 24 V AC 10 ms at 24 V DC 1 ms at 12 V DC Fuse   A ≧ 1A (T) Power loss P W Normally 2 Heat dissipation at 24 V DC   W 2 Number     4 Potential isolation     from power supply: no between inputs: no from the outputs: yes to base unit: yes to expansion devices: yes Rated operational voltage Ue V DC 12 Input voltage   V DC Status 0: ≦ 5 (I1 - I4) Condition 1: ≧ 8 (I1 - I4) Input current at signal 1   mA 1.75 mA (I1 - I4) Deceleration time   ms type 0.2 (0 -> 1) Insulation resistance Power supply Digital inputs 12 V DC 02/18/2020 Eaton Y7-197217 ED2020 V65.0 EN 2/7 type 0.15 (1 -> 0) Cable length   m 100 (unshielded) Number     4 Potential isolation     from power supply: no between inputs: no from the outputs: yes to base unit: yes to expansion devices: yes Rated operational voltage Ue V DC 24 Input voltage   V DC Signal 0: ≦ 5 (I1 - I4) Signal 1: ≧ 15 (I1 - I4) Input current at signal 1   mA 3.3 (I1 – I4) Deceleration time   ms type 0.1 (0 -> 1) type 0.2 (1 -> 0) Cable length   m 100 (unshielded) Number     4 Potential isolation     from power supply: no between inputs: no from the outputs: yes to base unit: yes to expansion devices: yes Rated operational voltage Ue V AC 24 Input voltage (AC = sinusoidal) Ue V Status 0: ≦ 5 (I1 - I8) Condition 1: ≧ 14 (I1 - I4) Rated frequency   Hz 50/60 Input current at signal 1   mA I1 - I4: 3.5 (at 24 VAC/DC) Deceleration time   ms type 25⁄21 (0 - > 1/1 -> 0, 50/60Hz) Cable length   m 40 (unshielded) Number     4 Outputs in groups of     1 Parallel switching of outputs for increased output     Not permitted Protection of an output relay     B16 circuit breaker or 8 A (T) fuse Potential isolation     Safe isolation according to EN 50178: 300 V AC Basic isolation: 600 V AC from power supply: yes From the inputs: yes between outputs: yes to expansion devices: yes Contacts Digital inputs 24 V DC Digital inputs 24 V AC Relay outputs       Conventional thermal current (10 A UL)   A 5 Recommended for load: 12 V AC/DC   mA > 500 Rated impulse withstand voltage Uimp of contact coil   kV 6 Rated operational voltage Ue V AC 240 Rated insulation voltage Ui V AC 240 Safe isolation according to EN 50178   V AC 300 between coil and contact 300 between two contacts Making capacity       AC–-15, 250 V AC, 3 A (600 ops./h) Operations   300000 DC-13, L/R ≦ 150 ms, 24 V DC, 1 A (500 S/h) Operations   200000 Breaking capacity       AC-15, 250 V AC, 3 A (600 Ops./h) Operations   300000 DC-13, L/R ≦ 150 ms, 24 V DC, 1 A (500 S/h) Operations   200000       1000 W at 230/240 V AC Operations   25000 500 W at 115/120 V AC Operations   25000       Filament bulb load Fluorescent lamp load Fluorescent lamp load 10 x 58 W at 230/240 V AC       With upstream electrical device Operations   25000 Uncompensated Operations   25000 Operations   25000 Fluorescent lamp load 1 x 58 W at 230/240 V AC, conventional, compensated 02/18/2020 Eaton Y7-197217 ED2020 V65.0 EN 3/7 Switching frequency     Mechanical operations   x 10 Switching frequency   Hz 10 Resistive load/lamp load   Hz 2 Inductive load   Hz 0.5 UL/CSA   6 10       Uninterrupted current at 240 V AC   A 5 Uninterrupted current at 24 V DC   A 5 AC       Control Circuit Rating Codes (utilization category)     B 300 Light Pilot Duty Max. rated operational voltage   V AC 300 max. thermal continuous current cos ϕ = 1 at B 300   A 5 max. make/break cos ϕ ≠ capacity 1 at B 300   VA 3600/360 DC       Control Circuit Rating Codes (utilization category)     R 300 Light Pilot Duty Max. rated operational voltage   V DC 300 Max. thermal uninterrupted current at R 300   A 1 Max. make/break capacity at R 300   VA 28/28 P W 2       Static heat dissipation, non-current-dependent Pvs W 2 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 55       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Meets the product standard's requirements. