Technical Data ELX1113
Effective December 2021
ECMS1V0905
Common mode choke, surface mount
Applications
Product features
High frequency filter
Square type closed magnetic core
Current rating up to 6 A
10 mm x 7.5 mm surface mount package in a
4.8 mm height
Moisture sensitivity level (MSL): 1
Battery backup
Renewable energy products
High tech consumer products
Appliances
LED lighting
Smart meters
Industrial IoT equipment
Motion controls
Power supplies
Medical equipment
Environmental compliance and general
specifications
Storage temperature (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
ECMS1V0905
Product specifications
Impedance1 (Ω)
mimimum
Impedance1 (Ω )
typical
DCR2 (mΩ)
@ +25 °C
maximum
Rated current3
(A)
maximum
Rated voltage
(Vdc)
maximum
Insulation
resistance4 @
(MΩ) minimum
ECMS1V0905-301-R
225
300
6.0
6.0
80
10
ECMS1V0905-601-R
450
600
8.0
5.5
80
10
ECMS1V0905-701-R
500
700
10
5.0
80
10
ECMS1V0905-102-R
750
1000
13
4.0
80
10
ECMS1V0905-222-R
1700
2200
50
3.0
80
10
ECMS1V0905-272-R
2000
2700
80
2.0
80
10
Part number
5
1. Impedance test parameters: 100 MHz, 0.1 Vrms, parallel connection (1,2 - 4,3), +25 °C
2. DCR test parameters: parallel connection (1,2 - 4,3), 4-wire method measured at +25°C
3. Rated current: DC current for an approximate temperature rise of 40 °C without core loss. It is
recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
4. Insulation resistance: Coil to coil
5. Part Number Definition: ECMS1Vxxxx-yyy-R
ECMS1V = Product code
xxxx= Size indicator
yyy= Typical impedance value in ohms. R= decimal point, if no R is present then last digit indicates the number of
zeros
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended PCB Layout
Schematic
Dimension
Value
A
9.0 ±0.5
A1
9.5 ±0.5
B
7.0 ±0.5
C
4.8 maximum
D
1.5 typical
E
1.7 typical
F
5.6 typical
Part marking: xxx= Typical impedance value in ohms
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.5 millimeters unless stated otherwise
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ECMS1V0905
Packaging information (mm)
Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant)
700 parts per reel
Dimension
Value
W
24.0 ±0.3
F
11.5 ±0.1
E1
1.75 ±0.1
E2
na
P0
4.0 ±0.1
P1
16 ±0.1
P2
2.0 ±0.1
D0
1.5 +0.1/-0
D1
1.5 +0.1/-0
A0
9.5 ±0.1
B0
7.7 ±0.1
K0
5.0 ±0.1
T
0.4 ±0.05
3
Impedance vs frequency
4
ECMS1V0905
ECMS1V0905
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“ECMS1V0905-102-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.39396
- 200+0.53946
- 700+0.52056
- 1400+0.51117
- 国内价格 香港价格
- 1+8.714181+1.13282
