Control Relays and Timers
Safety Relays
40.10 Safety Relays
Product Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Application Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Standards and Certifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Product Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2
2
2
2
3
4
7
Note: Supplement to Volume 7—Motor Controls, Logic and Connectivity, CA08100008E, Tab 40.
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
Control Relays and Timers CA04902001E—March 2011 www.eaton.com
1
40.10
40
Safety Relays
Contents
Safety Relays
Description
40
Page
Safety Relays
40
40
3
4
7
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
Product Description
Features
Safety relays are intended to
reliably monitor the signals
from safety devices at all
times and switch off quickly
and reliably in an emergency.
Single-channel and dual
channel versions are available
for the construction of safety
applications. The internal
logic of the safety relays
monitors the safety circuits
(emergency stop, guard door,
and so on) and activates the
enable paths in a fault-free
condition. Upon actuation of
the safety device or in the
even of a fault, the enable
paths are switched off. Any
faults that occur in the control
circuit, such as ground fault,
cross connection fault or wire
breakage are also detected.
Eaton’s ESR5 safety relays
provide optimal safety and a
high degree of reliability on
plant machinery. Applications
that meet the highest
safety requirements in
accordance with EN 954-1,
EN ISO 13849-1 up to PL e
and accordance with
IEC 62061 up to SILCL 3
can be realized with the
ESR5 safety relay.
Compatible with a wide
variety of safety devices:
Emergency stops
Rope pulls
Two-hand control stations
Light curtain (OSSD)
Gate enable device
Safety switches
Use for the highest
EN ISO 13849-1,
IEC 62061 and EC 61508
Suitable for the world
market with UL, cUL
certifications and TÜV
Rhineland functional
safety certifications
Applicable for EN 60204
stop categories 0 or 1
Plug-in screw terminals
for fast and fault-free
replacement
Multi-voltage versions
(24–230 Vac/Vdc) for a
flexible range of application
Delayed and non-delayed
contact expansions
accommodate a wide
variety of applications
40
40
40
40
40
40
40
40
2
Standards and
Certifications
UL 508; CSA-C22.2 No
14-95; CE Marked
UL/cUL file number:
E29184
Degree of protection: IP20
TÜV Rhineland certified
UL/cULus listed
Safety Relays
40.10
Product Selection
Safety Relays
40
Technical Overview
40
Single
Channel
Dual
Channel
Safety
Safety
Output (NO) Output
Output (NO) (Delayed)
Delay
Signal
Output
(NC)
Feedback Control
Output
Voltage
Removable
Terminal
Type of
Blocks
Unit
Catalog Number
4
1
24 Vac/Vdc
Main
ESR5-NO-41-24VAC-DC
2
1
24 Vac/Vdc
Main
ESR5-NO-21-24VAC-DC
3
1
24 Vac/Vdc
Main
ESR5-NO-31-24VAC-DC
3
1
230 Vac
Main
ESR5-NO-31-230VAC
3
1
24–230 Vac/Vdc
Main
ESR5-NO-31-AC-DC
2
2
0.1–30s
24 Vdc
Main
ESR5-NV3-30
2
1
24 Vac/Vdc
Main
ESR5-NZ-21-24VAC-DC
5
1
1
24 Vac/Vdc
Expansion
ESR5-NE-51-24VAC-DC
4
0.3–3s
1
1
24 Vdc
Expansion
ESR5-VE3-42
40
40
40
40
40
40
40
Application Overview
Emergency Safety
Stop
Switches
Light Curtain/ Two-Hand Control
(EN 574 Type III C)
OSSD
Contact
Expansion
Off-Delayed
Cross Circuit
Recognition
Monitored
Manual Reset Catalog Number
ESR5-NO-21-24VAC-DC
ESR5-NO-31-24VAC-DC
ESR5-NO-31-230VAC
ESR5-NO-31-AC-DC
ESR5-NV3-30
40
40
ESR5-NO-41-24VAC-DC
ESR5-NZ-21-24VAC-DC
ESR5-NE-51-24VAC-DC
ESR5-VE3-42
40
40
40
40
40
Application Overview, continued
40
Single
Channel
Dual
Channel
Stop Category
EN 60204
Control Category
to EN 954-1
Achievable PL per
ISO 13849-1
Achievable SIL per
EN IEC 62061
Catalog Number
PL d
SIL 3
ESR5-NO-41-24VAC-DC
PL e
SIL 3
ESR5-NO-21-24VAC-DC
PL e
SIL 3
ESR5-NO-31-24VAC-DC
PL e
SIL 3
ESR5-NO-31-230VAC
PL e
SIL 3
ESR5-NO-31-AC-DC
0/1
4
PL e
SIL 3
ESR5-NV3-30
PL e
SIL 3
ESR5-NZ-21-24VAC-DC
PL e
SIL 3
ESR5-NE-51-24VAC-DC
1
3
PL d
SIL 2
ESR5-VE3-42
40
40
40
40
40
40
Notes
Laser scanners or light curtains with OSSD outputs.