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties Supply voltage UAux Power loss Design verification as per IEC/EN 61439 Technical data for design verification IEC/EN 61439 design verification       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 PLC's (EG000024) / Logic module (EC001417) 02/18/2020 Eaton Y7-197217 ED2020 V65.0 EN 4/7 Electric engineering, automation, process control engineering / Control / Programmable logic control (SPS) / Logic module (ecl@ss10.0.1-27-24-22-16 [AKE539014]) Supply voltage AC 50 Hz   V 20.4 - 28.8 Supply voltage AC 60 Hz   V 20.4 - 28.8 Supply voltage DC   V 10.2 - 28.8 Voltage type of supply voltage     AC/DC Switching current   A 5 Number of analogue inputs     0 Number of analogue outputs     0 Number of digital inputs     4 Number of digital outputs     4 With relay output     Yes Number of HW-interfaces industrial Ethernet     0 Number of interfaces PROFINET     0 Number of HW-interfaces RS-232     0 Number of HW-interfaces RS-422     0 Number of HW-interfaces RS-485     0 Number of HW-interfaces serial TTY     0 Number of HW-interfaces USB     0 Number of HW-interfaces parallel     0 Number of HW-interfaces Wireless     0 Number of HW-interfaces other     2 With optical interface     No Supporting protocol for TCP/IP     No Supporting protocol for PROFIBUS     No Supporting protocol for CAN     No Supporting protocol for INTERBUS     No Supporting protocol for ASI     No Supporting protocol for KNX     No Supporting protocol for MODBUS     No Supporting protocol for Data-Highway     No Supporting protocol for DeviceNet     No Supporting protocol for SUCONET     No Supporting protocol for LON     No Supporting protocol for PROFINET IO     No Supporting protocol for PROFINET CBA     No Supporting protocol for SERCOS     No Supporting protocol for Foundation Fieldbus     No Supporting protocol for EtherNet/IP     No Supporting protocol for AS-Interface Safety at Work     No Supporting protocol for DeviceNet Safety     No Supporting protocol for INTERBUS-Safety     No Supporting protocol for PROFIsafe     No Supporting protocol for SafetyBUS p     No Supporting protocol for other bus systems     No Radio standard Bluetooth     No Radio standard WLAN 802.11     No Radio standard GPRS     No Radio standard GSM     No Radio standard UMTS     No IO link master     No Redundancy     No With display     No Degree of protection (IP)     IP20 Basic device     No Expandable     Yes 02/18/2020 Eaton Y7-197217 ED2020 V65.0 EN 5/7 Expansion device     Yes With timer     No Rail mounting possible     Yes Wall mounting/direct mounting     Yes Front build in possible     No Rack-assembly possible     No Suitable for safety functions     No Category according to EN 954-1       SIL according to IEC 61508     None Performance level acc. EN ISO 13849-1     None Appendant operation agent (Ex ia)     No Appendant operation agent (Ex ib)     No Explosion safety category for gas     None Explosion safety category for dust     None Width   mm 35.5 Height   mm 90 Depth   mm 58 UL File No.     E205091 UL Category Control No.     NRAQ/7 North America Certification     UL listed Degree of Protection     IEC: IP20, UL/CSA Type: - Approvals 02/18/2020 Eaton Y7-197217 ED2020 V65.0 EN 6/7 Dimensions Assets (links) Declaration of CE Conformity 00003207 Instruction Leaflets IL050021ZU2019_02 Manuals MN050009_EN (English) Additional product information (links) assembly instructions easyE4 IL050021ZU assembly instructions easyE4 IL050021ZU ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL050021ZU2019_02.pdf easyE4 (MN050009) manual easyE4 – Handbuch (MN050009) - Deutsch ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_DE.pdf easyE4 (MN050009) manual - English ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_EN.pdf Manuale easy E4 (MN050009) - italiano ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_IT.pdf instrukcja easyE4 (MN050009) - polski ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_PL.pdf f1=1454&f2=1174&f3=1755;Download Software http://applications.eaton.eu/sdlc?LX=11& easySoft V7 Product overview (WEB) 02/18/2020 http://www.eaton.eu/easyE4 Eaton Industries GmbH http://www.eaton.eu © 02/2020 by Eaton Industries GmbH Eaton Y7-197217 ED2020 V65.0 EN 7/7
EASY-E4-UC-8RE1 价格&库存
很抱歉,暂时无法提供与“EASY-E4-UC-8RE1”相匹配的价格&库存,您可以联系我们找货
EASY-E4-UC-8RE1
  • 1+1063.665501+137.87130
  • 5+987.732995+128.02900
库存:3