All main units can also be reset automatically or manually.
40
40
40
40
40
40
40
3
40.10
40
40
40
Safety Relays
Safety Relay
Description
Unit
Standards
40
40
40
Type-dependent standards
Lifespan, mechanical—c (contacts)
x 106
Maximum operating frequency
Ops/h
Climatic proofing
40
40
ESR5-NO-21_
ESR5-NO-41_
ESR5-NO-31-24VAC-DC
ESR5-NZ-21_
EN ISO 13849-1, IEC 62061,
IEC 61508, DIN EN 50178,
UL/CUL listed
UL/CUL listed
UL/CUL listed
UL/CUL listed
General
EN 574 Part no. IIIC
10
10
10
10
3600
3600
3600
3600
Cold according to
EN 60068-2-1, dry heat
according to EN60068-2-2,
damp heat according to
EN 60068-2-3
Dry heat according to
EN60068-2-2, damp heat
according to EN 60068-2-3
Cold according to
EN 60068-2-3
–4° to 131° (–20° to 55°)
Ambient temperature
°F (°C)
40
Ambient temperature storage
°F (°C)
–13° to 167° (–25° to 75°)
Mounting position
Any
Any
Any
Any
40
Vibration resistance (IEC/EN 60068-2-6)
2g, frequency: 10–150 Hz,
amplitude: 0.15 mm
amplitude: 0.15 mm
amplitude: 0.15 mm
2 g, frequency: 10–150 Hz,
amplitude: 0.15 mm
40
Shock resistance (IEC 60068-2-27)
Protection type
Housing
IP20
IP20
IP20
IP20
IP20
IP20
IP20
IP20
Finger- and back-of-hand
proof
proof
proof
proof
40
40
40
40
40
40
40
40
40
40
Terminals
Protection against direct contact when
actuated from front (IEC 0106 Part 100)
Weight
kg
0.17
0.22
0.17
0.22
Terminal capacity
Solid or flexible
mm2
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
Flexible with ferrule
mm2
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
Solid or stranded
AWG
24–12
24–12
24–12
24–12
2
Terminal screw
Pozidriv screwdriver
Size
2
2
2
Flat-blade screwdriver
mm
0.6 x 3.5
0.6 x 3.5
0.6 x 3.5
0.6 x 3.5
Max. tightening torque
Nm
0.6
0.6
0.6
0.6
Vac
6000
4000
4000
6000
Main Contacts
Rated impulse withstand voltage—Uimp
Overvoltage category/pollution degree
Outside
Inside
III/2
III/2
III/2
III/2
Rated insulation voltage—Ui
Vac
250
250
250
250
40
Rated operating voltage—Ue
Vac
230
230
230
230
40
Rated operation current
AC-15
230V (360 ops./h)—Ie
A
5
4
5
4
230V (3600 ops./h)—Ie
A
3
3
3
3
40
40
40
40
40
40
DC-13
24V (360 ops./h)—Ie
A
6
4
6
4
24V (3600 ops./h)—Ie
A
3
2.5
3
2.5
Max. summation current of all poles
24 Vac/Vdc devices
230 Vac devices
A
72
72
72
72
A
72 A2 (6 + 6)
72 A2 (4.2 + 4.2 + 4.2 + 4.2)
72 A2 (4.9 + 4.9 + 4.9)
72 A2 (6 + 6)
10
6
10
6
Square of the total current
(and total current)
of all current paths
Short-circuit protection
Max. fuse
A gG/gL
40
4
40.10
Safety Relays
Safety Relay, continued
Description
Unit
ESR5-NO-21_
ESR5-NO-41_
ESR5-NO-31-24VAC-DC
ESR5-NZ-21_
Actuating voltage 50/60 Hz
Vac
24
24
24
24
Actuating voltage—Us
Vdc
24
24
24
24
Voltage tolerance pick-up voltage
xe
0.85–1.1
0.85–1.1
0.85–1.1
0.85–1.1
Power consumption
AC operated 50/60 Hz
VA
40
Power Supply Circuit
40
40
40
40
W
3.4
3.4
3.4
3
DC operated
W
1.6
1.6
1.6
1.5
Short-circuit proof
Short-circuit proof
Short-circuit proof
Short-circuit proof
40
40
Fuse for control circuit supply
24V
115/230V
40
Control Circuit
Rated output voltage
Vdc
24
24
24
24
Rated operational current
mA
S12, S22: 30, S34: 45
S12: 65, S34: 40
S11, S21: 60, Y2: 45
50
22
50
22
2.3
2.3
2.3
2.3
Resistance—R
Short-circuit current
A
Response time
ms
100
65
100
50
Recovery time
ms
Response time with reset monitoring—tA1
ms
40
40
40
Response time without reset monitoring—tA2
ms
100
65
100
50
Reset time—tR/tR1
ms
Single-channel 45;
dual-channel 10
45
Single-channel 45;
dual-channel 10
40
Minimum on duration—tM
ms
Recovery time—tW
ms
Approx. 1000
Approx. 1000
Approx. 1000
Approx. 1000
Synchronous monitoring time—tS
ms
500
Emitted interference
EN 61000-6-4
EN 61000-6-4
EN 61000-6-4
EN 61000-6-4
Interference immunity
According to EN 61000-6-2,
EN 62061
EN 62061
40
Electromagnetic Compatibility (EMC)
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
5
40.10
40
40
Safety Relays
Description
Unit
ESR5-NO-31-230VAC
ESR5-NO-31-24V230VAC-DC
ESR5-NV3_
ESR5-VE3_
ESR5-NE-51_
General
Standards
EN ISO 13849-1, IEC 62061, EN ISO 13849-1, IEC 62061, EN ISO 13849-1, IEC 62061, EN ISO 13849-1, IEC 62061, EN ISO 13849-1, IEC 62061,
IEC 61508, DIN EN 50178, IEC 61508, DIN EN 50178, IEC 61508, DIN EN 50178, IEC 61508, DIN EN 50178, IEC 61508, DIN EN 50178,
UL/CUL listed
UL/CUL listed
UL/CUL listed
UL/CUL listed
UL/CUL listed
40
EN 60204
(if applicable)
EN 60204
(if applicable)
EN 60204
(if applicable)
40
x 106
10
10
10
10
10
Ops/h
3600
3600
3600
900
3600
40
40
Climatic proofing
Cold in accordance with: Dry heat according to
EN60068-2-2, damp heat EN60068-2-2, damp heat EN 60068-2-1, dry heat in EN60068-2-2, damp heat EN60068-2-2, damp heat
according to EN 60068-2-3 according to EN 60068-2-3 accordance with EN
60068-2-2, humidity
storage test in accordance
with 60068-2-78
40
40
Ambient temperature
°F (°C)
40
°F (°C)
–13° to 167° (–25° to 75°) –13° to 167° (–25° to 75°) –13° to 167° (–25° to 75°) –13° to 167° (–25° to 75°) –13° to 167° (–25° to 75°)
Mounting position
Any
40
2g, frequency: 10–150 Hz, 2g, frequency: 10–150 Hz, 2g, frequency: 10–150 Hz, 2g, frequency: 10–150 Hz, 2g, frequency: 10–150 Hz,
amplitude: 0.15 mm
amplitude: 0.15 mm
amplitude: 0.15 mm
amplitude: 0.15 mm
amplitude: 0.15 mm
40
Protection type
Housing
IP40
IP40
IP20
IP20
IP20
IP20
IP20
IP20
IP20
IP20
proof
proof
proof
proof
proof
40
Terminals
Any
–4° to 113° (–20° to 45°)
Any
Any
Any
40
40
Weight
kg
0.3
0.3
0.17
0.17
0.22
Terminal capacity
Solid or flexible
mm2
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
1 x (0.2–2.5)
2 x (0.2–1)
mm2
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
1 x (0.25–2.5)
2 x (0.25–1)
Solid or stranded
AWG
24–12
24–12
24–12
24–12
24–12
2
40
40
40
40
40
40
40
40
Terminal screw
Size
2
2
2
2
mm
0.6 x 3.5
0.6 x 3.5
0.6 x 3.5
0.6 x 3.5
0.6 x 3.5
Nm
0.6
0.6
0.6
0.6
0.6
Rated impulse withstand voltage—Uimp Vac
6000
6000
4000
4000
4000
Outside
III/2
III/2
III/2
III/2
III/2
Main Contacts
Inside
Vac
250
250
250
250
250
Vac
230
230
230
230
230
40
AC-15
40
A
4
4
5
4
A
3
3
3
3
3
40
40
40
40
40
40
DC-13
24V (360 ops./h)—Ie
A
4
4
6
4
A
2.5
2.5
3
3
2.5
A
50
50
49
50
50
A
50
50
50 A2 (4 + 4 + 4)
50 A2 (4 + 4 + 4)
50 A2 (4 + 4 + 4)
49 A2
(3.5 + 3.5 + 3.5 + 3.5)
50 A2
(3.7 + 3.7 + 3.7 + 3.7
+ 3.7)
6
6
10
10
6
24 Vac/Vdc devices
230 Vac devices
(and total current)
Max. fuse
6
A gG/gL
Safety Relays
40.10
Description
Unit
ESR5-NO-31-230VAC
40
ESR5-NV3_
ESR5-VE3_
ESR5-NE-51_
40
Vac
230
24–230
24
Vdc
230
24
24
24
xe
0.85–1.1
0.85–1.1
0.85–1.1
0.85–1.1
0.8–1.1
Power consumption
40
VA
W
5.8
5.8
2.2
40
DC operated
W
2.9
2.9
1.8
2
2.2
40
Short-circuit proof
Short-circuit proof
Short-circuit proof
40
24V
115/230V
40
40
Control Circuit
Vdc
24
24
24
24
24
mA
S10, S12, S22: 35, S34,
S35: 45
S35: 45
S12, S22: 3.5, S34, S35: 7
A1, A2: 84, K1/K2: 5
A1, A2: 92
40
11
11
500
0.7
0.7
0.1
40
Resistance—R
A
40
Response time
ms
250
250
150
Recovery time
ms
monitoring—tA1
ms
60
60
150
monitoring—tA2
ms
250
250
150
Reset time—tR/tR1
ms
20 (non-delayed enable
paths); 100 (min. delayed
enable paths)
0.3–3 s (+50%)
adjustable
40
ms
Recovery time—tW
ms
Approx. 1000
Approx. 1000
Approx. 330
Approx. 1000
ms
40
EN 61000-6-4
EN 61000-6-4
EN 61000-6-4
EN 61000-6-4
EN 61000-6-4
40
According to
EN 61000-6-2
According to
EN 61000-6-2
According to EN 61000-6-2, According to
EN 62061
EN 61000-6-2
According to
EN 61000-6-2
40
40
Dimensions
40
Approximate Dimensions in Inches (mm)
40
Safety Relays, Contact Expansion Modules
ESR5_ 24 Vac/Vdc
0.88
(22.5)
40
ESR5_ 230 Vac
1.77
(45.0)
4.51
(114.5)
3.06 3.90
(77.6) (99.0)
3.26 2.62
(82.8) (66.5)
40
4.51
(114.5)
40
40
3.06 3.90
(77.6) (99.0)
3.26 2.62
(82.8) (66.5)
40
40
0.26
(6.6)
3.74
(95.1)
0.26
(6.6)
3.74
(95.1)
40
40
40
7
Eaton’s Electrical Sector is
a global leader in power
distribution, power quality,
control and automation, and
monitoring products. When
combined with Eaton’s full-scale
engineering services, these
products provide customerdriven PowerChain™ solutions
to serve the power system
needs of the data center,
industrial, institutional, public
sector, utility, commercial,
residential, IT, mission critical,
alternative energy and OEM
markets worldwide.
PowerChain solutions help
enterprises achieve sustainable
and competitive advantages
through proactive management
of the power system as a
strategic, integrated asset
throughout its life cycle,
resulting in enhanced safety,
greater reliability and energy
efficiency. For more information,
visit www.eaton.com/electrical.
Eaton Corporation
Electrical Sector
1111 Superior Ave.
Cleveland, OH 44114
United States
877-ETN-CARE (877-386-2273)
Eaton.com
©2011 Eaton Corporation
All Rights Reserved
Printed in USA
Publication No. CA04902001E / Z10889
March 2011
Eaton is a registered trademark of Eaton
Corporation. All oher trademarks are
property of their respective owners.
